Old Aug 21, 2009, 08:27 AM
sp3hybrid is offline
Find More Posts by sp3hybrid
Joined Jan 2009
Question
Glow plugs for OS, GMS, ASP, Evolution and SuperTigre?
Hi everyone,
I have a few glow engines for which I would like to buy a few extra glow plugs just in case, but there are so many out there and I really don't know which ones to get. I have:
a Evolution .46 two stroke,
a SuperTigre .51 two stroke,
a GMS .76 two stroke,
a ASP .91 four stroke,
a OS AX .46 two stroke
Could anybody suggest some decent glow plugs I could get for these engines? Thanks for the help.
Sp3Hybrid
sp3hybrid is offline Find More Posts by sp3hybrid
Old Aug 21, 2009, 09:01 AM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
K&B long and the Fox Miracle plug for the 4 cycle or any of the 2 cycle engine that still won't transition well. For use in Schnuerle ported engines (what you have) avoid glow plugs with an idle bar. Idle bars should only be used with the old baffle engines! Idle bars disrupt flame propagation across the combustion chamber. This isn't a problem with the old baffle engine as that baffle already does this!
Friends don't let friends fly nickel,
Konrad
Konrad is offline Find More Posts by Konrad
Old Aug 21, 2009, 09:29 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
1, 2 and 3 - SuperTigre glow plug or H9 2-stroke plug
4 - OS F plug
5 - OS #8 or OS A3
Ivan
ivanc is offline Find More Posts by ivanc
Old Aug 21, 2009, 11:50 AM
Konrad is offline
Everett Wa.
Joined Jun 2001
To be truthful my recommendation is of little or no value taken out of context. The proper plug will change depending on the humidity (New Orleans vs Los Angeles) altitude (Chicago vs Denver) load (prop size i.e. RPM) and fuel (%nitro and oil).
I like to buy a whole range of plugs Such as the Rossi brand and then fine tune the engine using the proper plug. This is more than what most sport flier are willing to do (or pay for). My recommendations cover most sport application very well, are cheep and some of the money stays here at home. The only OS plug I like is the "F" . The #8 is good put there are many other that work just as well if not better in the same heat range.
Konrad
Old Aug 21, 2009, 04:11 PM
Joined Jan 2009
Thanks for the suggestions. I ordered a few of the suggested plugs to have some options. I live in the south, so the weather is usually hot and humid. Not sure what that means for my glow plugs though.
Old Aug 21, 2009, 04:59 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
OS#8 for the 2-strokes, OS-F for the 4-stroke.
That's pretty much all I use and have zero problems with any of my engines.
XJet is offline Find More Posts by XJet
Old Aug 26, 2009, 04:16 PM
Caphead is offline
Find More Posts by Caphead
eternal noob
Caphead's Avatar
United States, WI, Chetek
Joined Jul 2006
i second that
Caphead is offline Find More Posts by Caphead
Old Aug 26, 2009, 06:15 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I've recently tried the ASP "GP-1" 2/4-stroke plug in my 2-strokes and I have to say that it's pretty damned good so far. In fact, it's cleaned up the mid-range (a little) on my ASP/Magnum .52XLS engines.
With OS plugs costing so much these days, I may be buying a few more of these ASP plugs.
Old Aug 27, 2009, 09:54 AM
Joined Jan 2009
Where can you buy the ASP plugs?
Old Aug 27, 2009, 10:57 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
I bought an ASP #4 plug some time ago (even cheaper than a Taipan plug) but have no idea now what its heat range is. Any clues XJet?
downunder is offline Find More Posts by downunder
Old Aug 27, 2009, 05:59 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I buy mine from HiModel.
Old Aug 27, 2009, 06:01 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I don't know -- but I do know that their #5 is classified as "cold" so I expect that the #4 may be medium and the #3 hot?
Old Aug 28, 2009, 07:19 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
The proper/best glow plug sometimes can break down to just be a personal preference. I try to economize as I am on SS and a part time job at a LHS. I fly a variety of two strokes on 5% nitro ranging from an OS 32F to an ST S2000/25cc with a few Magnums and ST's in between and am happy with the Thunderbolt Heavy Duty plug. Plus they are less expensive than OS, McCoy, and a few others.
jjkupinski is offline Find More Posts by jjkupinski
Found Glow plugs for OS .40 Doubledog Aircraft - General - Miscellaneous (FS/W) 0 May 29, 2009 03:02 PM
Question What glow plugs for Evolution .36NT engine No Limits Fuel Plane Talk 11 Jan 30, 2008 12:43 PM
Sold Glow Plugs: Fox, OS, Thunder, McCoy Tram Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 24, 2007 06:10 PM
Glow plugs for 4 cycle engines jmf2001 Engines 5 Mar 19, 2004 11:23 PM
Enya #3 glow plugs for sale $5.25 each apfire Aircraft - Electric - Helis (FS/W) 0 Sep 01, 2003 06:08 PM
