Almost ready... Wingeron and elevator servos installed. Just need to know what the insident should be and glue on the tail. Once I have her balanced, then I'll detail out the fuse and wings. Should I avoid using my Spektrum 2.4 because of the carbon fiber I have laid up as fuse doublers and the carbon fiber wings, or is it good enough to just move the Rx further back past the carbon???
Dominic, Please don't take this wrong, but I've bagged literally hundreds of panels and with my system, anything over 7 will deform the foam. It may not crush it flat, but there will be signs of deformation. If you check ACP and CST's cheap bagging systems, they are set to 6-7"hg for that very reason.
As for bagging fabrics, I'd agree with you. You need to have enough vacuum to suck the cloth flat. Using mylar even at low pressure would give him a smooth, non-fabric-showing finish. I use 7" for white foam and all I can get on pink, blue or spyder foam. With the new pump I just bought I can run a dozen bags and get 23"hg w/o breaking a sweat. Funny though, I had to add another bleed valve since my pump was so strong it was providing 9" with one 1/8" bleed valve open fully. I had to put a dedicated 1/4" bleed line that is removed when I bag white foam. George |
You should be OK with the RX moved back. You can always put whiskers on it to be on the safe side. Make them so 31-32mm is sticking out of the plane. The extra length inside the fuse doesn't matter. Also, you don't need to solder anything. Just lay the new longer wire over the original antenna and use some heat shrink tubing to keep them together. You can put a drop of CA on the 2 wires if you want.
George |
We (the competitive RC sailplane bunch) have had problems with 2.4 in our carbon infested fuselages. What we've ended up doing while waiting for the manufacturers to catch up is to make whiskers. You see, the carbon in the fuse is blocking the signal, so we make a longer antenna from each antenna on the main RX and satillite RX and put them 90 degrees around the fuse. One out the top and bottom and one out each side. You only need to have 31-32mm sticking out of the fuse. The carbon blocks out the rest of the signal. Now, if your fuse isn't completely carbon, you will probably get it to work w/o making whiskers or even have to have the existing antennae exit the fuse.
JR has already come out with a 2.4 RX that has a long antenna on it and the aircraft manufacturers are now leaving the carbon out of the fuses from the back of the canopy forward so we can use 2.4gHz RX's without having holes and wires sticking out of our expensive models. Some of us are going so far as to go back to 72mhz in our competiton planes. We are actually doubling the length of the standard antenna and leave the extra hang out in the breeze. The antenna is routed up the fin and the extra roughly 12" (depends on the length fuse you have of course) hanging out. It looks stupid, but so does crashing a $2000 model. George |
| Thread Tools | |
| Mini Tornado Build Questions | HavingFun2002 | Foamies (Kits) | 4 | Apr 08, 2002 11:16 PM |
| U2 Glider Conversion Scratch Build Questions | cactus | Electric Sailplanes | 6 | Feb 14, 2002 07:10 AM |
| JK Aerotek Zero build questions | psbowen | Foamies (Kits) | 2 | Feb 02, 2002 10:17 AM |
| Voyager Build Questions...I'm Pulling My Hair Out | jimmyG | Electric Heli Talk | 18 | Jan 18, 2002 02:38 PM |
| Build Questions for a HL Mini Tornado | jah | Foamies (Kits) | 21 | Jan 14, 2002 12:13 PM |
