Old Oct 07, 2009, 02:03 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
What's the favorit prop for those of you running the 60xl on 6S? And what type of amps are you seeing?
NumbSkull is offline Find More Posts by NumbSkull
Old Oct 07, 2009, 03:02 PM
Bama3Dr is offline
Find More Posts by Bama3Dr
R.I.P. my 70" FB Slick
Bama3Dr's Avatar
Moody, AL
Joined Jan 2006
I'm getting around 82 amps at full throttle with a fresh pack on a Turnigy 17x8 Light Electric Prop, Castle ICE 100amp, and Rhino 6S 4900mah 25C packs. A little over 1800W and very nice pull out of hover all the way through the pack.
Bama3Dr is offline Find More Posts by Bama3Dr
Old Oct 07, 2009, 03:13 PM
Captain Norway is offline
Find More Posts by Captain Norway
Captain Norway's Avatar
United States, TX, Houston
Joined Oct 2007
I removed the extention between the ESC and RX, but the load was still too much for the BEC with the 4 x BLS451.
I will put in the CC BEC Pro tomorrow and give it another go.
The good news is that now it is tested that the BEC will not go up in flames when over-loaded, and as long as you do not have a system that takes long to boot, there is no harm in giving it a try with an untested combo.
So far, the ICE100 BEC works fine with 6s and HS7985.
7s and BLS451, not so much...
Erling
Captain Norway is offline Find More Posts by Captain Norway
Old Oct 07, 2009, 05:32 PM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
I just did a run up for you and i am pulling 87 amps 2090 watts with a 18x8 turnigy prop and turnigy 6s 5000 20c. This setup has lots of puchout.
skippy78 is offline Find More Posts by skippy78
Old Oct 07, 2009, 05:57 PM
Zero3803 is offline
Find More Posts by Zero3803
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Anyone running the CC Bec Pro, what should the led color be when power is plugged in and everything is running normal? If I recall correctly, the original ccbec was green, but this appears to be red?
edit: Nevermind...called Castle and red is A-ok.
Just ran her up for the first time. I didn't bother charging the turnigy 20C (23.22V for the test). Still pulled ~78 amps and nearly 1700 watts.
My heart is still beating faster just from the spool-up. The noise/wind was a rush...
Zero3803 is offline Find More Posts by Zero3803
Old Oct 07, 2009, 06:51 PM
ipsmotors is offline
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
Noah,
I'm right in there with everyone else. 89a on 18x8, 77a on 17x8. I'm flying the 17x8 & happy with the punch & overall performance.
ipsmotors is offline Find More Posts by ipsmotors
Old Oct 07, 2009, 07:01 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
18x8 apc,6s5000,94 amps wot,2200 watts, castle ice 100
v-room
Manta1 is offline Find More Posts by Manta1
Old Oct 07, 2009, 07:42 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
v-room
Which 18x8 prop? I had one from HC and saw 110amps and 2500 watts....WAY TOO MUCH for my combo (same as yours) so propped back down to 17x8.
blakevan is offline Find More Posts by blakevan
Old Oct 07, 2009, 07:49 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
mines apc.bout 94 amp if i remember correctly ill do some more runups this weekend as i had a squeal last weekend.after a few flights,i went to fly half throttle on takeoff,she did the squeal gig just before liftoff
so i havent flown it since.maybe this weekend
Old Oct 07, 2009, 08:24 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
Mine is running just fine,18x8 Zoar ,Hacker 80-X,15 and 20c 5000 Flightmax
ronbo111 is offline Find More Posts by ronbo111
Old Oct 07, 2009, 08:30 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
id like a zoar for mine..
Zero3803 is offline
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Well she's ready to roll. Just finished mounting the bec to the motorbox, and mounting the cowl. I'm planning on doing another charged battery amp/watt check tonight, and then finding the correct cg. Maiden may come tommorow, but that depends on my assessment of the local field. Goldcraft was telling me they've been installing more lights.
I set the CCbec pro (running off TP 2s 1350 pro lite) to 5.5 volts (5.1V default). I may go up to 6.0, but I'm not sure yet. I doubt I'd be able to tell a difference of the 0.5V.
Old Oct 07, 2009, 08:32 PM
Zero3803 is offline
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Looks like EspritModel has (1) 18x8 xoar left.
Old Oct 07, 2009, 08:33 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ive got mine set to 5.5v as well. i like it
wish i had a zoar 18x8,not too crazy about the apc cavitation noise,or whatever it is
thanks Zero! i may see if i can get bill to order me one.i just hope it doesnt squeal anymore..man i hate that noise
Old Oct 07, 2009, 08:38 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
Isn't that the noise where the Decapitated persons head hits the basket?
Oops, I've been reading stories about the Dark Ages again...
Jorge61
refugeefromcalif is offline Find More Posts by refugeefromcalif
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 07:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 08:31 AM
