If a Tiny Brite Lights set IS NOT RC Controlled, the light set turns on as soon as the receiver is powered. If a Tiny Brite Lights set IS RC Controlled, you will have the ability to control the light set using your transmitter. Our light sets are programmed to read the whether a switch, dial or stick is turned on or off, as well as the percentage, or "step," that the control is at. Explanation of Control "Steps" The LED controller within each RC controllable set has 4 distinct “steps” that are related to the percentage on the control RX channel ("switch / dial / stick" position): Control "Step" Average Percentage Example Behaviour #1 (0% - 25%): All Lights Off or Selected Lights On #2 (25% -50%): Selected Lights On #3 (50% - 75%) Selected Lights On #4 (75% - 100%) All Lights On For example, lets take a look at one of our Deluxe light sets. A Deluxe light set has 1 Red LED and 1 Green LED, a Strobing White LED for the tail, as well as 2 White landing LEDs and 1 White Spot LED. For this example we'll say that this set has been plugged into a spare channel that is linked to the shoulder dial (this is commmonly found on the Blade CX/2 transmitter). When you turn the Shoulder Dial a 25% of the way up the Red LEDs will turn on. At 50% up the the Green LEDs also turn on. Finally when the Shoulder Dial is turned 75% of the way up the White LED also turns on. Step 1 | Red & Green LEDs On Step 2 | + Strobing White Tail LED On Step 3 | + White Landing LEDs On Step 4 | + White Spot LED on |
Yeah as I researched it more for myself I found that same info. I learned that they have several switches to dim the lights and set blinking configurations to identify themselves as allies. Some lights got so hot that when sitting still on the ground they would burn through their plastic casing in 30 seconds. I am just so used to seeing planes land and take off and in the shows be it history channel or some movie they seem to always be on.
So I learned something new tonight. However the lights are still the coolest. At night if you flip them off to fire your guns your screwed because you will loose your plane during programmed blips. During the day its no more than a noticeable color. Besides if I was worried about scale I would of flipped over the airfoil of the wing. I think you will enjoy them regardless of its scale inaccuracy. It added a whole new level of fun to this hobby for me. |
Pacific Northwest
Joined Oct 2007
Now if the steps are currently programmable by the user I may already be happy but I didn't see that they were when looking at their web site. Maybe someone that has them can help me learn something new too. Question - Are the steps fixed as to what outputs come on at the various settings or is there a way to select which lights come on at each step point? |
If you look close in this video you can see it wile it's landing.
And the landing light gose in the left wheel well. Sam in Virginia |
Pacific Northwest
Joined Oct 2007
I just installed a set of Tiny Brites on my Sukhoi. I can Turn them all off, turn on red, green, rear strobe, and then the landing light so 3 functions. I'm using the Gear and Flap switch. There is also a way to make the red, green act like strobes as well. I got the #3080 kit and its nice. I embedded the red, green LED's inside the wing so it can be seen from both sides..Reme was the first to do that and it works. I just got in from a night flight and I'm totally impressed with these lights. I will post pics later in the Sukhoi thread.
| Thread Tools | |
| Discussion 15" Parkzone Micro Cessna 210 | flyingace451 | Micro RTF | 16 | Aug 09, 2007 04:11 PM |
| Discussion parkzone Micro Cessna 210 RTF | mecevans | Micro RTF | 7 | Apr 30, 2007 01:14 AM |
| Alert Parkzone Micro Cessna | Hugequark | Indoor and Micro Models | 28 | Apr 18, 2007 01:38 PM |
| New Product parkzone micro cessna | gunracer | Parkflyers | 18 | Apr 16, 2007 05:01 PM |
