Old Oct 28, 2011, 05:33 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Originally Posted by steliosh View Post
I guess you have checked it already, but... bent axle maybe?
Edit: hmmm... what have you changed to do that?
I recall the bike was plenty fast last time at Riccione... Is it faster even, now?
No, Its still the same as it used to be. Its been doing that since before Lostallo. But I had no solution at that time and was left to pray that it doesnt break at the wrong moment. In Riccione I used 8 spurgears, about one per run. Just seems to pass down to the weakest link each time I do a step forward.
Tightening the pinion less makes it fall of the motor. But I think it was just junk looking closely I saw its a cast not machined pinion.
edi.winter is offline Find More Posts by edi.winter
Old Oct 28, 2011, 05:40 AM
test driver is offline
Find More Posts by test driver
newcastle Australia
Joined May 2004
Change brands of pinions would be my approach.
Eden
test driver is offline Find More Posts by test driver
Old Oct 28, 2011, 03:19 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Wow, thats allot of power to the ground on a motorcycle.
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Oct 29, 2011, 05:28 PM
symon is offline
Find More Posts by symon
Joined Apr 2007
Hi Edi,
Its strange,because i would of thought 4wd touring cars put more power and grip through the spur gears than our bikes.??,and they dont seem to have much trouble in breaking 48dp spurs??
cheers simon
symon is offline Find More Posts by symon
Old Oct 29, 2011, 07:46 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Edi, are you breaking teeth off the 48p spurs or chewing them up? I've never broken teeth off an HPI graphite spur, even with a 3-turn motor and no slipper. Or even with a 4S pack in my speedrun bike.
Guidoracer is offline Find More Posts by Guidoracer
Old Oct 30, 2011, 11:32 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Originally Posted by symon View Post
Hi Edi,
cheers simon
I think it is because the slightest mishap directly hits the spur gear.
The drivetrain hardly has any possibility to flex.
A 4WD has softer tires then the driveshaft, Differential then a belt and then it is
at the Spur gear.....enough play and twist to compensate hard hits from the track....
Old Oct 30, 2011, 11:46 AM
Whitham69 is offline
Find More Posts by Whitham69
Whitham69's Avatar
Trowbridge UK
Joined Oct 2006
I had this when i tryed a motor on the swing arm, any small movment or twist in the swing arm stress the spur and it would fail after a while.
You use carbon plates clamped with spacers for a swing arm could be it just worn the holes alittle and your getting movent when i under load. You got alot of componants doing the job of what would normally be 1 machined piece, could be alot of things.
I doudt it going to be down to the power and grip the TC guys put more load though the gears then us on accelration and braking and they use the same stuff as us.
Whitham69 is offline Find More Posts by Whitham69
Old Oct 30, 2011, 11:49 AM
Whitham69's Avatar
Trowbridge UK
Joined Oct 2006
oh your spur gear the first thing to hit the floor in mishap, that explains it.
Old Oct 30, 2011, 12:30 PM
symon is offline
Joined Apr 2007
One thing we did used to do,with the 32dp spurs was cut a little bit of fuel tubing and put it in each screw hole on the spur gear then screw to the spur holder.acts like a bit of a cush drive......
Old Oct 30, 2011, 02:08 PM
trf_414_m2 is offline
Find More Posts by trf_414_m2
Espa˝a, CL, ┴vila
Joined Sep 2008
Interesting...
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Oct 31, 2011, 01:27 AM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
It is very common to KP bikes, before they started using the slipper... Here's my KP09 (nowadays converted to KP10), using RW spurs. Inside those washers are the fuel tubings. from Formby Models.
steliosh is offline Find More Posts by steliosh
Old Oct 31, 2011, 06:03 AM
Whitham69's Avatar
Trowbridge UK
Joined Oct 2006
Nitro's have the same problem with spur gear hitting the floor,Inside right hand curbs smash them to bits. A metal gear is the easyest solution, it add rotational mass but it wont be noticable, it will lift the wheels of the floor if it touch's, As for the belt they can fail just fun for no real reason or many reason, Im surprised if there failing every run or other run like you say your persisting with them and not swapping to chain.
anyway probily best not to take my advice as i cant stop my wankel stripping gears at the moment
Old Nov 08, 2011, 03:58 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
The Season is nearly over maybe one last race near Bologna end of November.
I won the Germany Open Indoor Masters.
2nd Aaron
3rd Marc Lutz
all RC-Bike Team Thunder Tiger
Note the cool laurel wreath we got instead of the Cups
Season Summary:
1st Rosenheim/Bavaria
1st Sollenau/Vienna
1st Kematen/Tyrol
1st Worlds Warmup Lostallo/Switzerland
2nd Aspern/Vienna
1st Kirchberg/Graz (Track for the WC 2013!)
1st Nu▀dorf/Salzburg
1st World Championship/Lostallo
2nd SaarbrŘcken/Germany
1st Riccione/SanMarino (Track for the WC2012)
1st Germany Indoor Masters /Friedrichshafen/Germany
780 Lipo charges this year equalling approx.:
130h of driving
or 15500Laps
or 3900km
Old Nov 10, 2011, 05:49 PM
zxr.750 is offline
Find More Posts by zxr.750
Joined Feb 2009
Congratulations Edi und Thunder Tiger Team Mates !
Here some more of my/our Pictures from the German Open Indoor Masters at Friedrichshafen
The young boy in the Black Shirt is my son and also drived there :-)
I`m very proud of him, because he got up in 7-Minute turns from 6 rounds on Friday up to 16 Rounds on Sunday
with his 10 Years! He was only 2 rounds back from the most next drivers and the Girls in C-Final.....
I took the 7th Place in A-Final as the only one in A-Final with real Stock Bike Configuration! (>1900gr / 17,5t BL / no Front Brake).
I also made some videos, come up next.....
zxr.750 is offline Find More Posts by zxr.750
Old Nov 10, 2011, 08:40 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
I wish there were 1/4 as many Canadians that passionate about rc bikes...
It would make it allot more fun.
Oops, must stop showing off wildpalms Parkflyers 6 Aug 08, 2012 02:46 AM
OFF TOPIC: Pics From Air Show ProLeisure Slope 1 Aug 26, 2003 01:10 PM
Showing Off Corona at Flyin Breakfast AirVenture Electric Heli Talk 2 Jul 13, 2003 01:00 PM
New prototype from China microflyer77 Scale Kit/Scratch Built 8 Sep 10, 2002 04:55 PM
Showing off with the Mini Max Vonbaron Parkflyers 1 May 15, 2002 01:14 PM
