Old Aug 27, 2009, 09:01 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
3D Hobby Shop 71" AJ Slick - Build & Fly thread
Newly updated:
OK, here they are. Per Ben from 3DHS
The new 25% AJ slicks measure 71" WS x 70" Long with 1012 sq. inches of wing area.
I think every single customer request ever made about the 70" Slick has been addressed:
The 71" Slick featured a carbon-carbon reinforced landing gear plate assembly with carbon tube fuselage stiffeners and heavy-duty fasteners.
The 71" Slick features 3" diameter main wheels.
The 71" Slick retains the pre-hinged and gap-sealed ailerons, but the tail hinges are no longer glued to allow them to be changed if desired by the builder (different brand, or do custom work like removable rudder).
The 71" Slick electric retains the extra-long hatch and cowl cutout for easy battery placement.
Carbon wing tube, carbon main gear, and carbon tail wheel are included.
A vinyl decal package featuring outline-vinyl graphics is included.
"AJ Design" mylar decal sheet and AJ throwmeter included.
Wing bags included.
All ball link/phenolic hardware.
AND. We are now building these aircraft at a new facility which is allowing us to raise the wood quality a bit, do a slightly better job overall...and offer the 71" in either color scheme for $389.99 plus shipping for now.
They are going live now, and are in stock now. The 71" uses exactly the same components as the 70" Slick, and flies essentially the same, which is to say just about perfectly.
BUILD VIDEOS
Another fine work by IPSMotors
3D Hobby Shop 70" AJ Slick Build Video #1 (6 min 24 sec)
3D Hobby Shop 70" AJ Slick Build Video #2 (6 min 44 sec)
3D Hobby Shop 70" AJ Slick Build Video #3 (7 min 15 sec)
3D Hobby Shop 70" AJ Slick Build Video #4 (6 min 27 sec)
3D Hobby Shop 70" AJ Slick Build Video #5 (4 min 41 sec)
VIDEO
70 AJ Slick Video #1 - AJ Uncut
70slick03 (4 min 38 sec)
70 AJ Slick Video #2 - 2009 IMAC Sportsman Sequence
70 AJ Slick Video #3 - First Huck
Component weight in grams / oz
Bare fuselage 767 / 26.4
Hatch 190 / 6.6
Cowl 142 / 4.9
rudder 70 / 2.4
Wing tube 54 / 1.9
Hstab+elev+joiner 193 / 6.7
Wheel pant 35 / 1.2
Carbon main gear 86 / 3.0
Wing, hinged w/ aileron 390 / 13.4
Tailwheel assembly 23 / 0.8
Parts List Added Courtesy of Matt (DaLoaf)
SLICK COCKPIT (Thanks to GP!!)
http://www.3dhobbyshop.com/assets/im...kpit_pilot.jpg
http://www.3dhobbyshop.com/assets/im...-corrected.jpg
http://www.3dhobbyshop.com/assets/im..._dashboard.jpg
http://www.3dhobbyshop.com/assets/im...ck_headest.jpg
BoneDoc is offline Find More Posts by BoneDoc
Old Aug 27, 2009, 09:02 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Note: We have made a few changes to the kit since IPS did the build videos. These few changes are reflected in the "build thread" posts below.
Instruction manual:
The 70" Slick manual is available for download as a .pdf file below.
NOTE about servo arms:
Make sure that your ball links do not contact your servo arms as they travel. We want to have smooth action and low servo-current draw. As pictured below, when using stock Hitec GRP servo arms, one way to do this is to cut or sand away the corner of the arm as shown.
Photo of Fantasy Blue:
Below is also a photo of the Fantasy blue color scheme on the 70" Slick, a 51" Slick is shown in the photo for size comparison.
Video added:
First video of Blue scheme added below. Setup:
Reaper GR60-XL
Xoar 18x8
Castle Hv-85
Turnigy 6S 5000mah 15C
70RBSlick01HQ (4 min 59 sec)
SPARE PARTS LIST
Canopy Hatch - Blue http://www.3dhobbyshop.com/detail.aspx?ID=2517
Canopy Hatch - Red http://www.3dhobbyshop.com/detail.aspx?ID=2518
Cowl - Blue http://www.3dhobbyshop.com/detail.aspx?ID=2515
Cowl - Red http://www.3dhobbyshop.com/detail.aspx?ID=2516
Motor box http://www.3dhobbyshop.com/detail.aspx?ID=2524
Wing spar tube http://www.3dhobbyshop.com/detail.aspx?ID=2522
Landing Gear http://www.3dhobbyshop.com/detail.aspx?ID=2519
Pants Red/White http://www.3dhobbyshop.com/detail.aspx?ID=2521
Pants Yellow http://www.3dhobbyshop.com/detail.aspx?ID=2520
Tailwheel assem. http://www.3dhobbyshop.com/detail.aspx?ID=2523
Main Wheels http://www.3dhobbyshop.com/detail.aspx?ID=2525
blucor basher is offline Find More Posts by blucor basher
Old Aug 27, 2009, 09:03 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
More info to come
Joined Jun 2003
70 Build Thread pt. 2
The 70" Slick uses pin-style hinges.
