Old Aug 23, 2009, 01:56 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Sketchup FPV platform(build)
Thought i would share with you my FPV design, it's a high wing pusher type
with 1400mm w/s, Clark Y wing foil. Going to be 4ch with no rudder, just a steerable nose wheel.
So far i have most of the fuselage design complete which is balsa/ply
structure, the wings will be solid foam core with balsa skin, the twin booms
are going to be aluminium and tail surfaces balsa.
Kev.au is offline Find More Posts by Kev.au
Old Aug 23, 2009, 01:57 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Old Aug 23, 2009, 01:58 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
finished up the fuselage design
Old Aug 23, 2009, 01:59 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Started construction on the fuselage soon after
Old Aug 23, 2009, 02:00 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
This is an idea i have for the nose wheel.
Old Aug 23, 2009, 02:01 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Knocked up a foam nose cone, going to glass it latter on in the build.
template for two blocks of foam.
sanded to shape then stuck together.
Old Aug 23, 2009, 02:04 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
More progress, cut out the center and wing tip sections with my hot wire.
Also cut out slots for wing tip dihedral brace(s)(1" under each tip)
C/F spar cut out into the under side of main section, should give it some extra strength
Starting to look like a plane now
Clark Y foil.
Old Aug 23, 2009, 03:21 PM
robe_uk is offline
Find More Posts by robe_uk
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
looks great, please keep updates coming
robe_uk is offline Find More Posts by robe_uk
Old Aug 23, 2009, 04:11 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Thanks Robe_uk, will do mate, thanks for ur comment.
Old Aug 23, 2009, 09:20 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Another little update, originally i was going to use alloy tube for the tail booms
but decided to use 3mm ply sandwiched between two 9mm sheets of soft balsa.
The fins and tail plane are 6mm foam framed with 6mm by 10mm balsa.
3mm inner part of the tail boom inter locking to the dihedral brace.
Old Aug 25, 2009, 11:33 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Small update,
Re-built the tail/fins out of 9mm/10mm balsa strips for extra strength to support the elevator servo. Also cover it with white solar film.
Old Aug 28, 2009, 09:24 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Another small up-date.
Skinned center and outer wing sections with 2mm balsa and used 10mm balsa strips to
simulate built up wing. latter on today i hope to add soft balsa wing tip blocks and mount ailerons/servos.
Old Sep 06, 2009, 04:35 PM
chimaera is offline
Find More Posts by chimaera
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
I love the look. I want something similar, maybe a little more glideresque. I will be watching.
chimaera is offline Find More Posts by chimaera
Old Sep 06, 2009, 04:50 PM
z999 is offline
Find More Posts by z999
Joined Oct 2007
how do you model the body in sketchup? I'm currently practicing in turbocad but it lacks in the 3d side, it's pretty difficult to get started, I'm currently downloading autocad to try that. I want to design something similar to mount a camera on it, supposed to be low drag trainery sort of thing probably will use clark-y too
z999 is offline Find More Posts by z999
Old Dec 29, 2012, 12:25 AM
SubSonichobby is offline
Find More Posts by SubSonichobby
Joined Mar 2011
Just started to design a drone here.
http://subsonichobby.blogspot.com/20...cdrone-v1.html
SubSonichobby is offline Find More Posts by SubSonichobby
Discussion New Foamie Aerial Platform Build critterhunter North Coast Electric Flyers 22 Dec 20, 2006 04:32 PM
Discussion Help w/ SS AP Platform build in/near DC? brobak Beginner Training Area (Aircraft-Electric) 0 Aug 01, 2006 07:51 PM
Discussion Miss Stik as AP platform build P-51 fan Aerial Photography 7 Mar 12, 2006 05:23 AM
ap1 - dedicated AP platform build thread nihil Aerial Photography 178 Mar 15, 2005 11:27 PM
I-Cub aerial platform build-progress pics Italian Flyer Aerial Photography 22 Mar 03, 2005 08:09 AM
