Old Aug 26, 2009, 05:03 AM
marell01 is offline
Find More Posts by marell01
marell01's Avatar
Sweden
Joined May 2006
Data
90mm fan, Mega 22/20/3 6cell = 1750 watt!!!! what do you EDF gurus think?
Hi all,
Yesterday I downloaded data from my eLogger V3. Motor had only been run a couple of tests to check for vibration. No full speed more than 1 second.
The fan is mounted inside my model and the data that came out was like this:
Motor Mega 22/20/3
DesirePower 6cell 4900 mAh
Jeti Spin 75, lowest timing, soft start
Max 81A
Max 1751 watt
Volts 21.4
Max 27700 rpm
Hmm Do you think this will be good for a 2100-2200 gram model
Sincerely Marcus
Picture 1 from eLogger
Picture 2 from eLogger
marell01 is offline Find More Posts by marell01
Old Aug 26, 2009, 07:17 AM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
Marcus, That Jeti spin 75 is too small for this setup. I have one of these in a pattern plane. Last week on my third flight the power cut out and the Jeti spin 75 would not re-arm until after the dead stick landing. I had the spin box with me and the error message revealed the cut out had occured because of an over amp of 83amps and a max temp of 53 degrees C. This happend about 3 min into the flight, I had plenty of battery left. The speed control is well vented in this airframe and OAT was about 25degrees C. Lucky I did not loose the model. I knew I was marginal with this speed control in this model and I do not want to loose it. So, I am replacing it with a Castle Creations Phoenix Ice 100. Just my opinion!
Dave.
172AMD is offline Find More Posts by 172AMD
Old Aug 26, 2009, 08:02 AM
carl rich is offline
Find More Posts by carl rich
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
You'll have enough power for a 2200 gram model but those packs are quite large. For review stuff I've tried the new 3250mAh 40C ThunderPowers in a jet at 95A. Run great and not overheating though I do not fly WOT the whole flight. They also hold voltage extremely well. I'll 2nd the Jeti info. Use Spin Box and set temp cut off at the highest setting of 100C and make sure tons of airflow. You MAY get away w/ current but maybe not. I'd consider stepping up to larger ESC.
carl rich is offline Find More Posts by carl rich
Old Aug 26, 2009, 03:03 PM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Thank you guys... Problem is, its allready mounted behind the motor in the exit-duct. Tough to get hands on :-(
I decided to use this ESC when we did the first testings. Back then I only did reach ~70Amps. I didnt have as good batteries then as I have today, thats wy the amp-draw is so much higher...
I do have a hextronic 120amp ESC laying around, problem is as mentioned to get it in...
Please visit my build log
Sincerely
Marcus
Old Aug 26, 2009, 03:17 PM
WeMoTec is offline
Find More Posts by WeMoTec
Willich / Germany
Joined Nov 1998
The motor is for 5s Lipo max.!
6s is over the top and I doubt the motor will last more than a couple flights.
Before you change the sped controller I would go back to 5s and a lighter battery.
You will still have plenty of power for a then about 2000g model.
Oliver
WeMoTec is offline Find More Posts by WeMoTec
Old Aug 26, 2009, 03:56 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
No need to bump everything up to help in killing the motor! lol Just drop a cell and your done changing any parts and it'll go plenty!!!
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Aug 26, 2009, 04:20 PM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
hmm I have to correct myself, the fan is actually Haoye Midisize with 7 blades. Maybe just change for a WEMOTEC rotor would be the ticket..
Sorry for bumping.
//Marcus
Old Aug 26, 2009, 06:09 PM
Joined Aug 2002
thats couldnt hurt! hehe At 3kw that fan depsite it's thrusty appearance is actually inefficient enough that at 3kw for example, you will have 1 pound less thrust than a midi. But all those rotors have the same %30 inefficiency as the original sized rotor it was copied from which is the Vio rotor.
Barry
Old Aug 26, 2009, 06:26 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I'm with Oliver, except I don't think the motor would last even one whole flight. I had a 22-30 overheat on less power.
I'd say get a bigger motor for sure. Very nice construction on your plane though! That type of construction is getting rare.
Steve C
Steve C is offline Find More Posts by Steve C
Old Aug 26, 2009, 06:46 PM
Joined Aug 2002
check out his vid too, thing flies like a dream, proof is it's a 90mm hand launcher!!!!
Barry
Old Aug 27, 2009, 06:25 AM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Barry
Hi Barry,
The prototype has made 2 flights. Videos in my thread. The proto has a mega 22/20/2E (Kv 2250) on 4 cell 2500mAh battery. It managed ca 718W @ 54 A, thrust 1500 gram. AUW was 1650 gram.
My build will end at somewhat around 2200 gram AUW.
I really appreciate all your time and effort to get us less informed how to set-up these demanding EDFs.
Sincereley Marcus
Old Aug 30, 2009, 02:26 PM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Made another test today.
Battery fully charged, but charged yesterday...
Ive attached the eLogger file.
Temp A = Motor
Temp B = ESC
Temp C = Not connected
I think Ill go for a 5 cell setup to be safe. Ill order a 4 cell tomorrow. Ill then split the 4 cell into 2 x 2cell and the sixpack into 2 x 3 cell packs. Then Ive the options of going 4,5 and 6 cell setup in different planes.
JA 37 006 (1 min 46 sec)
Sincerely
Marcus
Old Aug 31, 2009, 12:24 PM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Some other questions.
Timing, shall I go with Low, medium or high?
Freq: 8kHz or 32 kHz?
All on the Spin ESC.
Sincerely
Marcus
Old Sep 12, 2009, 06:40 AM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
anyone?
Old Sep 12, 2009, 07:03 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
mega 16/15/3 needs 25 degree timing on 4s according Jepe.
hope this might be usefull for you
good luck!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Midifan, Mega 22/20/3 mmormota Electric Ducted Fan Jet Talk 2 Dec 13, 2005 02:36 PM
mega 22/20/3 +k40 +insurd ship'g =$180 Andrew Gilchrist Aircraft - Electric - Airplanes (FS/W) 0 Mar 11, 2002 09:41 PM
Mega 22/20/3........Wow! Eco8gator Electric Heli Talk 0 Mar 03, 2002 02:08 PM
I dedided to get the Mega 22/20/3 Eco8gator Electric Heli Talk 4 Mar 01, 2002 11:19 PM
Mega 22/20/3 versus 22/30/3? Jon Baker Scale Kit/Scratch Built 2 Oct 09, 2001 08:26 PM
