Old Jan 21, 2012, 07:10 AM
Pescarolo is offline
Find More Posts by Pescarolo
Barcelona (Spain)
Joined Jun 2008
Edi looks good, if it works as you expect to have the invention of the car body clips is a good idea and the new accommodation for the crash bar is interesting, here in Barcelona there is a person who tried but Ruedin, but is Ruedin engages far the best slide nylon arch but had no place in the swing to be placed in the correct position.
good job, as always ...
Pescarolo is offline Find More Posts by Pescarolo
Old Jan 21, 2012, 09:48 AM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
That is very slick Edi! I would love to have those on my SB5!
621clay is offline Find More Posts by 621clay
Old Jan 21, 2012, 10:21 AM
young1670 is offline
Find More Posts by young1670
South Korea
Joined Dec 2010
Originally Posted by edi.winter View Post
Special features explanation:
Constant leaning angle over the full suspension stroke:
This means that when the bike is in a turn and the suspension compresses the crashbars stay "in position". Just take your conventional bike (disconnect the shocks) and lay it on the crashbars. When you move the suspension through its stroke you will see that the leaning angle changes.
Virtual Pivot point = zero interaction between suspension and transmission.
I dont know if this will help and make the bike better to drive this is a unknown factor. The idea is that the rear suspension is free to work whatever throttle position you are in. Full acceleration and Full brake cause a lockup of the rear swingarm.
Suspension also works while wheelying: well thats exactly what it means. When the front wheel is in the air the rear suspension can still even out the bumps. Try that with a normal bike.
Internal fairing clips (far way from those damn curbs). I have hidden the fairing clips away from the outside of the bike. This is just a nuisance on any bike and I wanted a solution to keep the bodyposts hidden. But still have a quick release clip for emergency services
These are just a few "new" features the 2012 bike has over the 2011....
Hi, edi
Thank you very much.
The more I know about your bike, the more I want to have it.
I really hope that someday I could buy your bike.
young1670 is offline Find More Posts by young1670
Old Jan 21, 2012, 12:15 PM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
Simply beautiful! Thanks, for sharing Edi!
steliosh is offline Find More Posts by steliosh
Old Jan 23, 2012, 04:16 AM
RoadRaceRiccione is offline
Find More Posts by RoadRaceRiccione
Joined Aug 2011
Hello Edi .......... but what kind of batteries you use in the new bike ..???? because (at least visually) that the two central shock in the bike hamper normal batteries hard case used up to now ......???
Or you put the short ones?
Hello Marino
RoadRaceRiccione is offline Find More Posts by RoadRaceRiccione
Old Jan 23, 2012, 04:22 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Hello Marino
Hi Marino,
I will be using the "shorty" style Lipo Hardcase you see here.
This is very risky. I do not know if this will be enough capacity.
edi.winter is offline Find More Posts by edi.winter
Old Jan 23, 2012, 05:30 AM
symon is offline
Find More Posts by symon
Joined Apr 2007
Hi Edi,
Bikes looking good!......4400 should be plenty,especially at riccione as the tracks not huge like lostello!
symon is offline Find More Posts by symon
Old Jan 23, 2012, 05:49 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
4400... you are kidding those rubbish Lipos just manage 4000. Cycled them a few times
thats the absolute max..I am not sure at all if it will be enough capacity. In Riccione I
can do approx. 38 Laps with a 5500 so maths say it should just be enough.
Old Jan 23, 2012, 05:56 AM
symon is offline
Joined Apr 2007
What are they vampire?...dont reedy do shortys?
Old Jan 23, 2012, 06:00 AM
symon is offline
Joined Apr 2007
Or these?...http://demonpowerproducts.co.uk/prod...hnology-p-6879
Old Jan 23, 2012, 06:02 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Reedy is out of stock in europe at the moment. I just got those for the meantime.
Old Jan 23, 2012, 02:13 PM
Joined Aug 2011
I do not want to do the devil's advocate ... But Gianni tried that type of batteries a month ago in Riccione and with little or no sealing of the track but managed to make over 22 rounds in October and I remember Gianni Edi did 26 laps ......... ......................
Best regards Marino
Old Jan 24, 2012, 09:43 AM
trf_414_m2 is offline
Find More Posts by trf_414_m2
Espa˝a, CL, ┴vila
Joined Sep 2008
Edi
Did you think about saddle lipos?
More capacity choices (up to 6000mAh), but you may need to move the battery tray upwards....
Current shorties measure about 96x46x25mm while saddle lipos go up to 94x69x32mm (6000mAh)
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Jan 24, 2012, 09:55 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Originally Posted by trf_414_m2 View Post
Edi
But you will need two of those saddle lipos. One saddle has only 3,7V.
The usual dimensons for saddlepacks are: approx 69x47x25.1
Under the line this is heavier and needs more room than the shorties.
I hope 4000mAh will be enough. If not: rubbish bin
Old Jan 24, 2012, 02:28 PM
Barcelona (Spain)
Joined Jun 2008
And placing the recepetor and esc on a tray on the crash bars, frees space in the center of the bike and put there the two vertical batteries?
It's an idea ...
Oops, must stop showing off wildpalms Parkflyers 6 Aug 08, 2012 02:46 AM
OFF TOPIC: Pics From Air Show ProLeisure Slope 1 Aug 26, 2003 01:10 PM
Showing Off Corona at Flyin Breakfast AirVenture Electric Heli Talk 2 Jul 13, 2003 01:00 PM
New prototype from China microflyer77 Scale Kit/Scratch Built 8 Sep 10, 2002 04:55 PM
Showing off with the Mini Max Vonbaron Parkflyers 1 May 15, 2002 01:14 PM