The wing hinges are glued, gap-sealed and finished.
The tail hinges are unglued. On these hinges, we recommend the use of vasoline on the center rotating portion to keep your glue from making the hinge sticky. When hinging the tail, you can use hinge glue, polyurethane glue (gorilla or sumo), or 30-minute epoxy glue. For epoxy or polyurethane, use alcohol for cleanup. Note that polyurethane will bubble up out of the hinge for approx 30-45 miunutes and you will need to clean off the excess a few times with alcohol.
The control hardware on the 70" slick uses allen-screws and self-locking nuts to attach the ball links to arms and horns.
As pictured below, there is a rear-rudder servo option, for pilots who opt for heavy power systems. Space is tight for this install, and so the pushrod attaches to the inside of the servo arm, and a spacer may be needed between the ball link and the arm if you are using an arm with a tall installed height. Do whatever it takes to keep the pushrod from contacting the elevator at full throw.
Old Aug 27, 2009, 09:04 PM
Joined Jun 2003
70" Slick build thread pt. 3
Hstab and elevators.
Cut out the holes in the fuslage covering as shown. Slide the horiztonal stab into its slot. Align side to side with a ruler. Temporarily install wing tube and wings onto fuse and measure form the Hstab tips to the rear aileron tips, equalize this dimension to make sure stab is perfectly aligned (illustration coming).
Drip thin Ca glue onto the Hstab-to-fuselage joint. Again, we DO NOT remove any covering from the Hstab. Thin CA binds very well to both covering and wood. Allow to dry. Clean up any leakage with Ca debonder.
Install the hinge points on the elevators in the same manner as on the rudder.
Install the elevator with the joiner-rod first. Put some thick CA, polyurethane, or epoxy into the joiner slot on the other elevator before installing it. NOTE: the joiner slot is TIGHT. Trial fit once before doing it for real.
Install elevator servo, horn, and linkage as shown. If you use a very heavy power system, you can use a second elevator servo, this system can be done a second time on the other side, everything is mirror-image and the hardware is included. Our test aircraft use ONE elevator servo and we fly them hard.
Joined Jun 2003
70" Slick build thread pt. 4
The aileron installation is very simple.
Cut out the covering over the servo hole and the control horn slots as shown.
Use epoxy or polyurethane to glue the horn in, just as on the rudder and elevator.
Install the servo, using the pull-string inside the wing to pull the wire through.
Assemble and install the pushrod as shown, using the allen-screws and nylon locknuts. Check for free motion, and make sure the ball-link is not rubbing the servo arm. Cut away servo arm as needed.
Old Aug 27, 2009, 09:06 PM
Joined Jun 2003
Reserved 6
Old Aug 27, 2009, 09:28 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
Reserved 7
gwh is offline Find More Posts by gwh
Old Aug 27, 2009, 09:35 PM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Hey Ben took all the front row seats. LOL
jadamian75 is offline Find More Posts by jadamian75
Old Aug 28, 2009, 12:00 AM
JClark is offline
Find More Posts by JClark
Check Your Bolts!!
JClark's Avatar
Grove, Ok
Joined Feb 2005
I just got off the phone with him a while ago and know what motor is going in one. It is going to be off the hook.
JClark is offline Find More Posts by JClark
Old Aug 28, 2009, 02:15 AM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I just ordered my CC Pro BEC, so all I have left to pick up is the motor spacers and I'm done buying stuff for the Slick. Now its time to start collecting parts all over again for the big Vyper.
Matt
Daloaf is offline Find More Posts by Daloaf
Old Aug 28, 2009, 02:30 AM
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
I just measured my Scorpion S4025-12 and got 78mm from back of x-plate to seat of prop adapter. Looks like I won't need any spacers.
brucewsb is offline Find More Posts by brucewsb
Old Aug 28, 2009, 05:50 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Here's a relatively simple way to install the Neu setup for those interested. Basically, just drill / enlarge the hole to allow the motor to fit (but not too large as to allow you to still drill the four supporting hole.
Then you mount the Neu on an aluminum plate (I just modded one of my other motor's X mount for this purpose)
Also measure out how long your mount needs to be.
Use an appropriate length nylon washer and rods found at Lowe's, and you're set
Old Aug 28, 2009, 07:59 AM
rctc is online now
Find More Posts by rctc
RCTC
USA, MI, Traverse City
Joined Feb 2005
I like the videos
great job on the video's showing the how to put the slick together.
Very helpfull
rctc is online now Find More Posts by rctc
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
