Old Aug 24, 2009, 10:49 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
Brushless RPM Sensor not working
Brand new V3, software and firmware current as of today. Brushless sensor purchased some time ago and never used.
Two wires from brushless sensor soldered into connectors. Motor is Xera 4030/3Y-460, speed controller is Kontronik Jive. Battery system is 12s.
Sensor is plugged into "last" connector (the one marked RPM), with black wire near label and white wire on bottom.
Absolutely no readings. All other data seems normal.
Danal Estes is offline Find More Posts by Danal Estes
Old Aug 25, 2009, 11:40 AM
billpa is online now
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Danal,
Can you confirm you are logging RPM, under "Hardware, Choose Parameters to Log in the Recorder"?
Regards,
Bill, for Eagle Tree
billpa is online now Find More Posts by billpa
Site Sponsor
Old Aug 25, 2009, 01:47 PM
heliflieger is offline
Find More Posts by heliflieger
Joined Aug 2009
Hello,
my nameīs flo from germany.
i didnīt found a german support for my logger V3, so here i am!
same problem as danal with brushless rpm-sensor.
the logger showed only 999 in all numeric readouts in "log-mode".
live-mode didnīt worked at all.
so, i deleted all eagletree settings in advanced menu and reinitialized the logger.
volts, amperes, watts and mAh worked after that in both modes.
rpm not.
then, i checked for updates.
sw is 7.83, logger firmware is 5.63
rpmīs still not working.
settings like poleīs and gear ratio is right (i use the logger since 6 months)
rpm-sensor a is "hooked" in the recorder menu.
i used an ohmmeter and measured the wires from the rpm sensor, no brakes in the wires, all fine.
what now?
i hope my english doesnīt sound too funny...
bye!
heliflieger is offline Find More Posts by heliflieger
Old Aug 25, 2009, 11:59 PM
Joined Aug 2009
can i test the brushless sensor somehow?
Old Aug 27, 2009, 01:27 AM
Joined Aug 2009
no one an idea?
Old Aug 28, 2009, 11:11 AM
billpa's Avatar
Joined Nov 2003
Heliflieger, sorry about the issue you are having. Can you confirm that you are logging RPM under "Hardware, Choose parameters to log in recorder."?
Regards,
Site Sponsor
Old Aug 28, 2009, 11:25 AM
Joined Aug 2009
of course!
i ordered a new one. in germany, you have the possibility to send "online-buyed-stuff" back within two weeks.
if the new sensor works, i send the not-working-one back to the dealer for guarantee.
if the new sensor doesnīt work, iīm gonna send it to you for repair!
i will come back when i have news!
bye, flo!
Old Aug 28, 2009, 04:50 PM
Flys with Thumbs
Frisco, TX, USA
Joined Sep 2001
Verified.
Interesting point: I turned OFF "throttle" logging. I am now getting RPM readings. Could be coincidence...
Old Aug 29, 2009, 03:56 AM
Joined Aug 2009
new sensor, old problem...
Old Aug 29, 2009, 02:15 PM
billpa's Avatar
Joined Nov 2003
Danal, that's very strange. If you turn throttle logging back on, does the RPM no longer work?
Regards,
Site Sponsor
Old Sep 01, 2009, 07:03 AM
Joined Aug 2009
hi bill,
did you get my support-mail?
greets, flo
Old Sep 10, 2009, 10:53 PM
Flys with Thumbs
Frisco, TX, USA
Joined Sep 2001
Bill, just got back to this thread. RPM logger has been working fairly well. I will experiment with throttle logging.
Old Sep 13, 2009, 06:53 AM
Joined Aug 2009
hi
new logger, problem gone!
bye, flo
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Product Announcements 13 Dec 28, 2006 03:50 PM
Discussion Eagle Tree RPM sensor placement architorture Mini Helis 2 Aug 18, 2006 09:32 PM
Discussion Eagle tree magnet mount for rpm sensor Jasonscott Mini Helis 0 Mar 18, 2006 12:10 PM
how to build a rpm sensor. burro breath DIY Electronics 0 Nov 16, 2005 12:11 PM
Multiple RPM Sensor Support from Eagle Tree Systems, LLC Dave Lauck Product Announcements 1 Nov 09, 2005 12:39 AM
