Old Sep 25, 2009, 12:26 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
It should be no prob trap with a little fine tuning,I usually set up 2 flite modes , one for slow flying witha tad of reflex, and one for railing thats trimed to track strait at high speeds.
Thats whats nice about having flite modes .
You can fly fast then when I slow down I just flip the switch for a tad of up trim and its awesome.
ck
Originally Posted by trappy
I need this baby to stay in a dive, no rising at speeds or stuff like that. It needs to stay where I point it, so I guess a bit nose-heavy is the way to go.
klique is offline Find More Posts by klique
Old Sep 25, 2009, 12:31 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
ck
exactly what I'm aiming for. thanks for the advice. won't need the flight modes ... never really understood what those are for. I can pull the elevator myself on the landing but the idea is to have a plane that tracks straight wherever I point it and on the landing I just get her low and then wear off the speed until she stalls out and "lands".
trappy is offline Find More Posts by trappy
Old Sep 25, 2009, 12:32 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
ck
thats my permanent flight setup: a little reflex for slow pokin' around
As you can see in the video, she doesnt really yaw about that much
2nd fpv flight (3 min 41 sec)
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Sep 25, 2009, 12:46 PM
jetstreaming is offline
Find More Posts by jetstreaming
UK
Joined Mar 2009
Nice project Trappy. Referring to your Wing with the Video Tx 'embedded' into the end of the Wing. Will this affect cooling to the Video Tx? Also, would you still be fitting Wingtips at the sides?
Locating a Video Tx onto a Flying Wing is quite a tricky process I suppose, as you only have a flat wing to work with, and no nice little canopy sections to glue things to (vertically), like you would on say an EasyStar!
Look forward to further updates.....
jetstreaming is offline Find More Posts by jetstreaming
Old Sep 25, 2009, 12:52 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
jetstreaming: The wingtips will still be mounted, but the area where the cooling section of the tx currently sticks out will be cut out from the wingtips. So the heatsink will still be exposed to moving air. It will not have any effect on the cooling.
Wings are pretty good for placing the gear in my opinion. Yes you can't attach them properly but once you find a good place you can space things out well enough to get excellent range as opposed to an EasyStar where the tx in most installation is jammed behind the camera where it will interfere with your picture quality, pan servos and not get full range because of the reflective material right in front of it.
Old Sep 25, 2009, 01:01 PM
UK
Joined Mar 2009
Interesting, will like to see the finished wing once the Tips have been added (around the Video Tx). And the heat it generates wont affect the foam around it?
Sweet project. ...The King of FPV Flying Wings!
Old Sep 25, 2009, 01:06 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
jetstreaming: The tx comes down very cool (30deg C) if you don't leave it just standing there on the workbench. I don't think it will have any effect on the foam around it.
Thanks I don't think I'm the king of flying wings ... that's Gabriel ... at least for now, wait till you see my first urban Ritewing video
Old Sep 25, 2009, 01:08 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Heres how mine is mounted in the wingtip
Administrator
Old Sep 25, 2009, 05:07 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Mine came in yesterday. I hope I can come close to doing as good a job as you guys assembling it.
bracky72 is offline Find More Posts by bracky72
Old Sep 25, 2009, 05:24 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Yep, youll do fine. It was my 1st wing as well.
1. glass it light. If its hot outside, be prepared to work fast as the 3M will get sticky real quick
2. go sparingly on the gorilla glue when squirting it down the holes for the spars
3. Cut your bays and install servos as far forward as possible..seriously
4. weigh all your components as you add them and after each major assembly step (glassing, covering, electronics). Shoot for an AUW of 60oz or less for best glide and performance.
5. balance at 10-10.5" back from the nose
Administrator
Old Sep 25, 2009, 05:26 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
Yeah .. it's not my first wing, but I've been told (by my R/C buddies) that the person that builds worse than me still has to be born
Old Sep 26, 2009, 05:51 PM
UK
Joined Mar 2009
Looks good webdr
Is the trailing edge of the wing to the left, where it tapers off?
If so, if the Wing lands flat on the ground is there a risk the antenna sticking past the end could dig into the ground and get ruined?
On mounting the Video Tx onto the wing, I had thought of gluing a small block of foam ontop of the wing somewhere, curved at the front 45 degrees for aerodynamics. Then the Video Tx is glued to the back of the block, sitting vertically. Might ruin the sleek Wing profile, but would have the Video Tx out of any danger ontop of the Wing, also with no obstructions behind it that could affect reception.
Old Sep 27, 2009, 07:16 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
jetstreaming: See the way I have installed it ... I had the same concerns as you.
Old Sep 27, 2009, 09:45 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Originally Posted by jetstreaming
Looks good webdr
Ive got about 15+ landings, no problems as of yet. If you lay the wing on the ground with the wingtips attached, youll find out that the nose touches the ground before the leading edge at the tips does.
Administrator
Old Sep 28, 2009, 07:19 AM
UK
Joined Mar 2009
Sounds good. Any Vids of your build/Wing flying?
I've just ordered a 50" Wing and plan to mount the Video Tx at the side also. As far away as possible from all the other 'critical' electrical components, that will then be mounted all the way near the end of the opposite wing!
...if I continue to experience glitching (as I did with my doomed 1st FPV model, my EasyStar), I might resort to crossword puzzles instead!
Discussion Ritewing Zephyr FPV build thread Matt Gunn FPV Talk 436 Feb 01, 2011 11:01 AM
Question Anybody Interested In Another LightHawk + LightSpeed Build Thread? Bolt55 Hand Launch 13 Jun 19, 2008 03:16 PM
Build Log Ritewing Wacko Build Thread critical Flying Wings 36 Nov 12, 2007 10:56 AM
Another GWS P51D Build Thread - wth Flaps, Retracts and Film covering though! Michnet76 GWS (Grand Wing Servo) 119 Apr 09, 2006 11:26 AM
It's not another Sopwith Triplane - Austin Triplane build thread Looooeeee! Scale Kit/Scratch Built 58 Dec 03, 2005 02:44 PM
