Old Aug 23, 2009, 10:11 PM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
Thunder Power Pro Lite V2 4350 mAh 3S 11.1v--Did I just wreck it?
Today, I flew the Apprentice for approx. 33 min on my Thunder Power Pro Lite V2 4350 mAh, and used up 95% of the battery. 15th cycle.
That is, to be precise, when I recharged it on my Cell Pro 4S, it showed 5% to start. Actually started about 12%, then after a minute or so, settled on 5%.
It's taken hours to recharge. Have been recharging off and on for probably 6 hours today, more or less, and it's now at 12.59V, 95% finally. Just started the balance cycle.
Did I wreck my battery? I've never used more than 80% before.
Have actually flown for longer, but this time I flew loops and more time WOT.
tlr-boise is offline Find More Posts by tlr-boise
Old Aug 23, 2009, 10:13 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
where was you LVC?
i doubt this will "wreck" your battery, but yes shorten it's life. basically, it's not happy about it.
i once had a parkzone lipo i left connected to a charger all night. when i recharged it, it came back up past 2200mah in. i continued to use said lipo for the next year and a half.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Aug 23, 2009, 10:15 PM
Boise, ID
Joined Dec 2008
Thanks. Did not reach LVC. Using the E-flite 40 amp ESC with Power 25 motor. The LVC is whatever the default is; I haven't changed it. 3.7V, I think.
Old Aug 23, 2009, 10:25 PM
Team White Llama!
that's something you should look into, generally LVC will kick in before you drain the battery that much, unless your amp draw is very low. setting it up correctly doesn't take long and is cheap insurance.
i think you will be fine.
Old Aug 23, 2009, 10:38 PM
Boise, ID
Joined Dec 2008
Also, dang it; I didn't notice what volt the charging started at, when the window showed 5%.
Old Aug 24, 2009, 06:30 AM
pmmartin is offline
Find More Posts by pmmartin
Fly Every Day
pmmartin's Avatar
United States, FL, Sebastian
Joined Apr 2001
The 5% should be the amount of usable voltage so you should be just fine.
pmmartin is offline Find More Posts by pmmartin
Old Aug 24, 2009, 08:22 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Thunder Power pro lite V2 are relatively recent cells. what i mean is the voltage will (generally) not drop below an esc's out of the box pre set LVC until the pack is very nearly empty.
no way your LVC is set at 3.7v/cell by default. the earliest lipo specific ESC's were set at 2.7v/cell which now is WAY too low (even then it was too low). The very latest high C cells, some users custom set the LVC to 3.5V/cell.
a timer with appropriate for the given lipos LVC as back up is preferable
12.59v , average 4.2v per cell is fine. unsure why recharge (balance) should take so long?
Alex
like2fly! is offline Find More Posts by like2fly!
Old Aug 24, 2009, 06:55 PM
Boise, ID
Joined Dec 2008
Thanks guys!
For Sale Thunder Power Pro-Lite TP 1320 mAh 3 cell 11.1V and 2 cell 7.4V LiPo Battery TP taps shschon Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 11, 2008 07:32 PM
Sold Thunder Power Pro-Lite TP 1320 mAh 3 cell 11.1V bighead93 Aircraft - Electric - Batteries & Chargers (FS/W) 5 Nov 11, 2008 10:56 AM
Sold Thunder Power Pro-Lite TP 910mAh 3 cell 11.1V Lithium Polymer LiPo Battery $25 shschon Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 25, 2008 06:55 AM
Sold Thunder Power Pro Lite 3s2p 4200 mAH Brick Packs PDX Slope Pilot Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 11, 2006 09:59 AM
Sold Thunder Power Pro Lite 4S4P 8000 MAh Orion_V Aircraft - Electric - Helis (FS/W) 0 Feb 09, 2006 09:10 PM
