This thread is privately moderated by Dora Nine, who may elect to delete unwanted replies.
Old Aug 25, 2009, 01:42 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Alfa model decal application and preservation.
One question that is asked frequently is: "How do I protect my Alfa model decals?" Well there are a number of ways, but the following links below are to a number of posts explaining what I do to the apply and protect the decals. These links are from a couple years ago in the Alfa Model Spitfire thread. Hopefully, this wil be of help and of course any questions or comments are always welcome.
Spitfire thread:
http://www.rcgroups.com/forums/showthread.php?t=652418
The entire discussion starts on page 11. The links below are directly to my posts with discriptions and photos.
http://www.rcgroups.com/forums/showp...&postcount=164
http://www.rcgroups.com/forums/showp...&postcount=168
http://www.rcgroups.com/forums/showp...&postcount=209
Dora Nine is offline Find More Posts by Dora Nine
Old Aug 25, 2009, 10:24 PM
CaseySP is online now
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
All good points there Dora.
I know you mentioned it, but it can't be overstated enough that the decal must not be over-soaked. This is probably the single most common reason decals peel away from the airframe after a short time.
The decal must not be immersed for any longer then 10 seconds or all of the adhesive needed to properly adhere to the model will be washed away.
Also, when the decal and backing is removed from the water bath, it must be placed on a non-absorbent/non-porous surface to soak. If it is placed on a absorbent surface, such as a paper towel, the adhesive will soak into the towel and not stay with the decal.
CaseySP is online now Find More Posts by CaseySP
Old Aug 26, 2009, 04:22 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
Good points as well. I think next I am going to do something about the Alfa motor questions. That seems to come up equally as much.
Old Sep 18, 2009, 05:17 PM
Bf109G is offline
Find More Posts by Bf109G
Over-engineered
Bf109G's Avatar
Ridgecrest, CA
Joined Nov 1998
I'm getting ready to do this on my 109. Brushing the SET on is all you need to do to be able to move the decal around on the surface? I've done it with water, but never used the SET/SOL before.
I've also read about people spraying a gloss clearcoat down before they apply decals to prevent silvering. You don't need to do that using the SET, correct?
Bf109G is offline Find More Posts by Bf109G
Old Sep 21, 2009, 11:03 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
Adding a layer of gloss prior to the decals is fine. It certainly WILL help. However, you MUST make sure it's 100% dry prior to decaling. I would wait atleast over night. The decal setting solutions are both a mild acid, and could damage the finish of the gloss cote.
When I do the decaling, I don't apply any gloss, but that because the set/sol does a good enough job its own.
You can move the decals around with the SET, just remember to be gentle, you really want the decal to be about 85% in place when you set it to the model. The set/sol actually melts the decal plastic film. With some practice you will figure it out. Just go slow..and the results will be worth the work.
Old Dec 20, 2009, 01:57 PM
moon dog is offline
Find More Posts by moon dog
p-47 great planes
hi don wher did you get 4 bladed prop for that p-47 is that electri or what? that prop looks very nice.have you flone it with that prop? if so let me no how it flys. i would love to got one. and who makes it? thank you rob
moon dog is offline Find More Posts by moon dog
Sold Alfa Model Decal Leftover Lot Sale! 20.00 ASAMech Aircraft - General - Miscellaneous (FS/W) 0 Jul 11, 2007 11:25 AM
Stiff Pushrods - Alfa Model Busta Prop Parkflyers 8 Nov 24, 2004 08:42 PM
Yippee! Anyone else here waiting for the Alfa Model MiG-15? ManWithNoName Electric Ducted Fan Jet Talk 5 May 30, 2004 02:20 AM
Aftermarket Plastic model decal site? dpoles Scale Kit/Scratch Built 16 Mar 17, 2004 02:19 PM
Aftermarket Plastic model decal site? dpoles Scale Kit/Scratch Built 2 Mar 16, 2004 08:40 AM
