Old Aug 20, 2009, 06:36 PM
helivsFMX is offline
Find More Posts by helivsFMX
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
What is Fan Fold Foam?
I see that home depot and lowes sell it, but what is it exactly? What do I ask for if I cant find it?
helivsFMX is offline Find More Posts by helivsFMX
Old Aug 20, 2009, 06:43 PM
may-day is offline
Find More Posts by may-day
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
Its blue foam that is in a bundle 2x4' and about 8 inches thick. When opened up it opens like a hand held fan -----------> WWWWWW each leg of the w is 2x4
Its called protection board III
may-day is offline Find More Posts by may-day
Old Aug 20, 2009, 07:54 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
What may-day said.
The blue foam consists of quarter-inch thick sheets, 2 feet by 4 feet, fifty feet long, folded in a 2x4 foot bundle, about 8 inches thick (folded).
One sheet can easily build a plane.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Aug 20, 2009, 08:12 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
ok sweet thanks guys. I'm gonna stop by lowes on the way home.
Old Aug 21, 2009, 12:34 AM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
So Lowes near me sells it. Home Depot doesnt. Is there anywhere other than lowes that sells it but not like 600foot of it? Im looking to make A plane. not 100. Any ideas?
Old Aug 21, 2009, 03:40 AM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
As far as I know FFF only comes in fifty foot bundles, folded into 25 sheets.
Old Aug 21, 2009, 06:00 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
If your Lowes has it, buy it, around here the Lowes stores have discontinued it and replaced it with some crumbly green stuff with their Lowes logo on it.
Your other option for lower quantity is Depron or EPP from one of the suppliers or Foam board from the craft type stores and then remove the paper (did it once, never again )
Azarr
Azarr is offline Find More Posts by Azarr
Old Aug 21, 2009, 07:26 AM
DaOldGuy is offline
Find More Posts by DaOldGuy
SEC. 336. SPECIAL RULE FOR MOD
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Azarr
Ouch
EPP between Dupron and foam board is not really fair.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Aug 21, 2009, 10:52 AM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Well my brother works at a place called TechLite. They do foam insulation, and carry all kinds of stuff. So Im having him check into what he can supply. He said the spec sheet for FFF says its styrofoam with plastic on one side? Is that right?
I might just have to buy a bundle anyway because I want to build an F15 too... And 14, 16, 18, 22, ..... hahaha
Old Aug 21, 2009, 11:56 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Protection Board III <FFF> is 1/4 inch with a single side with a stiff plastic coat. Its weak point is all the waves, looses strength on the 4 foot run direction.
Old Aug 21, 2009, 12:11 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
this is it right http://www.dow.com/PublishedLiteratu...romPage=GetDoc
What do you mean it loses strength in the 4ft run direction? Does that mean I shouldnt make a wingspan (30") lengthwise? Is there anything else I should know?
Do you guys just cut it with an exacto knife? or hot wire? Does the foam lose strength if you peel the plastic coat off?
Old Aug 21, 2009, 01:09 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
http://www.rcgroups.com/forums/showthread.php?t=775020 Lots of info on the stuff on this thread, as well as comparisons to other foam types. If your brother works at an insulation place, he might be able to get scraps that will get your started. I built my first plane with pink foam (Owens corning version of fff) scrounged from a dumpster! Also, if he can get it and you want to pop for a full bundle, try the High Performance LF Styrofoam fff. it's got skin on both sides, perfect for profile foamies. The skin adds lots of strength and stiffness for it's weight. The process of adding the skin in the fff manufacture seems to densify the outer layer of the foam, which also adds thickness.
The "loses strength in long direction" just means that the panels have a "grain" slightly stiffer in one direction than the other. I generally make wings the long (4') direction as the waves look (more or less) like the ribs in real planes.
If you are really nervous about getting too much foam, then try the dollar store foam first. hassle to get paper off, but for a one off first try to see if you really want to scratch build, it may be worth it
springer is online now Find More Posts by springer
Old Aug 21, 2009, 07:33 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Springer is spot on, however there is another way to look at it.
While the wave look good like ribs, the wave cause the thickness to go from 1/4 to near or below 3/16. You can roll the foam in a barrel the 4 foot way, but the 2 foot way it has much more resistance.
To get a stronger wing, I make sure the thickest part of the foam runs along the CG area of the wing, it sort of makes an airfoil, kinda This limits you to 2 foot and often a 2 piece wing.
I did some testing on WaterDog's STS high wing 43 inch, really big difference depending on the direction run.
You can wing the 4 foot direction as springer mentioned, Adding carbon fiber, KF Step airfoils and such to stiffen things up.
Old Aug 21, 2009, 08:27 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
quarter in? I measured mine and its 3/16's
GreenAce92 is offline Find More Posts by GreenAce92
Old Aug 21, 2009, 11:42 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Well I bought a bundle... So Im officially starting my simple corsair plane... Cutting out the template now. Cutting this accurately sucks! haha
what does depron and/or fan fold foam look like? Martin Hunter Foamies (Kits) 17 May 29, 2011 03:52 PM
I bought some fan-fold foam . . . what to build? emoone Foamies (Kits) 2473 Jul 11, 2003 05:48 PM
What is good for Fan Fold Foam Foam Gap Filling? RC Pete Foamies (Kits) 4 Jul 21, 2002 01:29 AM
talking german, what is fan fold foam??? Sir Lui Foamies (Kits) 7 Jul 13, 2002 01:17 AM
What is "Fan fold Foam and where to buy it? ttnissan Foamies (Kits) 1 Apr 18, 2002 11:48 PM
