Old Jun 01, 2012, 05:55 PM
Gartenzwerg is online now
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
I get the 0.75mm Sheets from my local "Conrad" Store (don't know if you have them in Sweden?).
For my SB-5 lower fairing I just made a template from cupboard, and used that to cut out the lexan. Then bend it over an edge (do not use heat!).
Gartenzwerg is online now Find More Posts by Gartenzwerg
Old Jun 02, 2012, 04:53 PM
Appel82 is offline
Find More Posts by Appel82
Appel82's Avatar
Sweden
Joined Aug 2010
Ok Conrad . Do you now the art number ?
Appel82 is offline Find More Posts by Appel82
Old Jun 02, 2012, 05:47 PM
trf_414_m2 is offline
Find More Posts by trf_414_m2
España, CL, Ávila
Joined Sep 2008
A tip for lexan folding.
I use to create my own fairings and undercowls. In case that lexan sheet could be too thick to easily bend it, I mark each bending line with a ballpen and a steel ruler. Now it´s time to look for an old flat screwdriver (a really ancient one with no sharp edges...) and go all ruler down pressing the lexan sheet.
If you try to bend the sheet after this, you´ll see that it bents much easily along the line without the need of a sharp edge table.
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Jun 03, 2012, 03:34 AM
Austria
Joined Jan 2007
POLYCARBONAT MC GLASKLAR 400X500X0,75MM »
Best.-Nr.: 229802 - 62
400 x 500 mm
costs 6,5 Euros
When I tried to "scratch" the material to bend it easier, it always broke very quick on the edge.
Old Jun 05, 2012, 10:12 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Note to myself:
Next time I buy steering springs check that they are the right ones and dont up my setup by using those wrong ones....
edi.winter is offline Find More Posts by edi.winter
Old Jun 05, 2012, 10:17 AM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
lol
621clay is offline Find More Posts by 621clay
Old Jun 05, 2012, 05:47 PM
España, CL, Ávila
Joined Sep 2008
Springs?
I thought you were testing rubber bands steering system too. Did you discard it?
Any comments about the rubber system?
Old Jun 06, 2012, 03:33 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Originally Posted by trf_414_m2 View Post
Springs?
I have tried close to everything.
small springs, big springs, steel, stainless springs. Rubber, NBR and silicone tubing.
ORings. Carbon blades. If I would have found a curl of Elfhair I would have made springs out of that too.
The O-Ring system works well it has its advantages and disadvantages.
Under the line either the NF or Anderson steering dampers with a good set of springs make up the most reliable assembly.
The most professional assembly is surely from RGEvolution.
Old Jun 06, 2012, 09:41 AM
España, CL, Ávila
Joined Sep 2008
If you finally get it, try to realize where the elfs have the most curly hair, and wash it properly...
Old Jun 06, 2012, 10:29 AM
Austria
Joined Jan 2007
hey, I'm doing a Skype conference here, don't make me laugh..
Old Jun 06, 2012, 11:15 AM
Jonathan Bradbury is offline
Find More Posts by Jonathan Bradbury
Occasional useful idiot...
Joined Nov 2009
I'd rather not know how you found that information out! Eeewwwww!
Jonathan Bradbury is offline Find More Posts by Jonathan Bradbury
Old Jun 21, 2012, 05:42 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Just in case your bike doesn´t stay down in a turn I made myself a checklist:
1.)Reduce Play in the steering lingage
2.)Reduce Play the Fork Assembly: Right down to the wheel. This is the "Twist" Play if you hold the wheel and turn on the top Triple.
3.)Reduce the Freeplay the springs have before they turn the Fork.
4.)Use harder springs if 1 to 3 dont help
4.a) Be sure those new springs are really harder than the previous ones
And here is what I did after 1 to 4 didnt seem to help anymore:
5.)Have a friend check out a reciever on a Professional testbed and find out it was sending unclean signals, change the Receiver.
6.)Repeat 1 to 4.
7.)Change the Gearing of a one year old Futaba Servo
8.)Repeat 1 to 4.
9.)Change the Servo
10.)Repeat 1 to 4.
11.)Find out the Radio is not centralling the Steering properly
12.)Dismantle the Radio and change the whole Steering electronics
13.)Repeat 1 to 4.
14.)Clean all the Grit and Muck out of behind the Steering wheel BEFORE sending in the bloody thing for repair
Old Jun 21, 2012, 05:08 PM
Austria
Joined Jan 2007
..and No. 14 finally solved the issue?
Old Jun 22, 2012, 02:56 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Yes it did . Quite embarrassing.
Old Jun 22, 2012, 03:04 AM
Austria
Joined Jan 2007
..especially after No.12, which seems to be pretty complicated
Oops, must stop showing off wildpalms Parkflyers 6 Aug 08, 2012 03:46 AM
OFF TOPIC: Pics From Air Show ProLeisure Slope 1 Aug 26, 2003 02:10 PM
Showing Off Corona at Flyin Breakfast AirVenture Electric Heli Talk 2 Jul 13, 2003 02:00 PM
New prototype from China microflyer77 Scale Kit/Scratch Built 8 Sep 10, 2002 05:55 PM
Showing off with the Mini Max Vonbaron Parkflyers 1 May 15, 2002 02:14 PM
