Old Jan 25, 2013, 10:00 PM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Originally Posted by RealGambler View Post
Even if you don't fly at full throttle, it will happen eventually. Those little brushes will eventually burn out, even if you don't fly WOT. Sure enough, they will last longer is you don't drive too much current, but no matter what, it's a question of time. Brushless motors last forever, but brushes are brushes....
So, if you put 200 flights in one season, you're likely to change one motor, maybe two. But if you have 5 ultra-micro, and you fly them only 40 times each, sure enough, they will last a long time. But again, no matter what, eventually, you'll have to change a brushed motor....
I think the last part is why mine have lasted so long. I have four micro planes that I fly about equal time.
GBLynden is online now Find More Posts by GBLynden
Old Jan 26, 2013, 05:49 AM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Originally Posted by valiantGLX View Post
Nows a good time to upgrade it to a bravo SX motor for 20-30% more static thrust and better longevity.
RCbabbel' sells the motor ready to plug in.
V...decided to try the SX from RCbabble and test it in the P-51 with the Spit 4 blade....as it flies great now with the added pitch, a few more rpms will add to the thrust....
LICobra is offline Find More Posts by LICobra
Old Jan 26, 2013, 08:30 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Excellent I have been meaning to get one myself, however I'm currently sinking my $$$ into BL 1s setup in a gearbox I'm hoping it will deliver 70-80g of static thrust, but its too early to know for sure yet. I'll keep you guys posted
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 27, 2013, 07:56 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Even though I am for sure going with the SX, what is this BL that you speak of?
Old Jan 27, 2013, 11:30 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
http://www.hobbyking.com/hobbyking/s...dproduct=10003
that motor paired with a good BB 7mm gearbox. i belive.
nemoskull is offline Find More Posts by nemoskull
Old Jan 27, 2013, 11:54 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Close but no cigar! Thats the combo that gave me the idea, but unfortunately the 1mm prop shaft seems to be a bit of a let down. I occasionally turn my micros into lawn darts so I needed a better gearbox solution.
The new mCPX BL tail motor in the UM gearbox This new BL motor has a diameter of 8mm so with a layer of tape wrapped around it it should slide directly into the UM gearbox. Then the mCPX 9t pinion should fit the motor too so I dont need to mess around with pinion pullers
I believe the mCPX BL tail motor is 8000 and something KV, and coupled with a 6a 1s ESC it should be a winning combo. I think a 3a 1s ESC should cut the mustard though, but better to be safe than sorry. 1220 11000kv Inrunners pull around 4-6a so the 8mm 8000kv should pull less amps in theory.
Old Jan 30, 2013, 06:46 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
New BLH3904 BL UM gearbox conversion thread
Old Jan 31, 2013, 01:41 PM
nemoskull's Avatar
Joined Sep 2009
im guessing 60 grams thrust with gws 5030 @ 4v area.
we really need a ball bearing gearbox, especially iff this gets anywhere above stock thrust.
Old Jan 31, 2013, 07:34 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
So I just bit the bullet and ordered my SX motor. Fingers crossed that all goes well for me with it!
GB
Old Feb 02, 2013, 01:44 AM
nemoskull's Avatar
Joined Sep 2009
never heard a bad report about it. change the prop to a gws 5030. thrust static is 45 grams, on stock motor.
Old Feb 02, 2013, 05:06 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
I am going to go with the stock prop for now. Money is tight, so it will have to do for now
Old Feb 06, 2013, 01:30 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
I am bumping this for the guys that want this plane before it is gone. A Main Hobbies is selling them for $69.00 now!
Old Feb 12, 2013, 07:11 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
They are $65 @ Wholesale trains.
UNGN is offline Find More Posts by UNGN
Old Feb 12, 2013, 11:47 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Ah lame they are discontinuing this one too? First my Gee-bee, now my P-51, what next.... Wish I could afford a second p-51 like I did on the Gee-bee....
dacaur is offline Find More Posts by dacaur
Old Feb 13, 2013, 04:24 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Hopefully they birth a phoenix of of the ashes though!
I would love a p-51 with AS3X, clear canopy and 4 blade prop as stock I was going to build my own, but I got sidetracked with scratch building foamies.
Discussion 15" Parkzone Micro Cessna 210 flyingace451 Micro Ready-to-Fly 16 Aug 09, 2007 04:11 PM
Discussion parkzone Micro Cessna 210 RTF mecevans Micro Ready-to-Fly 7 Apr 30, 2007 01:14 AM
Alert Parkzone Micro Cessna Hugequark Scratchbuilt Indoor and Micro Models 28 Apr 18, 2007 01:38 PM
New Product parkzone micro cessna gunracer Parkflyers 18 Apr 16, 2007 05:01 PM
