Old Aug 25, 2009, 04:00 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Yippee!
Poor Man's Pre-Rotator for Autogyro!
I know this is an old idea. I've seen this on Hal Debolt's designs and a few others lately on rcgroups. I love the idea, especially on this size because it's a cheap fix for those no wind days. I have a hard time taxing my gyros on no wind or cross wind days on the hard surface at the field. This is going on my DAG's also!
Hope you guys enjoy!
RPG Autogyro with Prerotator Test (5 min 10 sec)
jodini is offline Find More Posts by jodini
Old Aug 25, 2009, 04:12 PM
SafeLandings is online now
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Joe...loved every second of it!!!
That is a very short take off run in no wind conditions ..and that cigar
How is that rotor spindle holding out?..try to add a little light oil to it if you can from time to time
Regards Rich
SafeLandings is online now Find More Posts by SafeLandings
Old Aug 25, 2009, 04:19 PM
batcho99 is offline
Find More Posts by batcho99
batcho99's Avatar
Cheshire
Joined Aug 2009
Looks great. Ideal for short field take off.
batcho99 is offline Find More Posts by batcho99
Old Aug 25, 2009, 04:24 PM
imsofaman is offline
Find More Posts by imsofaman
imsofaman's Avatar
Nowhere
Joined Aug 2003
Awesome awesome awesome!!!!!!!! Gary Tepass style!!!! You got it man!!!! Pre-rotator with out making it "post-heavy"!!!!
Honestly Joe....it is the only way to go in my opinion, and for you die hard "OMG..I have to have a gear reduction motor on my rotor-head", I will never understand that train of thought as you are adding a lot of weight. I just dont get it. Untill you can harness your motor's power and transfer it to the head via a clutch system, I think the way Joe does it makes perfect sence. Gary Tenpass "old school" style with the cordless drill is so cool. I like it Joe.....nice job!!!
Dave
imsofaman is offline Find More Posts by imsofaman
Old Aug 25, 2009, 04:30 PM
rotorheid is offline
Find More Posts by rotorheid
Closed Account
Joined May 2006
Joe,
Excellent way forward mate, that's such a practicle idea, I concur with Dave and the lads, no added weight or technical complications, just added value and usefullness.
11/10 , Cheers,
regards to all, Al
rotorheid is offline Find More Posts by rotorheid
Old Aug 25, 2009, 04:34 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Hi Joe,
Good to see you making videos again! I've seen that method in the past as well, in fact I've got a video somewhere of "Me" doing that on one of my AcoA Kelletts. It's a simple fix for zero-wind without adding wt. to the aircraft. Thanks for the video Joe.
Regards,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Aug 25, 2009, 05:51 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
Hey Mike....no loops yet!
Rich, thanks for the heads up on the hub. That thing spins like a top! I'll lube it up next time I take it out.
So, Al...I think it might make your life easier if you can get something set up like that...since you have such short runways.
Well, gotta go pull a rabbit out of a hat!
Joe
Old Aug 26, 2009, 12:06 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
For Big AL!
Hey Al,
I went back to the hobby store to get some more nose cones!
Wanted to try two differnet kinds.
Great planes makes one that has a thinner back plate which works well. Dubro is too thick. Also the staight aluminum hubs work great too.
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Well Joe looks like I'll have to bookmark this blog Can you see that I'm green with envy I like the prespin I might see one in my future because the grass is always too high.I'll keep watchin Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Aug 26, 2009, 01:20 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
Thanks Bill! The cigar smoking was for you! I'll have to get your brand next time!
Old Aug 26, 2009, 02:56 PM
Closed Account
Joined May 2006
Hi Joe,
Thank you for the pics, they explain perfectly. I think I do have a thin aluminum backed one some where in the house. I've been modifying my Rotor mast today, just plodding on, I went for the load share as in Rich's RPG set up, it took ages to get the angles correct for the head input arm, pics and more stuff tomorrow. cheers,
regards to all, Al
Old Aug 26, 2009, 03:01 PM
imsofaman's Avatar
Nowhere
Joined Aug 2003
If you guys dont mind me jumping in....dont use a cone whos diameter impeeds the flap travel of the rotor disc.
Sorry....it had to be said before someone says: "Hey....I put the cone on and now it doesnt fly..." LOL!!!
Old Aug 26, 2009, 03:11 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
Very good point Dave!
I did take a look at that and it seems like it still will flap well. That's why I think the metal one will work better....it's only 1 inch wide. The plastic one is 1.5 inches, but the smallest they make. I'll give it a hop tomorrow. If it tucks and rolls, you can say..."I told you so!!!!" HA!
Old Aug 26, 2009, 03:16 PM
imsofaman's Avatar
Nowhere
Joined Aug 2003
You can just add a couple washers under it. That is how I used to do it. I had to use a smaller spacer also.
Dave
Old Aug 26, 2009, 03:17 PM
Closed Account
Joined May 2006
I was just thinking that as the one I have is 50mm diameter, the blades won't even lead / lag for storage, I'll look for a prop nut. Good call Dave, cheers,
Al
Poor Man's Heat Shrink for Homemade Battery Packs... flytowner Parkflyers 28 Mar 12, 2010 11:45 PM
Poor man's Helistar Iain Micro Helis 25 Dec 01, 2005 06:15 AM
What to do? W/lb of poor man's F5B (long post) 96S14 High Performance 14 Sep 29, 2003 03:02 PM
Poor man's Super Slow Stick fun flyer? uglyplane Parkflyers 1 Jul 03, 2003 11:54 AM
Kyosho 180 Poor Man's Power Fix??? Don Sims Electric Plane Talk 41 May 12, 2001 09:23 PM
