Old Aug 21, 2009, 10:43 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Ritewing Zephyr FPV build thread
For my 1st FPV platform Ive decided to go with the Zephyr.
This one is slightly cut down with a total ws of 54" and a little extra sweep to the wing. I was told by Chris at Ritewing that it will be alot easier to balance in this size and shape but still float and create lots of lift.
Power:
Battery is one 11.1v 5000mah Thunder Power Pro-Lite lipo
Motor (so far) is Rimfire 35-36-1200
ESC is Electrifly 45-SS Silver Series 45amp
Servos TBD
Video:
RV 900-500 transmitter
DX201 w/ case
Tilt/pan TBD
GPS/OSD TBD (either Range Video or Eagle Tree)
I decided to build this wing with flaps for controlled decents, short landings, and decent slow flight characteristics.
Heres a few pics of the initial build with my intended layout.
Please let me know your opinions.
Matt
www.gunnphotoservices.com
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Aug 21, 2009, 10:57 AM
xeqouz is offline
Find More Posts by xeqouz
Joined Aug 2007
Nice build there! I'm not an expert in aerodynamic, I'm confuse on how the flap/spoiler will work on flying/delta wing? Do u intend to use it just like the concept of speed brakes i.e. flap up elevons down?
xeqouz is offline Find More Posts by xeqouz
Old Aug 21, 2009, 11:15 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Ive been talking with Chris at ritewing and he said that there are wings with flaps, so Im guessing it will work.
I can also employ mixing with all four surfaces such as butterfly mixing or crow mixing. That makes the elevons go up and the flaps go down. the result is a very stable plane with extreme drag and slow flight abilities.
Administrator
Old Aug 21, 2009, 01:25 PM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
webdr,
Looks nice, I like the idea of flaps and also the cover on your tx, just one thing though, are you gonna embed the wires into the foam or tape them onto the surface of the wing ??
Simon
bignose13 is offline Find More Posts by bignose13
Old Aug 21, 2009, 01:32 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Pretty small flaps for the wing size. Could you just program flaps into the elevon function simular to what is accomplished with flaperons?
The video Tx gets hot during use so you may want to provide some ventilation.
Gary Evans is offline Find More Posts by Gary Evans
Old Aug 21, 2009, 01:35 PM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
Not unless you want to be thrown into the ground nose first
airmcn_3 is offline Find More Posts by airmcn_3
Old Aug 21, 2009, 01:37 PM
edragon is offline
Find More Posts by edragon
United States
Joined May 2008
The foam looks pretty rough. Does that make it draggy?
edragon is offline Find More Posts by edragon
Old Aug 21, 2009, 01:40 PM
Mesa, Arizona
Joined Nov 2006
Ya could be since they are on the trailing edge but wouldn't that be the same problem with separate flaps. Never mind I see you plan to link them.
Old Aug 21, 2009, 02:02 PM
airmcn_3 is offline
Moore, Oklahoma
Sure it does but not any more then the batteries, wires, transmitters ECT sticking out .
Old Aug 21, 2009, 02:08 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Originally Posted by bignose13
webdr,
Simon
All wires will be imbedded.
Also, after some good advice, I moved the flap servos forward infront of the spar and slid the elevon servos forward a bit. Pics to come...
And yes I will cut scoops for all electronics that heat up.
The wing will be fiberglassed, then covered in monocoat. it wont look rough.
Administrator
airmcn_3 is offline
Moore, Oklahoma
No not the same problem with flaps because you still have the ellevons to keep positive pitch. Flying wings do not fly slow unless you either have flaps or you fly at a ridiculous angle of attack. I guess if your wing loading is nice and low you could also fly slow. Does not tend to be our case when we stuff lots of MAh on the bird for extended flight times.
Old Aug 21, 2009, 02:10 PM
airmcn_3 is offline
Moore, Oklahoma
Good call! BTW nice build!!
Old Aug 21, 2009, 03:23 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Hi guys ,The Zephyr's foam is a 1.5 grade when the maxi only uses 1.3,the 1.5 makes it more rigid with verry little added weight.
The 1.5 requires more heat to cut and has a little more of a plastic feel to it.
I like this foam better ,it cuts more true than the 1.3 and it is way more durable,the finish is a tad rougher,it makes the glass stick better.
It makes your wing more than just a disposable plane when built rite.
Ck
klique is offline Find More Posts by klique
Old Aug 21, 2009, 05:37 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
I got the servos moved to better suit the center of gravity.
Test fit a few items.
The motor mount is glued in and I turned the outrunner around like it should be
Administrator
Old Aug 21, 2009, 05:56 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
awesome. thanks a lot for doing this. I haven't gotten around to even starting mine yet, work is killing me. I'll follow your lead on this one, I guess
by the way ... the battery cover says 3200mAh and your description says 5000mAh ... which one is it?
trappy is offline Find More Posts by trappy
Build Log The Ritewing Build Thread Atom1025 Flying Wings 12799 Jan 13, 2016 09:03 PM
Discussion Ritewing Zephyr FPV AP UAV wing klique FPV Talk 75 Oct 28, 2009 02:46 PM
Discussion From Plane to HELI FPV (Build Thread)! jetstreaming FPV Aircraft 13 Aug 12, 2009 01:40 AM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Isthmus Models Zephyr II build thread chlee Hand Launch 10 Jan 30, 2005 09:58 PM
