Old Aug 28, 2009, 07:43 PM
Greygoosegregg is offline
Find More Posts by Greygoosegregg
Greygoosegregg's Avatar
United States, CA, Simi Valley
Joined Feb 2008
According to the pump I have, 5 X 10-4 Torr is = to -29.36psi. I don't know, but that is what the pump data sheet claims...
Rotary Vane Pumps
Two Stage
5 X 10-4 Torr
0.5 Microns
800 litres/min.
28 CFM
48 m3/hour
Rotary Vane Pumps
Two Stage
5 X 10-4 Torr
0.5 Microns
200 litres/min.
7 CFM
12 m3/hour
3.5 CFM 7 CFM
21 CFM 28 CFM
Greygoosegregg is offline Find More Posts by Greygoosegregg
Old Aug 28, 2009, 07:59 PM
Frank Jarratt is offline
Find More Posts by Frank Jarratt
Wichita Falls, TX
Joined Oct 2005
Originally Posted by flyonline
after balancing the wings so that the CG of the WING is just ahead/on top of the pivot point you rebalance the entire PLANE so that it has the original CG before balancing the wings.
I had just assumed that the wing should pivot at the computed Neutral Point of the airframe. I had not considered that the mass of the wing, which depends how the wing is built, could affect the final placement.
Thank you.
Frank
Frank Jarratt is offline Find More Posts by Frank Jarratt
Old Aug 28, 2009, 08:01 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Rotary Vane Pumps
Two Stage
5 X 10-4 Torr
0.5 Microns
800 litres/min.
28 CFM
48 m3/hour
Rotary Vane Pumps
Two Stage
5 X 10-4 Torr
0.5 Microns
200 litres/min.
7 CFM
12 m3/hour
3.5 CFM 7 CFM
21 CFM 28 CFM
Vacuum Conversion Chart
wyowindworks is offline Find More Posts by wyowindworks
Old Aug 28, 2009, 08:03 PM
Joined Feb 2008
Ahhh.... I see. I did not understand until just now. Read up on the perfect vacuum. Like I said, first time. lol
Old Aug 28, 2009, 08:08 PM
Joined Feb 2008
Anyway, I didn't even come close to that at 4 psi. Thanks of the lesson wyowindworks.
Old Aug 28, 2009, 08:25 PM
Just fly it!
Cody, WY
Joined Nov 2007
I used to get them all mixed up too. I used to call them "atmospheres" which is psychotically off.
Adam
Old Aug 28, 2009, 11:23 PM
screamin' eagle is offline
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Reason I mentioned the vacuum level is because in some of the photos, it looks like the surface of the bagged wing is textured like the cloth. Ideally you want it pressed down flat, and 4 inches is hardly pulling a vacuum. I usually bag carbon over blue foam at about 18 inches and can go up to 24 inches without ill effects using 5.7 oz carbon twill.
screamin' eagle is offline Find More Posts by screamin' eagle
Old Aug 29, 2009, 12:50 AM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
Thank you.
Frank
Technically I think the wing should pivot on the NP of the wing (or tail for a FF stab) but as Adam pointed out earlier the NP changes with AOA for a cambered surface but for the low cambers we usually use I suspect it probably won't change to a large extent though I have no proof or formal knowledge on this - hence my decision to use the 25%MAC point as the wing CG.
flyonline is offline Find More Posts by flyonline
Old Aug 29, 2009, 03:09 AM
Joined Feb 2008
Yea, The layup is textured. =( I was just afraid to crush or distort the wings. I wish I had known... My willingness to try new things, over shadow my experience. Live and learn. Maybe I'll start searching for a new set of wings or cut some new ones and re do them. Don't get me wrong, I'm gonna fly these, but I'd like to make them right. Thanks for the advise Screamin Eagle!!!
Old Aug 29, 2009, 09:04 AM
R/C Chronic
Joined Jul 2004
I feel like kind of a pest with all my posts - I'm glad they are at least somewhat helpful. I think the plane will fly great irrespective of any bumps in the road...
Old Aug 29, 2009, 02:21 PM
Joined Feb 2008
Hahaha Your not a pest at all. I really appreciate your experience, and great input. I definitely don't know it all, and am not afraid to ask for help. I should have posted the question about laying up the carbon fiber. Just a bit to anxious to get her done.
I put a light layer of glass over the carbon fiber. Should I attempt to sand it down and put a light coat of thinned resin over the wing to try and smooth it out? BTW, I'm sending you a PM.
Old Aug 29, 2009, 02:28 PM
CR_Aircraft is offline
Find More Posts by CR_Aircraft
The Legend continues
CR_Aircraft's Avatar
Carlsbad, Calif
Joined May 2009
Nice looking plane Gregg,
Not sure we ever determined what your airfoil was,...could you post a profile picture of the wing root? Let's see if they used the RG15, 8020, 3016, 3021, etc...
CR_Aircraft is offline Find More Posts by CR_Aircraft
Old Aug 29, 2009, 02:54 PM
Joined Feb 2008
Hey CR Aircraft! Yea, It's no FG Turbo, but it's gonna look pretty good I think. I will post some pics of the root later tonight. I have my daughters this weekend, so trying to get some plane time in might be rough. lol I'll definitely have them post by Monday if not sooner.
Gregg
Old Aug 30, 2009, 08:14 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
A detail somewhere in my kit said E387, I have a different wing though-it is hollow molded FG.
Oh, re: vacuum level on the wings, I think less is more with these as from what I've seen they use very low density white EPS. Any more pull and you may have crushed the wings altogether.
Sleedo is offline Find More Posts by Sleedo
Old Aug 30, 2009, 10:24 AM
R/C Chronic
Joined Jul 2004
White foam is fine up to 12 inches - and am I imagining it or were these wings sheeted already? Ya need enough vacuum to pull the cloth flat!
Mini Tornado Build Questions HavingFun2002 Foamies (Kits) 4 Apr 08, 2002 11:16 PM
U2 Glider Conversion Scratch Build Questions cactus Electric Sailplanes 6 Feb 14, 2002 07:10 AM
JK Aerotek Zero build questions psbowen Foamies (Kits) 2 Feb 02, 2002 10:17 AM
Voyager Build Questions...I'm Pulling My Hair Out jimmyG Electric Heli Talk 18 Jan 18, 2002 02:38 PM
Build Questions for a HL Mini Tornado jah Foamies (Kits) 21 Jan 14, 2002 12:13 PM
