Sep 07, 2011, 08:23 PM
United States, KS, Overland Park
Joined Aug 2004
Originally Posted by 94'325is
Not the highest output charger but I love my Hi-Tec X4 charger. It's 4 50W chargers in one and you can charge every type of battery commonly available. Even though you can't charge at 10A you can still charge 4 4S in the time it takes for the higher output chargers, but you're charging at a lower Amp rate and I'm a fan of being as easy as possible on my batteries.
um...well...your not being any easier on your packs. if you are charging 4x 4s4000 packs on a high output charger at 16 amps, that is the same as charging all of them individually at 4 amps. the different is you only have to set it once, and you dont have to sit and watch and wait to swap out packs on the charger (which you dont have to do anyways with the 4 port  , but you can do up to 6 packs at once with most parallel cable sets)
Latest blog entry: Transmitt
