Old Aug 26, 2009, 11:38 PM
hacker002 is offline
Find More Posts by hacker002
thE hACkeR
hacker002's Avatar
United States, IL, Chicago
Joined Apr 2009
Question
how to connect and charge a lipo battery park? my fist time!
hi, am new to this and need a lot of help with this things. i have read and study about lipo batteries. so i know almost all about the don't and do's.
im going to charge my first lipo battery pack in my life and want to make sure that am doing correct. and what is the correct order to connect it.
am going to used the Electricfly Triton EQ that charger, discharger, cycler, balancer.
charging a common sence 11.1v 1650mAh
what i want to know of how do i start. like do a turn on first the charger and then connect the battery and then program the charger or first plug the battery and then turn on the charger.......???????
please!!!!!! someone that can help me i will THANK YOU SO MUCH ('o')
hacker002 is offline Find More Posts by hacker002
Old Aug 26, 2009, 11:42 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
http://www.rcgroups.com/forums/showthread.php?t=1101807
mrforsyth is offline Find More Posts by mrforsyth
Old Aug 27, 2009, 01:35 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Turn the charger on, and from there, you can plug the battery in. Doesn't matter if you plug it in before programming, or after
Xpress.. is offline Find More Posts by Xpress..
Old Aug 27, 2009, 11:42 AM
thE hACkeR
hacker002's Avatar
Joined Apr 2009
thanks Xpress, with try that why, will see what happens.
also do i plug first the balance cable and then main plug?
Old Aug 27, 2009, 11:47 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Really does not matter since there is no power coming out of the charger leads until you start the charging process.
freechip is offline Find More Posts by freechip
Discussion At how many amps should i charge this lipo battery? bretd123 3D Flying 2 Apr 05, 2008 02:54 PM
Discussion how long do i charge stock HBFP battery? hockmasm Micro Helis 14 Dec 29, 2007 10:54 PM
Question how low can you discharge a lipo battery? taekwondo Batteries and Chargers 22 Aug 07, 2006 08:15 PM
How often do you discharge a lipo battery? jbflier Batteries and Chargers 5 Mar 01, 2005 05:53 AM
Charge two Lipo Packs at the same time? Jeffro Batteries and Chargers 5 May 15, 2004 06:02 PM
