Old Aug 23, 2009, 05:51 PM
flanker is offline
Find More Posts by flanker
flanker's Avatar
Lowell, MA
Joined Feb 2004
Help!
Schulze Isl 6-330 d discharge programming
I am trying to figure out how to setup my isl 6-330 charger to discharge my batteries for storage. For that I would like to set it up to discharge a fixed amount of battery capacity and then stop automatically. For example set is so that discharge stops after it has removed 1000mah from the battery. Otherwise I have to watch it and make sure it doesn't drain the battery completely and ruin it in the process.
I have gone over the manual but it is so cryptic that it is hard to figure out more advance functions. Does anyone know if that is possible with isl 6-330 and if so how can I program it?
Thanks in advance for any help
flanker is offline Find More Posts by flanker
Old Aug 24, 2009, 05:42 AM
Giz is offline
Giz
Find More Posts by Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
You could charge up after you have flown and limit the charge delivered by setting the charge limit. That's what I do manually as I always have my charge limit set too 99999.
Giz is offline Find More Posts by Giz
Old Aug 24, 2009, 08:04 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
It's much more usual to discharge until the battery reaches a preset voltage (which prevents it getting over-discharged). The isl6-330 can do that I believe.
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 24, 2009, 08:26 AM
flanker is offline
flanker's Avatar
Lowell, MA
Joined Feb 2004
The charge limit setting doesn't seem to have any effect. It seems to continue on past the set limit. Is there a special charge program that I need to use to make the charger honor that?
Old Aug 24, 2009, 08:29 AM
flanker is offline
flanker's Avatar
Lowell, MA
Joined Feb 2004
Slipstick I agree. Usually I keep my batteries charged so that I can go fly when the opportunity arises. But sometimes you know you won't be flying a battery for a while or it is the end of the season here in the NE and the battery needs to stored. I have already ruined one battery but forgetting that it was on discharge and charger simply kept on going until completely empty
Steve
schulze isl 6-330 d chamaleon charger philip noel Electric Plane Talk 10 Jan 10, 2006 01:48 PM
For Sale Schulze isl 6-330 d Charger & Power Supply delta2001 Aircraft - Electric - Helis (FS/W) 0 Jun 11, 2005 10:39 AM
schulze isl 6-330 d chamaleon charger philip noel Aircraft - Electric - Airplanes (FS/W) 2 May 24, 2005 01:50 PM
Schulze isl 6-330 d charger Whiskey Bravo Aircraft - Electric - Airplanes (FS/W) 1 May 02, 2005 03:13 PM
Question Charging Li-Poly's with Schulze ISL 6-330-D? Clive Henry Jones Batteries and Chargers 8 Jan 28, 2003 11:49 AM
