Best regards W. |
Cromer,Norfolk, UK
Joined Nov 2006
Agreed Wendi, but the problem is that in the case of models certainly, 99% of the time, the control surfaces sizes are based on what works, which is itself largely based on experimentation, so there simply isn't an "equation" that is used.
It might BE possible to derive an equation using mathematical constructs, but that equation would have to have too much variable data to be workable. I do agree though with your first reply with regard to asking for help, and I do sometimes wonder when people ask these questions. If person X is doing a degree, they presumably have access to a university library who will be able to order books in on virtually any subject. As well as having access to the internet, and more than likely, access to a wide array of research papers and technical papers and abstracts. |
A Tentative reply.
Since you are writing a paper to be submitted relative to your degree, you are trying to meet a requirement OF SEVERAL FOOTNOTES AND/OR SOURCES for the information that you presented.
I have attended seven Universities and have writen several papers with referenced information. I find that the people who read your papers DO NOT pay much attention to your sources. So go ahead and write your paper and throw a number of footnotes to them. They are looking more for FORM than true research accuracy in undergrad courses. The profs wont know what you are talking about half the time. ** You have asked an impossible question by the way. As others have said,"there are many variables", too many for one equation to cover. If I were you I would measure the control surfaces of a number of kit planes. Chose trainers, 3-D, scale etc. Pay attention to something called "Tail Volume". You know that a short fusalage usually will have tail surfaces that are a greater percent of the wing area and visa versa. |
Cromer,Norfolk, UK
Joined Nov 2006
You could do a useful piece of research here actually.
"A single equation be applied to the size of RC aircraft control surfaces" On that hypothesis, examples of popular models could be measured for; wing section, chord, tail volume, tail moment, CMo etc Then, using the results of those measurements, you could try to devise an equation which fits the facts. That way, you could either prove or disprove the hypothesis. In either event, you fulfill the objective of the research. |
Thanks guys for all your help. The airplane im designing is a F5D pylon racer designed to fly at times as quick as 250mph. I have already calculated the required aileron percentage as that has to do heavily with the airfoil section.
What im really after is the required size for the actual horizontal and vertical stabilizers. They have already been designed as i have worked off from a paper which had used percentages from the actual wing area to calculate the size of these components. I just didn't think that stating percentages would have been enough to support the design theory. As said before, there are many variables which can go in to the equation. I also really don't think that such an equation has been derived for model aircraft. Ill do a little more research, if nothing comes up ill just source the paper which im basing it on. Thanks to everyone for their help... Abdullah. |
Thanks... |
USA, WA, Edmonds
Joined Aug 2008
Tail volume is a relatively simplistic calculation that isnt as accurate as some others.
I had a stability and control book written by Jan Roskam that gives 1 long equation for each stabilizer surface. Determining all of the variables in that equation was fairly difficult though. |
I have no doubt that the tail volume coefficient isn't the entire story. After all, one could start from scratch by trying to solve the differential equations for fluid flow around a rigid body, and try to get all the way to sizing flight controls from there.
But the tail volume coefficient and associated information might well be sufficient for the OP's needs. It certainly seems to be sufficient for a lot of RC model design. There is some good info on RC model design here: http://www.charlesriverrc.org/articles_modeldesign.htm The following two references might also be useful; they're designed for the lay person, so the math level is not high enough for an engineering student, but they still contain a great deal of good information: http://www.amazon.com/Model-Aircraft.../dp/1854861905 http://www.amazon.com/Basics-Model-A...791867-7452345 -Flieslikeabeagle |
| Thread Tools | |
| Discussion Sailplane control surface sizing... | skyzking | Modeling Science | 6 | Apr 07, 2009 04:33 PM |
| Drag Reduction with Control Surface Tiplets | green66 | Electric Plane Talk | 0 | Dec 15, 2001 01:19 AM |
| And_Now control surface hinges. | CharlesD | Parkflyers | 6 | Dec 01, 2001 08:36 AM |
| Omega E control surface travel | sprocket | Electric Sailplanes | 5 | Aug 05, 2001 02:09 AM |
| Wingo control surface gap | JensJakob | Foamies (Kits) | 1 | Jun 16, 2001 04:51 PM |
