Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Sep 16, 2009, 04:58 PM   #46
Rudder time
  • Name: Picture build thread 001.jpg
Description: Rudder post with sections of plastic tube glued  in slot , centre of post, between holes. Wire is in tube for allignment before gluing Rudder post with sections of plastic tube glued in slot , centre of post, between holes. Wire is in tube for allignment before gluing 20.7 KB · Views: 97
  • Name: Picture build thread 002.jpg
Description: Robart pin hinge with hinge part cut off and 1/32" hole drilled in shank. Robart pin hinge with hinge part cut off and 1/32" hole drilled in shank. 30.4 KB · Views: 79
  • Name: Picture build thread 004.jpg
Description: Rudder post with hinges in place. Rudder post with hinges in place. 18.1 KB · Views: 95
  • Name: Picture build thread 015.jpg
Description: !/32" music wire glued to TE as a stiffener. !/32" music wire glued to TE as a stiffener. 24.4 KB · Views: 112
  • Name: Picture build thread 006.jpg
Description: Determine overall width of panel needed, tape to framework and follow photo 6 Determine overall width of panel needed, tape to framework and follow photo 6 21.6 KB · Views: 84
  • Name: Picture build thread 005.jpg
Description: Trace rib positions on back or inside of panel. remove and draw gusset size and location on panel then cut out with scissors. Trace rib positions on back or inside of panel. remove and draw gusset size and location on panel then cut out with scissors. 22.4 KB · Views: 91
  • Name: Picture build thread 007.jpg
Description: Custom fit and cut panel attached. Do same for other side. Custom fit and cut panel attached. Do same for other side. 22.2 KB · Views: 85
  • Name: Picture build thread 008.jpg
Description: Completed rudder with cap strips etc. Weight under two oz. Completed rudder with cap strips etc. Weight under two oz. 20.9 KB · Views: 92
  • Name: Picture build thread 009.jpg
Description: Fin LE fill in painted silver. All photos I have show a light colour. If anyone can correct me please do. I think I will end up with white(I told you I'm not a scale purist) Fin LE fill in painted silver. All photos I have show a light colour. If anyone can correct me please do. I think I will end up with white(I told you I'm not a scale purist) 31.8 KB · Views: 131
  • Name: Picture build thread 012.jpg
Description: It's beginning to look a lot like a glider. It's beginning to look a lot like a glider. 24.7 KB · Views: 115
  • Name: Picture build thread 013.jpg
  • Name: Picture build thread 010.jpg
Fred China is offline Find More Posts by Fred China   Reply With Quote
Old Sep 16, 2009, 05:08 PM   #47
Fred, are you using only one half of the Robart hinge pin to make a removable rudder? Does the long rudder pin ride in a tube?
Steve
SteveR is offline Find More Posts by SteveR   Reply With Quote
Old Sep 16, 2009, 05:32 PM   #48
SB-28 UK Display Pilot
GeeW's Avatar
Fred
The full size Gull that I used to help rig had a light blue fuselage with blue leading edges and white on the open structure.
From memory the blue was "Ford Olympic Blue"
Gordon
GeeW is offline Find More Posts by GeeW   Reply With Quote
Old Sep 16, 2009, 05:38 PM   #49
Steve
How does this happen I press submit and I already have your question. Ghosts
Yes I cut the hinge in half and also remove the little flanges. I do this with the small and the large. There is a small one at the top of the rudder because there wasn't enough room for a large pin. Yes the 1/32" Music wire is the axle inside the small plastic tube. This is all assembled with the pins protruding from the rudder and then is glued into appropriate holes drilled in the fin post. Once the glue has dried(epoxy) the pin or wire can be removed and the pins stay in the fin post in perfect allignment.
Fred
Old Sep 16, 2009, 05:43 PM   #50
Gordon
Thanks , but I am going to give this a varnish finish and I'm thinking of copying the Derby and Lancs club gull with the old canopy, BGA 378 with the blue and white stripes on the rudder.
Fred
Old Sep 17, 2009, 05:23 AM   #51
The master class continues!
All great stuff Fred, and thanks so much for your effort.
