Old Aug 23, 2009, 06:16 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Another Ritewing Zephyr build thread
After the death of my Maxi Swift I decided to go with something a little more versatile. I'm going to let the pictures do the talking on this build log and include descriptions in the pictures where necessary.
Day #1: Installation of spars and test-fitting video wire
trappy is offline Find More Posts by trappy
Old Aug 23, 2009, 07:23 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Ill be following the build. have you figured out what colors your going to go with? Mine is going to be black on the bottom and silver on top.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Aug 24, 2009, 06:40 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
webdr, I'm not even sure anymore if I'll do any covering. I'll need to disuss this with klique. If I do any covering, I'll make it blue & yellow, mainly because that's what I have lying around. No point fussing about the colors, since I won't look at the plane in flight after the maiden
Old Aug 24, 2009, 07:25 AM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Trappy
Any reason why you used CA and not Gorrilla Glue for the central spars?
Just curious thats all
Simon
bignose13 is offline Find More Posts by bignose13
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
We don't get gorilla glue around here Only reason.
webdr: what distance from tip for COG did you use?
Old Aug 24, 2009, 07:30 AM
Yeah Baby
bignose13's Avatar
Joined Apr 2006
I am a bit concerned for you mate, I think the CA might be a bit brittle for the job, when I built my Lightning only Gorrilla glue would be up to the job, but thinking about it, I dont suppose you will be going 90 mph so should be fine
Old Aug 24, 2009, 07:34 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
I will be going 90mph but no worries, I'm going to glass at least over the spars so they don't have any chance of ripping through the EPP. Also, I will take a lot of load off the spars by moving the batteries out on the wing a bit. My maxi swift didn't have any spars at all ... no issues at all. I'm not worried - yet
Old Aug 24, 2009, 07:43 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
I havent even looked at the COG yet. I think Chris said 10" back from the nose but dont quote me.
Administrator
Old Aug 24, 2009, 09:51 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
ok, thanks. he told me 10-11" but wasn't sure if from front or back ...
shouldn't you look at the COG *before* cutting everything out?
Old Aug 24, 2009, 09:58 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Hi guys
I would start with cg at 10'' to start.
It is calculating between 10 to 11'' on the cg calcuator.
ck
klique is offline Find More Posts by klique
Old Aug 24, 2009, 10:00 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
thanks. I rather have it more forward since the outrunner isn't mounted totally in the middle of the wing.
Old Aug 24, 2009, 10:21 AM
klique is offline
Mum is the word!
Joined Jun 2003
Sounds good ,if you need to add weight to hit the 10'' ,then just make the added weight is easily removed for fine tuning if you find that it is a tad noseheavy.
The large root and tip chord on the zephyr should make it easily flyble anywhere close to 10'' ,it should be fairly easy to atain with this sweep.
Ck
Old Aug 24, 2009, 11:17 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
We don't add weight, we add larger batteries those are easily removed anyhow
Old Aug 24, 2009, 11:37 AM
klique is offline
Mum is the word!
Joined Jun 2003
Sounds even better
ck
Discussion Ritewing Zephyr FPV build thread Matt Gunn FPV Talk 436 Feb 01, 2011 11:01 AM
Question Anybody Interested In Another LightHawk + LightSpeed Build Thread? Bolt55 Hand Launch 13 Jun 19, 2008 03:16 PM
Build Log Ritewing Wacko Build Thread critical Flying Wings 36 Nov 12, 2007 10:56 AM
Another GWS P51D Build Thread - wth Flaps, Retracts and Film covering though! Michnet76 GWS (Grand Wing Servo) 119 Apr 09, 2006 11:26 AM
It's not another Sopwith Triplane - Austin Triplane build thread Looooeeee! Scale Kit/Scratch Built 58 Dec 03, 2005 02:44 PM
