Old Dec 11, 2012, 12:56 PM
edi.winter's Avatar
Tirol
Joined Jul 2009
I have a way to connect, but I am looking for a nice place to put it.
edi.winter is offline Find More Posts by edi.winter
Old Dec 11, 2012, 02:31 PM
Gartenzwerg's Avatar
Austria
Joined Jan 2007
as far in the front as possible - you want to win the photo finish, I know you
Gartenzwerg is online now Find More Posts by Gartenzwerg
Old Dec 11, 2012, 02:41 PM
edi.winter's Avatar
Tirol
Joined Jul 2009
Yes. But I stll am having trouble with traction
Old Dec 11, 2012, 05:09 PM
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
I can fit my lap-z transponder on the tank, facing up but will it run on 3,7v?
My ultra-small mr. Light Venoman compensates for the weight, covers it and as leaves room for the beam.
Again, can i power the Lap-z transponder by the single lipo cell?
z_dad is offline Find More Posts by z_dad
Old Dec 12, 2012, 12:47 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
First my experiance says that the IR (lightbeam) Transpondersystems do not work well on bikes.
The leaning angles are the problem. You pass the detector alsways at a different angle and they
seem a bit sensitive about that.
Second: just try it and plug it to 3.7V(4.2Vfreshly charged). I have never heared of electonics as
simple as a transponder exploding by undervolting it.
Old Dec 12, 2012, 02:24 AM
Tüsken's Avatar
Sverige, Västra Götalands Län, Lidköping
Joined Jan 2010
The Lap-Z will not work If you are in the lead on the last lap and you want to finish in style like the big boys on tv, take the bike on rear wheel over the finish line, your last lap will not count because of the IR. Otherwise it will work. Maybe you will miss a lap because of low power. This can happen in a mini-z car sometimes when power is low and when you are on full throttle at the same time.
Tüsken is offline Find More Posts by Tüsken
Old Dec 12, 2012, 02:32 AM
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
come on! Each racer will count their own laps, with pencil and paper. EACH LAP!
Then, we will compare notes: The one's writing that is the most beautiful wins!
Edit: And NO MARSHALS!
steliosh is online now Find More Posts by steliosh
Old Dec 12, 2012, 02:57 AM
Austria
Joined Jan 2007
I like stelios's Idea best
The Robitronic IR System works with 4 AAA Batteries on the Mini-Z Cars as well, so I don't see why they should not work on 1s Lipo as well.
Considering the typical voltage break-down of a Nimh Battery, I guess they will have more Voltage on a 1s Lipo setup than in the Cars
Old Dec 12, 2012, 03:09 AM
steliosh's Avatar
Athens, Greece
Joined Oct 2003
We also must not make the bike top heavy... it wont stand if it lays on the crashbar...
I know... I removed the tiny rider and stuck a smallish camera to try some onboard video... it was a failure! haha!
Old Dec 12, 2012, 03:19 AM
Austria
Joined Jan 2007
I guess a transponder will not hurt it, especially if you take it out of its case (when possible).
Regarding IR transponders on Bikes: With the small bikes I try to put the Receivers into a hairpin, so you are on the bars in 90% of the passings. Then mount the Transponder so it faces upright, when on that bar.
Old Dec 12, 2012, 10:20 AM
España, CL, Ávila
Joined Sep 2008
Why don´t you try a step up lipo module?
Some brands manufacture these kind of devices, designed to raise 3.7 lipo nominal voltage to BEC style 5V...
The question is...
Do you have any spare room inside those tiny bikes to hide a transponder and the step up converter?
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Dec 30, 2012, 07:41 AM
www.racerhobby.com
jumpsa's Avatar
Joined May 2012
I hope some one can help...what type of materials use for the "crashbars". How its called and usually what type of shop is selling???
I see most of you bending the crashbar in square form, compare with round type....what is the advantage of square bending the crashbars
jumpsa is offline Find More Posts by jumpsa
Old Dec 30, 2012, 10:11 AM
Austria
Joined Jan 2007
Very simple - they last longer!
Larger contact patch - less wear
Old Dec 31, 2012, 09:53 AM
Vzzznnnn...
vegos's Avatar
Greece, Attica, Athens
Joined Oct 2010
You can wire a voltage regulator from your ESC/battery (ESC is better, due to lower voltage, so less heat on the voltage regulator).
http://uk.rs-online.com/mobile/p/lin...tors/7485228P/
Ooops, edit: I thought you had to supply 3.7V from a more-than-1-cell-lipo battery...
Ignore then
vegos is offline Find More Posts by vegos
Old Jan 21, 2013, 04:40 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
I just registered that I haven´t written for over 5 weeks.
Here is the new arrangement of screws for the 2013 season compared to 2011.
Oops, must stop showing off wildpalms Parkflyers 6 Aug 08, 2012 02:46 AM
OFF TOPIC: Pics From Air Show ProLeisure Slope 1 Aug 26, 2003 01:10 PM
Showing Off Corona at Flyin Breakfast AirVenture Electric Heli Talk 2 Jul 13, 2003 01:00 PM
New prototype from China microflyer77 Scale Electric Planes 8 Sep 10, 2002 04:55 PM
Showing off with the Mini Max Vonbaron Parkflyers 1 May 15, 2002 01:14 PM
