Old Mar 08, 2010, 07:39 AM
Joined Jan 2010
Are the fuses only necessary b/c of your DD kit? The stock heli doesn't have any fuses right?
It is not necessary to use fuses for DD kit. It is needed only when you are using 11.1V batery instead of 7.4V (just to prevent demage of 3 in 1 unit). DD kit from RTF-heli.com is actually the same as tail motor for Esky Honeybee CP3, you can buy it on RC711.com for the same or better price.
ifin is offline Find More Posts by ifin
Old Mar 08, 2010, 10:27 AM
New R/C Aircraft Fanatic!
JettaManDan's Avatar
Southern Maryland
Joined Jan 2010
great info guys..gonna use the recommendations to make my 180D fly better...bump...
JettaManDan is offline Find More Posts by JettaManDan
Old Mar 09, 2010, 09:30 AM
Southern Maryland
Joined Jan 2010
well the changes worked awesome! put the flybar in the middle holes..and cranked up the extent and the gain..and this sucker scoots now! more flight tests to come...
Old Mar 13, 2010, 11:56 PM
Joined Jan 2009
Has anybody mentioned about the pinion pitch. Is the CB180D pinion a .3mod or .25mod? I know it is not a .4mod. Also what is the total count of the teeth of the pinion? thanks.
Jonathan
wowhobbies is offline Find More Posts by wowhobbies
Old Mar 14, 2010, 08:12 AM
Joined May 2009
0.3, 16t.
Arakon is offline Find More Posts by Arakon
Old Mar 14, 2010, 09:57 AM
Joined Apr 2009
I found a couple of places that sold the 0.3 pitch but after one minor blade strike it removed the teeth so I got a 64 pitch spur gear for a RC truck machined an aluminum hub for it and I am using that now. It is more common alittle larger tooth and a wider gear works great..
Flight time is offline Find More Posts by Flight time
Old Mar 15, 2010, 03:23 PM
Joined Jan 2009
Originally Posted by Arakon View Post
0.3, 16t.
Thanks so much for the info. Any link where we can purchase them. We are looking for 10T to 12T with 2.0mm shaft diameter. Any links will be appreciated.
Jonathan
WowHobbies.com
Old Mar 18, 2010, 07:48 PM
Joined Mar 2010
I just got the D and have a couple of questions..........I cant seem to get any flight time out of a battery, damn battery's only last 2 or 3 min. I see where most people are getting around 10 min flight time on a battery.
Also the ruder seems to be extremely sensitive. I just move the stick and it spins. Would turning the gyro gain down help this?
Also any idea on the battery thing would be great.
sorry so noobish
Hydmechc is offline Find More Posts by Hydmechc
Old Mar 20, 2010, 10:45 AM
United States, AZ, Gilbert
Joined Feb 2010
want to convert to spektrum
I have the cb180d and love it however since buying a spektrum dx6i to fly my msr I want to now fly my 180d with this tx.. Anyone have any suggestions about converting the cb180 to spektrum gear?
here are my thoughts..
1 - get an AR6k series rx something affoardable
2 - get 2 esc's 1 for the main motor and one for the dd tail
3 - buy a used gyro or get a hh gyro from hobbyking
Anything else? any specific product recommendations?
thanks in advance
dan
dmanshep78 is offline Find More Posts by dmanshep78
Old Mar 20, 2010, 08:39 PM
Joined Apr 2009
I did this a few months ago I installed the 6110 receiver a telebee gyro 6 gram gyro and the brushless motors A far better radio than the walkera you wont be sorry..
Old Mar 26, 2010, 07:51 PM
Joined Dec 2009
Is this 2402 TX ok or will they package a better TX in the future with this helicopter?
Mackhack is offline Find More Posts by Mackhack
Old Mar 26, 2010, 10:00 PM
Joined Apr 2009
Probably not you could buy a 2801 pro but if your going to spend that much you might just as well go with a DX6I and a spektrum receiver..
Old Mar 26, 2010, 10:07 PM
France
Joined Jul 2007
Jonathan
WowHobbies.com
Hello Jonathan,
I have a link for you for the 10 and 12T but the shop is in France.
They have pinion M0.3, 10T, 12T, internal shaft 1.5mm, then you can resize to 2mm.
In case of, you can found in similar shop in USA, i hope.
Best regards.
http://www.letrainmagique.com/Tarif_..._module_03.htm
f-btsd is offline Find More Posts by f-btsd
Old Mar 26, 2010, 10:43 PM
Joined Dec 2009
That's true. Na I think I'm gonna go either with the E-Flite Blade mSR or I stick with what comes with the CB180Q which is the 2402.
Or does anything speaks against the CB180Q with the 2402?
I mean I still have my big Graupner gas engined Bell 222 helicopter with my Graupner MC-24 (uh what a powerful remote control. I love my German toys)
Old Apr 27, 2010, 02:58 AM
Joined Jan 2010
it can fly
Hi everybody, I have finaly found the way how to force it fly... The main problem of this heli is lack of power, so I have replaced the main motor with a new one from ESKY Honey Bee CP3. Now it has much more power for flying (like it should be from the factory). The second way how to achieve more power is described on RTF-heli.com (replace 2 cells batery with 3 cells one). It probably works, but my solution is more cheaper, everything you need to buy is a motor. No new gears, batery, fuse or anything else, just new powerfull motor (which is cheaper than 3 cells batery).
Mini-Review RCHH Now Taking Pre-Orders for the new Walkera 4B120 johnIn2SonAZ Micro Helis 1 Aug 13, 2009 11:17 PM
For Sale **NEW** Walkera 5G6 metal 2.4Ghz helicopter $100 delivered Z06 Tony Aircraft - Electric - Helis (FS/W) 1 Nov 30, 2008 07:24 PM
Sold Traded Z06 Tony for a new walkera 4#3b HyperHelis Aircraft - Electric - Helis (FS/W) 10 Oct 06, 2008 07:49 AM
Discussion Lookin' for a new cell phone.. Motorola Q? Tram Life, The Universe, and Politics 14 Apr 08, 2007 03:26 PM
Matt S: Any BT mods for this new heli? blades flex too much Norb Electric Heli Talk 6 Mar 04, 2005 06:37 PM
