Old Sep 21, 2009, 04:58 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
ok, just wanted to point it out since you noted you might be making package deals. I'm setting up a 5S glider at the moment ... I've got a lot invested on step-downs and it's a pain
trappy is offline Find More Posts by trappy
Old Sep 21, 2009, 05:36 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
I would neve attach my cameras of the main batt power anyways,I would use a seperate power for rx and cam gear.I wouldnt trust that situation with it configured like that, if somthing goes wrong with you cam gear.
It could it take out your drivetrain and rx, and that would suk .
Ck
klique is offline Find More Posts by klique
Old Sep 21, 2009, 05:37 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
Originally Posted by klique
I would neve attach my cameras of the main batt power anyways,I would use a seperate power for rx and cam gear.I wouldnt trust that situation that if somthing goes wrong with you cam gear.
If so it could it take out your drivetrain and rx,that would suk.
Ck
believe it or not, you actually increase reliability with a single battery system I've got 2 batteries in parallel on the Maxi Swift ... as soon as the bank allows, I'm getting a 5V step-down and throwing out the VTx battery.
Old Sep 25, 2009, 11:35 AM
klique is offline
Mum is the word!
Joined Jun 2003
Hey Trappy here is the new Updraft 60'' posible powered thermal and sloper wing.
This will make a great new addition to my lineup.
Here is a thread w info.
http://www.rcgroups.com/forums/showt...2#post13198845
Here are a few pix
Old Sep 25, 2009, 11:43 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
love it. thanks also for that last pic of the zephyr ... now I know what i've planned wrong on the motor ... needs to go further forward over the spars
Old Sep 25, 2009, 11:56 AM
klique is offline
Mum is the word!
Joined Jun 2003
Well maybe not, what motor are you using,is your gear heavy?
Mine is for sport use and onmy has bats ,so to get it to ballance better I moved it more forward to help.
You gear might weigh mor so the motor being back it will help you possibly.
Old Sep 25, 2009, 12:03 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
not sure I'll try it out to see how the CG works. I'm just not happy with the motor mount embedded only in foam, in your videos you mentioned to put it onto the stabs but they are too much forward
Old Sep 25, 2009, 12:10 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Ill vouch for how strong it is in the foam. once you glue it in with goop, it will not budge or break out. mine butts up against the carbon rods.
trap, I actually think the vertical part of the black mount will bend before it rips out
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Sep 25, 2009, 12:13 PM
klique is offline
Mum is the word!
Joined Jun 2003
Trap what motor are you using?
Web DR did you add much weight to ballance yours?
Ck
Old Sep 25, 2009, 12:16 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
klique: Turnigy 35-36 1300kV
http://www.hobbycity.com/hobbycity/s...idProduct=2140
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Ck
Ive found that the swept back wing is a catch-22.
You want to put your gear out on the wing tip, but doing so puts all that gear way behind the center of gravity. So you gotta pick your battle, either move stuff farther in so your infront of the cg and risk interference, or keep the VTX and gps out on each wing tip and come up tail heavy.
I chose the later of the two because its perfectially flyable at 10.5" w/o adding any balancing weight.
My AUW is 60.8oz
Administrator
Old Sep 25, 2009, 12:17 PM
klique is offline
Mum is the word!
Joined Jun 2003
I just looked a Web DR Zepyr and his motor seems to be in a good place for all around ease of ballancing.
Old Sep 25, 2009, 12:19 PM
klique is offline
Mum is the word!
Joined Jun 2003
At 10.5 does she track solid with no hunting or rising at speeds?
I am just trying to get a feel for how its handling for you.
Ck
Old Sep 25, 2009, 12:20 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
I need this baby to stay in a dive, no rising at speeds or stuff like that. It needs to stay where I point it, so I guess a bit nose-heavy is the way to go.
Old Sep 25, 2009, 12:22 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Ck
it does get a yaw wobble every once in a while, but overall its not that often. Doesnt rise at speeds that Im aware of, it will just start to pull out of a dive at the bottom of the dive.
I really like how it lands at this configuration. I can come in somewhat slow in an alpha attitude and bleed off speed in the ground effect.
Im going to do some more video flying tomorrow so Ill post up.
Side note, Incase your wondering, max speed in a straight line is around 50mph.
I put it in a dive w/ the motor off and she hit 80 real quick.
Thats with a 10x6.5 folding prop. 11.1 lipo, and a 35-36-1200
Administrator
Discussion Ritewing Zephyr FPV build thread Matt Gunn FPV Talk 436 Feb 01, 2011 11:01 AM
Question Anybody Interested In Another LightHawk + LightSpeed Build Thread? Bolt55 Hand Launch 13 Jun 19, 2008 03:16 PM
Build Log Ritewing Wacko Build Thread critical Flying Wings 36 Nov 12, 2007 10:56 AM
Another GWS P51D Build Thread - wth Flaps, Retracts and Film covering though! Michnet76 GWS (Grand Wing Servo) 119 Apr 09, 2006 11:26 AM
It's not another Sopwith Triplane - Austin Triplane build thread Looooeeee! Scale Kit/Scratch Built 58 Dec 03, 2005 02:44 PM
