Aug 26, 2009, 12:53 PM
Delaware
Joined Jan 2004
(SOLD)Brushless ESC New in Package 60A Speed Controller
For Sale - Brushless ESC New in Package
Brushless ESC
I have a Sky-Wing, Hobby-Wing (Mystery) Brushless ESC New in Package I can sell you $30 Shipped U.S. Only Thanks,Rick
Specs
Sky-W RC 60A Brushlessmotor Speed Controller ESC
Product Code SW - 60A
Constant Current 60A
Input Volt 6 - 30V (2-8 LIPO / 4 - 25 NIMH)
Max Current 70A
BEC Output Current 3.0A
Low-Voltage Cutoff Auto detect and set
Size(mm) 56.5*35.1*13mm
Each Unit Weights(g) 48.2 g
Unit Dimensions(mm) 90*145*25mm
Advantage of
the MYSTERY Speed Controller
•Low resistence
•High rate PWM
•User programmable brake
•Low voltage auto setting based on battery
•Throttle range self-adjusting
•Soft start ramp up
•Runs motor in forward or reverse
•Auto motor cutoff with reset
•Safe power arming program ensures motor will not run accidentally after turn on
•Low torque start
•Auto shut down when signal is lost
Reason: sold
