Old Oct 05, 2009, 05:27 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
I've been wondering how the Ice controllers will hold up.
I couldn't figure out why a newer line of controllers, with (what should be) a better BEC is less then the old line of Phoenix controllers. Looking at Tower, the PH80 is still $10 or $20 more than the Ice.
I'm thinking of buying the Ice cause its cheaper, and just using an Ultimate BEC that I have on hand....
NumbSkull is offline Find More Posts by NumbSkull
Old Oct 05, 2009, 05:43 PM
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
Originally Posted by Tipover
I got my oldest one this spring from the LHS, came with my DX7. Should be fine unless it was an old stock set, I doubt that.
Kevin
Just power cycle the RX (while leaving the TX on) and if it comes back blinking on both main box and satellite with instant control returned then you have v1.6.
brucewsb is offline Find More Posts by brucewsb
Old Oct 05, 2009, 09:23 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Real quick note on the Hacker X-80-OPTO Pro 3D ESC. If anyone is planning on, or has tried using the X-Link USB cable & software for programming, the OPTO version ESC's require a main flight pack to be connected to the ESC prior to connecting the ESC to the USB cable. Otherwise the software and USB interface won't recognize the ESC and you can't program anything.
Fliprob17 is offline Find More Posts by Fliprob17
Old Oct 06, 2009, 04:13 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Checking in from the road guys (on a 10 day cross country vacation ).
Here's a relatively simple way to install the Neu setup for those interested. Basically, just drill / enlarge the hole to allow the motor to fit (but not too large as to allow you to still drill the four supporting hole.
Then you mount the Neu on an aluminum plate (I just modded one of my other motor's X mount for this purpose)
Also measure out how long your mount needs to be.
Use an appropriate length nylon washer and rods found at Lowe's, and you're set
BoneDoc is offline Find More Posts by BoneDoc
Old Oct 06, 2009, 06:19 AM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Simple and elegant, nice install Josh
Fig Jam is offline Find More Posts by Fig Jam
Old Oct 06, 2009, 08:15 AM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
What did you do about the thrust angle !!
goflyhighrc is offline Find More Posts by goflyhighrc
Old Oct 06, 2009, 08:26 AM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
Looks like the thrust angle wouldn't change because he mounted it against the existing firewall.
blakevan is offline Find More Posts by blakevan
Old Oct 06, 2009, 08:35 AM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Well done Josh, simple and solid. Had you thought about using bolts instead of threaded rod? I'm a little concerned that I can't torque threaded rod as well as I can a bolt.
Ron
ronrandle is offline Find More Posts by ronrandle
Old Oct 06, 2009, 08:47 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Nice job Josh. Very clean and simple. Now, we need someone to produce that front plate in CF.
Goflyhighrc - As answered above, thrust angle is set by the firewall. Josh has mounted his motor to the firewall. Therefore, his motor is pointing at the correct thrust angle.
blucor basher is offline Find More Posts by blucor basher
Old Oct 06, 2009, 08:52 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
that is neat. does that motor have a gearbox built into it?or are they mounted on the side of those motors when they have gearboxes..you guys are gonna make me try one of these.they seem to be gettin popular....when in Rome...
Manta1 is offline Find More Posts by Manta1
Old Oct 06, 2009, 08:54 AM
ipsmotors is offline
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
Manta,
That's a P32 planetary gear box on the end of the motor. It works just like the planetaries in an auto trans.
ipsmotors is offline Find More Posts by ipsmotors
Old Oct 06, 2009, 08:58 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by ipsmotors
Manta,
wow!compact lil buggar aint it? im guessing with the gear reduction you get more power/rpms/torque with less amp draw/power from batts,less heat buildup?
Old Oct 06, 2009, 09:19 AM
3DHS Junkie
Joined Nov 2007
Just like anything we put in our planes, there are things to consider.
Ease of use, weight, performance, reliability, service, etc.
Comparing our 89" Slicks, Josh gets longer flight times than I do.
I haven't noticed a difference in heat.
Mine makes more watts but my GR70 & Spin are heavier.
Noah's (Numbskull) 89 has crazy power with a 1527 Neu.
We never did get them all together & drag race maybe FYI 2010?
Old Oct 06, 2009, 09:21 AM
Joined Jun 2003
I still like this idea of giant-scale vertical drag racing. Under the lights. Would be cool.
Old Oct 06, 2009, 09:33 AM
3DHS Junkie
Joined Nov 2007
I'm in!
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
