Old Aug 25, 2009, 06:24 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
Mountain Models Lucky ACE prop selection
Hi All,
I've just started construction on the Lucky Ace. And I'm wondering about prop selection. Would a 9*6 be a good choice? I've got several 3S 2100s so I can supply the amps. Is the frame slick enough to benefit from the extra pitch speed to be gained from a 9*6 vs a 9*4.7? The motor has not been chosen.
Mitch
mumblety-peg is offline Find More Posts by mumblety-peg
Old Aug 25, 2009, 07:16 PM
buzzltyr is online now
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Mitch, motor and batteries are going to determine prop size, pretty much. 3S2100's are awfully big for the Ace. I'm using the recommended Scorpion motor, and 3S1200 packs, which flies it just fine.
Mark
buzzltyr is online now Find More Posts by buzzltyr
Old Aug 25, 2009, 08:03 PM
USA, CA, Martinez
Joined Feb 2001
Hey Mark,
Thanks for the reply. The motor has not been purchased yet. And I may indeed end up buying some smaller packs. Just wondering about optimal pitch vs thrust.
BTW, I used to fly over in Burlington back when I lived in MA
Regards
Mitch
Old Aug 25, 2009, 08:27 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Hi Mitch,
I'm using Brian's recommended setup, and my Ace goes vertical pretty much forever.
It has become my all around "fun-to-fly" plane, and goes with me pretty much every time I fly. Because it's not a 3D plane, I'd probably go for a little less pitch and a little less thrust.
I'm a bit west of Burlington, just south of Springfield, on the CT. border.
Mark
Old Aug 27, 2009, 10:51 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
I'm using a GWS 9050, 3S 1320mAh and get long flights with unlimited vertical.. The beauty of the ACE is keeping it light.
bartricky is offline Find More Posts by bartricky
Discussion Mountain Models "Lucky ACE"--RELEASED buzzltyr Parkflyers 690 May 13, 2014 07:51 AM
Discussion StevensAero Shaft 400 vs. Mountain Models Lucky ACE rogerl Parkflyers 12 Nov 24, 2008 09:01 PM
Prop selection for MAX 001 6:1 gear drive...help!! foss1997 Parkflyers 2 Jan 05, 2002 01:28 AM
Prop selection? Superbike High Performance 5 Aug 04, 2001 09:58 PM
