Old Oct 13, 2009, 07:30 AM
RC4x4 is online now
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Originally Posted by Buzzed
RC4x4,
Where did you get your Xoar props? I just received two Xoars today in the mail but they are drilled to about 10mm. Both my prop adapters (Scorpion and Hyperion) are 8mm.
All my props show up needing to be drilled, but not these.
Ughhhhh,
-Buzzed
I usually get all my Xoar's from Chief Aircraft. I talked to them to see what size hole was drilled in the center and it was 10mm. Not sure why they did that when usually all the 14 and 15 inch prop holes are around 5-6mm?
I got the 18x8 from Abell RC. They did not have 18x10, only 18x13.
Joe used a piece of Carbon fiber wing tubing to shim the 18x10 he has so it would fit on the 8mm prop shaft. I ordered a 18x10 Turnigy to try also.
Between me and Joe we should have some good numbers by this weekend.
The 18x10 Xoar's are hard to find.
Cory
RC4x4 is online now Find More Posts by RC4x4
Old Oct 13, 2009, 07:34 AM
RC4x4 is online now
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Originally Posted by jadamian75
Can't wait to see it fly on the Rimfire. When are you going to prop it to 2300 watts like the specs say you can? It looks like a good high power motor.
May need a 19 inch prop for that. Don't remember if any were ordered with your HC order or do have one? 2300 watts would be cool. May have to do 7s packs for that .
Cory
Old Oct 13, 2009, 09:05 AM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Thank you Cory!
Have a great day man.
-Buzzed
P.S. Man those Xoar props are hard to find. But they are my fav.
Buzzed is offline Find More Posts by Buzzed
Old Oct 13, 2009, 09:12 AM
Bama3Dr is online now
Find More Posts by Bama3Dr
Bama3Dr's Avatar
Moody, AL
Joined Jan 2006
Originally Posted by Draknkep
And.... are these servos okay for this plane???SteveT
Those look like they should work fine, but they're a little on the slow side at .2 seconds. You'd definitely want to run them at 6V. The price is right though!
Bama3Dr is online now Find More Posts by Bama3Dr
Old Oct 13, 2009, 09:34 AM
Scott Gerber is offline
Find More Posts by Scott Gerber
Account Closed
Joined May 2008
Originally Posted by ronrandle
Finished up my red Slick and if the wind dies down will maiden today.
Y'all know what it looks like but here are a few pics of ESC and mounting. If I had read Scott's post about mounting the ESC underneath I would have done that, but had already fashioned a piece of lite ply with balsa to hold it steady and allow airflow on all sides.
Also created an EPP guard for the protruding bolts for the motor. Maybe unnecessary, but with 8S my batts are on the sides of the battery tray and directly in front of the bolts, if my batts ever get loose they're heading straight for the bolts
Specs:
70" Silck
AUW with batts 9.2 lbs naked (No pants )
8s 3700
CC 85HV
Scorpion 4025-16
Dimension Engineering Sport BEC
4-Hitec 985's
Watts 1985 @ 67 amps Turnigy light electric 18x8
Ron
Ron,
What info did Scott post about mounting the ESC underneath?
Scott
Scott Gerber is offline Find More Posts by Scott Gerber
Old Oct 13, 2009, 09:36 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Cory
I don't have a 19" prop in your order but you can borrow my 19x10 Turnigy electric wood to test. Bring the reamer this weekend and remind me.
jadamian75 is offline Find More Posts by jadamian75
Old Oct 13, 2009, 10:23 AM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Originally Posted by Scott Gerber
Ron,
Scott
Stoops had a post with pics showing the esc mounted on bottom of battery tray with battery leads coming up from bottom. With my two batteries on the sides of the tray, it would have been a very direct route to take for RX connections and power. It also seems that there is a ton of room under the tray for airflow, but being the lazy guy that I am, I didn't re-mount the motor with the leads on the bottom.
Ron
http://www.rcgroups.com/forums/showp...postcount=1325
ronrandle is offline Find More Posts by ronrandle
Old Oct 13, 2009, 11:21 AM
RC4x4 is online now
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
HS-645MG Ultra Torque
Too slow. I've had those before. Go with the HS985MG. Perfect servo.
You don't need digital's and the 985 will be plenty.
Cory
Old Oct 13, 2009, 11:22 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Thanks for replying....as I am not really a 3D flyer (though I'm trying), I would think they will work for me, and yes, on 6 volts.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 13, 2009, 11:25 AM
RC4x4 is online now
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
SteveT
Not 3ding, should be fine.
Old Oct 13, 2009, 05:46 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Hey I know this is not the right forum but, does anyone know how to download airplanes from Knife Edge Software to Real Flight.
gofly
goflyhighrc is offline Find More Posts by goflyhighrc
Old Oct 13, 2009, 06:05 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
gofly
Download from the swap forum to your desktop then use import on RealFlight's file menu.
Fig Jam is offline Find More Posts by Fig Jam
Old Oct 13, 2009, 08:01 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Originally Posted by weaser42
Hey Buzzed, I ran into the same thing with my Xoar's. I found some plastic spacers at Ace hardware which were 10mm OD by I think 6.3mm ID and 15mm long. I used a prop reamer to get the ID up to 8mm and it makes a nice bushing
+1 on this. True Value has the same spacers, they are black, perfect length, and a nice snug fit in the 10mm prop. hole once the I.D. is reamed out to 8mm and the nylon expands a little.
Fliprob17 is offline Find More Posts by Fliprob17
Old Oct 13, 2009, 08:03 PM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
couldn't resist any longer ........Un-packing pics from about a week ago, had my "assistant" look everything over
Old Oct 13, 2009, 08:05 PM
Warbirds Rule is offline
Find More Posts by Warbirds Rule
Warbirds Rule's Avatar
Leesburg, VA
Joined Jun 2006
Hey man, that kid is awfully young to be getting tattoos!
Warbirds Rule is offline Find More Posts by Warbirds Rule
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