I guess you'll already have checked out the Gull on the scalesoaring website:
http://www.scalesoaring.co.uk/VINTAG...ype12_Gull.htm
Rog
Sutton Bank is offline Find More Posts by Sutton Bank   Reply With Quote
Old Sep 17, 2009, 04:37 PM   #52
Rog
Yes I have. Unfortunately, just about all the pictures or photos of the Gull are in black and white.
If anyone can tell me what shade of blue is on the rudder of the Derby and Lancs Gull or for that matter, if they continue the trend, on their present gliders, I would appreciate it. Or is the Club still in existence?
Thanks Fred
Old Sep 17, 2009, 06:42 PM   #53
Landing skid
Description: Middle screw offset to help prevent splitting one side only. Other side would conflict with tow release also may help prevent splitting skid on groundloop landing. Middle screw offset to help prevent splitting one side only. Other side would conflict with tow release also may help prevent splitting skid on groundloop landing. 19.3 KB · Views: 101
Description: Rear screw in slot to assist cushioning in landing. Rear screw in slot to assist cushioning in landing. 18.6 KB · Views: 79
Description: Rubber pipe shock tube is washered and screwed into fuselage. Skid is held to tubing with a small 4/40 countersunk bolt and blind nut inside tubing. Rubber pipe shock tube is washered and screwed into fuselage. Skid is held to tubing with a small 4/40 countersunk bolt and blind nut inside tubing. 14.7 KB · Views: 90
  • Name: Picture build thread 003.jpg
Description: I have found that if not held fore aft and in the middle the skid is prone to damage with a bad landing, of which I have done many. I have found that if not held fore aft and in the middle the skid is prone to damage with a bad landing, of which I have done many. 19.8 KB · Views: 101
Old Sep 18, 2009, 02:36 AM   #54
Hi Fred,
Are you building in time with your posts, I am really enjoying this thread, you are a craftsman of note. I am almost convinced to build a wooden glider next and hang up my latex gloves.
Regards
mikegbogh is offline Find More Posts by mikegbogh   Reply With Quote
Old Sep 18, 2009, 11:31 AM   #55
Yes I am.
The hobby to me is mostly in the building.
Fred
Old Sep 18, 2009, 12:54 PM   #56
Fred and Mike
More like an artist.
Tailspin Tommy is offline Find More Posts by Tailspin Tommy   Reply With Quote
Old Sep 19, 2009, 01:10 AM   #57
Vintage wood is the best!
Gold Member
SZD16's Avatar
Originally Posted by Fred China
Yes I am.
Fred
Don't you know it......don't get me wrong...I love to fly...but spending time in the shop cutting and fitting and figuring out how to make it all work is why I scratch build vintage wood airframes.
SZD16 is offline Find More Posts by SZD16   Reply With Quote
Old Sep 19, 2009, 07:59 AM   #58
So true, so true. I just wish I had enough original scale vintage sailplanes built to say so.
A truly interesting and yet, one for the truth kinda conversation I have had with an established F3B flier here in Japan.
Him: A soarhead like you with a mind set for thermal flying. How come you arent flying F3B.
Me: 'Cause I want to BUILD my own planes.
Him: Silence. A bit each of surprise, shame and embarrassment on his face. AND!!! not to forget, AND!!! must not be left out, NO!!!!! a true expression of understanding on his face.
We ALL Enjoy model airplanes. ARFs are the last realistic resort. Building RULE!!!!
suirendoujin is offline Find More Posts by suirendoujin   Reply With Quote
Old Sep 19, 2009, 01:55 PM   #59
Lemaquettiste's Avatar
Hi Fred,
Very beautiful building, congratulation, very clean as usually.
I am happy to see your building in progress on a forum. For me, you are one of the best builder of oldtimer in USA
Vincent
Lemaquettiste is offline Find More Posts by Lemaquettiste   Reply With Quote
Old Sep 20, 2009, 11:30 AM   #60
Fred, a question on your skid shock mounts. Are you first mounting the bits of rubber tubing to the fuselage lower keel with small wood screws? I assume two so it won't rotate and to make it easier to reach inside the tubing with the screwdriver tip, then mount the skid to tubing with a bolt and nut to make the shocks functional?
It seems to me a single screw all the way through would have the possibility of breaking out without this method and curious as to how you solve this.
Tom
mmartin55 is offline Find More Posts by mmartin55   Reply With Quote
Bored? Want to fight?
Join the RCGroups clan!
