I am thinking of upgrading my motor. But I don't have the money to go brushless right now. I have one of these motors from BSD laying around, does anyone know if it is better than the stock motor on the P-51?
http://www.bsdmicrorc.com/index.php?productID=848 I also have this prop for it. http://www.bsdmicrorc.com/index.php?productID=788 |
The Gravity Zero Would be cool to be bashed into a Val or a Kate (make a longer/lower Cockpit and add wheelpants) for near scale Dogfights with the UM P-51. The AR6400 brick runs the Elevator and Rudder and a Single 3 - 4g servo can work for ailerons (though I used the dual AS2000 setup). Power is a 5g 2K Kv Brushless with a lightened 10A ESC. AUW is 3.8 Oz which is about 2 Oz less than stock Cox Warbird. The best part is the painted Kit with everything in the picture (less the prop and motor shown - it comes with a brushed motor/prop) is $14+shipping from the US. I bought 3 for $50 shipped and they should be arriving today via UPS. |
Latest blog entry: AR6400 guillows Space Shuttle
See Modfly's Cox Warbird Thread
The bottom line is they appear to fly great at 4 Oz and AUW's as low as 3.5 Oz is completely possible with an AR6400. Their only drawback vs. a 1 Oz plane is you can't crash them without any damage, so attempting stunts you can pull off with a UM P-51 may not be adviseable. |
Look up RCBABBEL here on the forums he makes them, he also sells the 240mah lipos. |
http://hobbyking.com/hobbycity/store...idProduct=9727 You can also buy 250 mahr 20C cells there as well: http://hobbyking.com/hobbycity/store...idProduct=7568 Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
UK
Joined Sep 2009
If you guys are looking for some better batteries than the usual suspects, please have a look at these.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280440832505 180mAh, 15C, 4.8gram. 38mm x 12mm x 8mm. They fit the standard Parkzone charger. On test these perform very similar to the popular 6 gram 240mAh 20C cells from a popular supplier. The 180mAh 15C cells actually gave a higher voltage under a 1amp load, with very slightly less duration. |
UK
Joined Sep 2009
Yes i am.
Totally new venture. I've been modelling for over 20 years and fell in love with the new micros as soon as Kyosho released the Cessna. I was trying to buy some decent batteries for my Sukhoi soon after i got it and tried the usual cells and found them lacking. So i set to trying to source my own. I worked with a large manufacturer and these are a purpose made cell. I worked with their lab and we tried a few different cells. These cells and Miniaviation are the result. |
You have better performance than a battery with 25% more C and 20 % more capacity. The only question I have is how much are they in US dollars and how much shipping to US, in US dollars? Thanks Ron |
| Thread Tools | |
| Discussion 15" Parkzone Micro Cessna 210 | flyingace451 | Micro RTF | 16 | Aug 09, 2007 04:11 PM |
| Discussion parkzone Micro Cessna 210 RTF | mecevans | Micro RTF | 7 | Apr 30, 2007 01:14 AM |
| Alert Parkzone Micro Cessna | Hugequark | Indoor and Micro Models | 28 | Apr 18, 2007 01:38 PM |
| New Product parkzone micro cessna | gunracer | Parkflyers | 18 | Apr 16, 2007 05:01 PM |
