Old Oct 08, 2009, 07:25 AM
JPRC is offline
Find More Posts by JPRC
Support Cancer Research
JPRC's Avatar
Joined May 2007
Originally Posted by Zero3803
I'll take her up again this weekend for you to see.
Sounds good. Sunday works best for me. Send me a text.
JPRC is offline Find More Posts by JPRC
Old Oct 08, 2009, 07:53 AM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Originally Posted by weaser42
I found some nylon spacers at a local Ace hardware today. They are 10mm OD x 6.3mm ID x 15mm length. I used my prop reamer to get the ID to 8mm and it looks like the hub on my 18x10 Xoar is 16mm so the spacer fits nicely at just 1 mm short. I think this will be a great solution but I'll let everyone know if I have any issues next time I fly.
I believe these are the same spacers on Amazon for about 10x cheaper than what I paid Even though the Amazon pics show white they are black in color, not that it matters.
http://www.amazon.com/Metric-Spacer-...971144&sr=8-14
May want to make them a little shorter as they might stop the prop from being fully tightened down. The wood will probably compress a little.
G.P. is offline Find More Posts by G.P.
Old Oct 08, 2009, 08:52 AM
Zero3803 is offline
Find More Posts by Zero3803
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Well I just made a bigtime mistake again. I was checking the voltages of the 6s 5000 packs with my wattmeter. I get to the last pack, and accidentally plug the friggin receiver pack into it.......
Flames shot out the back of the powerpoles and I unplugged them as fast as I could. Voltage check on both packs is fine.....
Pretty frustrating to ruin the rx pack, and possibly a flight pack hours before the maiden. Guess that is postponed now again....
Zero3803 is offline Find More Posts by Zero3803
Old Oct 08, 2009, 08:56 AM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Flames shot out the back of the powerpoles ....
What, no pics?
ronrandle is offline Find More Posts by ronrandle
Old Oct 08, 2009, 09:03 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
get the video camera and do it again.....like no shoes did
cmala is offline Find More Posts by cmala
Old Oct 08, 2009, 09:16 AM
Zero3803 is offline
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
I wish I could be that funny about it.
I'm pretty pissed off right now. I will probably use the 6s 5k again simply because of the rx pack redudancy, but I won't use the tp pack in this bird.
Old Oct 08, 2009, 09:29 AM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
Don't power poles have male/female? Sry I don't want to start a brand war just gathering information.
blakevan is offline Find More Posts by blakevan
Old Oct 08, 2009, 09:44 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
nope.
They have a red and a black. Any connector will plug into any other connector.
David,
Your not the only one to do this. Many people have done the same thing or even worse, plug the 6S pack directly into the receiver. I used the little futaba style connector for my rx battery/regulator for that reason.
Old Oct 08, 2009, 09:49 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I would probably do the same thing as you and get a new rx pack. You can test it to see if it is still ok but you could have weakened one of the connections between the cells and it could fail. It's probably ok but I probably wouldn't trust it as the rx power in the slick either.
You don't have anything else laying around that you can use as a rx pack? NiCads? NiMH? Another 2S LiPo?
If you were closer, I could fix you up....
Old Oct 08, 2009, 09:52 AM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
Good point, I was thinking that 1mm would be enough for any compression but I'll double check when I mount. It's easy enough to shorten and I'm sure there would be no proble having it another mm shorter.
weaser42 is offline Find More Posts by weaser42
Old Oct 08, 2009, 10:00 AM
JPRC is offline
JPRC's Avatar
Joined May 2007
David,
I have a few 2 cell packs that I use in a small heli. You're welcome to them. They don't have power poles on them but I could put some on or you could.
Old Oct 08, 2009, 10:21 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
bring it to the fly in this weekend at hodges well get ya goin
Manta1 is offline Find More Posts by Manta1
Old Oct 08, 2009, 10:22 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
what are you using as a regulator? Can you use something other than a 2S? Something you might have handy?
Old Oct 08, 2009, 10:23 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
dont you have an ice 100 esc? plug it up and go bro
Old Oct 08, 2009, 11:42 AM
Zero3803 is offline
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Got a good deal on one from Atlanta Hobby today. $16.00 for a replacement. The maiden should still be today, but a little later.
We'll see how the 6s 5000 I dorked performs over the next few weeks. I may try it today once I get my new rx pack wired up and charged. It will definitely not be the maiden pack..
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
