Old May 15, 2012, 11:44 AM
Manuspain is offline
Find More Posts by Manuspain
Manuspain's Avatar
Joined Feb 2007
Hi Edi
is it me or your bike sounds overgeared ?
Manuspain is offline Find More Posts by Manuspain
Old May 15, 2012, 12:01 PM
edi.winter is offline
Find More Posts by edi.winter
Joined Jul 2009
Originally Posted by Manuspain View Post
Hi Edi
No idea how a overgeared bike sounds
Overgeard means the gearing is too long or too short??
Given 1:10,0 was ideal. too long would be 1:9,0 and short 1:11,0...
edi.winter is offline Find More Posts by edi.winter
Old May 15, 2012, 02:10 PM
Manuspain's Avatar
Joined Feb 2007
i mean too long. it seems the motor is getting more and more rpm when you need to brake at the end of the straight.
Old May 15, 2012, 03:06 PM
Joined Jul 2009
Thats what I intend. I can´t stand a motor maxing out mid straight:
For me its ideal when the motor maximum revs at braking point.
It accelerates to the end. I can make it wheely at any point of the straight if
I dont limit the Amps. Its a Lehner ........................................... By the way
exactly the same motor I have been using since the Warmup last year,
all conditions, on all Tracks: from 180m length indoor to the whopping 380m in Lostallo...
just needs a bit of a change in gearing. Oh and its not a "special" one as suggested
in the spanish forum.. its commertially available to everyone....since over 10 years.
Old May 15, 2012, 03:30 PM
Manuspain's Avatar
Joined Feb 2007
What spanish forum says i think is that your motor has a modified back can, hasn t it ? Same info you gave somewhere.
Anyway, it sounds like you still have some rpm availables at the braking point, that was my feeling.
Old May 15, 2012, 03:45 PM
Joined Jul 2009
I admit that in the video I was taking it a bit easy for a safe win in the second run. Maybe obvious for your ear
The only difference of this motor is the back plate. A better way to solder the cables making the motor more compact
and less vulnerable in crashes. But no difference in performace to the normal 1920 series. I was lucky last year to ask
him about a better solution and he was just in the development of that.
The motor has enough power to backflip the bike at any point of the straight. I always try to adjust it that its always on
the edge to a wheely throughout the whole lap. That results to a steady raise in rev. from the beginning of a straight to
the end. 5 Amps more on the limiter and I am in trouble.
Old May 15, 2012, 04:53 PM
trf_414_m2 is offline
Find More Posts by trf_414_m2
España, CL, Ávila
Joined Sep 2008
...5 Amps more on the limiter and I am in trouble.
These words brought me back to some videos from F1 racing, when ground effect was the key to go fast...
One driver made a complete backflip with no injuries at all. First words he said:
"I´ve seen St. Peter calling me..."
Seems that driving your bike is stressful enough to fear anybody...
trf_414_m2 is offline Find More Posts by trf_414_m2
Old May 15, 2012, 07:44 PM
Manuspain's Avatar
Joined Feb 2007
Make a little test.
Very short gearing, and your gearing. Tell me than which make more wheelies.
Old May 16, 2012, 01:11 AM
Gartenzwerg is offline
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
..the problem with his Motor is - it actually has way too much power for a Bike. So no matter how you gear it - you always have to tame it by limiting the Amps.
This weekend was the first time I really noticed the difference between the usual 1/10 Car Motors (4.5T Star, 8T Delta) and a Lehner.
At about 60% of the straight, when my Motors screamed for Mercy, the Lehner really gave one more punch, easily gaining 5-10 meters.
But even on this track, power is not the thing that gives you a good laptime..
Tight lines, good braking and smooth power is what helps a lot more.
The slowest bike (on the straight) started from second place into the finals - driven by the youngest Driver in the field.
Gartenzwerg is offline Find More Posts by Gartenzwerg
Old May 16, 2012, 04:56 AM
Joined Jul 2009
Make a little test.
I am not sure if I am misunderstanding that you are pulling my leg .
Old May 16, 2012, 08:25 AM
Joined Jul 2009
The Warmup is coming close and I am still not prepared .
I will be on the Track in a weeks time.
AAAAAAAAAAAAAAAARGGH!!!!!!!!!!!!!!!!!!!!!
Tires for the JABBER Drivers: Alex, Helly, Irmi, Bernhard, Aaron, Panti, Steff, Willi and myself. And a set for the Austrian Nitro Driver Rudi.
Zero made 49 to go
Old May 16, 2012, 12:10 PM
Tüsken is offline
Find More Posts by Tüsken
Tüsken's Avatar
Sverige, Västra Götalands Län, Lidköping
Joined Jan 2010
Don't forget the beer
Tüsken is offline Find More Posts by Tüsken
Old May 16, 2012, 12:13 PM
Austria
Joined Jan 2007
remember to open a Window, to get enough air
Old May 16, 2012, 01:22 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
What's missing from the picture? How about a 2l size bottle of CA!
Guidoracer is offline Find More Posts by Guidoracer
Old May 16, 2012, 02:35 PM
Joined Jul 2009
Opened a new 20g tube of 406 made 14front and 17 rear.. still a fifth left in the bottle. Was a good hint to check how much glue a tire needs, thanks, a bit less than 2L. Anyway I needed 3 bottles of beer... 2 and the bottle on the picture is still full . The 4 tires on the far left with the "E" on them are my rear ones. Usually I do my tires last... (unluckally) as I started them, Simon "the Bomber" Lancaster gave me a call and I had to listen to what he wanted to tell me. While on the phone I glued them so I guess MY tires are fu'&ed, thanks Simon....anyway next is pressure test and then the last step to finish them.
Oops, must stop showing off wildpalms Parkflyers 6 Aug 08, 2012 02:46 AM
OFF TOPIC: Pics From Air Show ProLeisure Slope 1 Aug 26, 2003 01:10 PM
Showing Off Corona at Flyin Breakfast AirVenture Electric Heli Talk 2 Jul 13, 2003 01:00 PM
New prototype from China microflyer77 Scale Kit/Scratch Built 8 Sep 10, 2002 04:55 PM
Showing off with the Mini Max Vonbaron Parkflyers 1 May 15, 2002 01:14 PM
