Old Oct 27, 2009, 11:33 AM
g35xfun is offline
Find More Posts by g35xfun
Salvaging heli parts...Again?
g35xfun's Avatar
Joined Aug 2008
Has anyone measured the weight of their P51d? I don't claim my scale to be calibrated by any means, but it seems to be accurate. In any case, without battery, with landing gears, the thing comes to 33.1g and that is with 0.3g of additional nose weight I've had to add . And I know the battery is on the order or 3.4g to 3.7g depending on make and model, c rate, mah etc. The box/label claims that P51d is 34.6g. Is that the AUW? With or without battery? With or without landing gear? Is the nominal 34g an estimate? I suppose the question is what should be weight limit, not to be exceeded, when tweaking with the bird?
BTW for comparison, my su-26m weighs in at 31.4g with landing gear without battery and the box is labeled for 34g. So is parkzone reporting high weight to be conservative or are they reporting low? Because 31.4+3.6(for battery) is 35g.
g35xfun is offline Find More Posts by g35xfun
Old Oct 27, 2009, 12:46 PM
mcharles13 is offline
Find More Posts by mcharles13
Jaded Flyer
mcharles13's Avatar
United States, FL, Clearwater
Joined Aug 2004
Originally Posted by SabreHawk
Two things, or a combination of will have a plane porpoiseing.
Way out of trim, or way out of balance. better to adjust the balance as its the more likelyhood its the problem. If a plane is in balance, it should fly perfectly well with the elevator dead level.
What the plane is doing is "hunting" for its optmum airspeed, and overshooting it each time.
In my case it was out of trim. After all my adjustments with the subtrim (quickest option in the field) the elevator was only then completely level.
mcharles13 is offline Find More Posts by mcharles13
Old Oct 27, 2009, 01:18 PM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Mine with the battery and the light mod came in at 32 grams.
Orion Pax is offline Find More Posts by Orion Pax
Old Oct 27, 2009, 01:56 PM
tulz43 is online now
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Anyone have any close up pics of the lights installed? Just wondering how the wire looks and lights mounted.
tulz43 is online now Find More Posts by tulz43
Old Oct 27, 2009, 02:46 PM
Orion Pax's Avatar
Joined Dec 2006
I can take a photo under my wing on how it is all ran tonight when I get home if you would like.
Old Oct 27, 2009, 04:18 PM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Cool...that would be great.Thanks
Old Oct 27, 2009, 05:09 PM
SabreHawk is offline
Find More Posts by SabreHawk
Off we go.............
SabreHawk's Avatar
Seattle, WA. USA
Joined Jan 2006
Aye, on second thought yes the trim is more likely as iin the case of this particular model, as its more in the hands of the user than the CG is.
Glad ya got it snorted, errr sorted.............sorry.
SabreHawk is offline Find More Posts by SabreHawk
Old Oct 27, 2009, 06:30 PM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
I had the same problem. I just bent the bend by the control horn a little more. Flew great this morning even in some gusty wind.
On another note... what exp are you all running, if any?
Old Oct 27, 2009, 06:41 PM
Orion Pax's Avatar
Joined Dec 2006
Batteries died while taking photos. I will download them as soon as I get the battery charged.
Old Oct 27, 2009, 06:47 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I have been running into this kind of flying characteristic. See:
http://www.rcgroups.com/forums/showp...postcount=1183
I've had to add weight to nose to get that damped out. I not sure if it is better to add weight, or squeeze the elevator linkage and have significant bit of down elevator relative to the horizontal stabilizer just to fly sort of neutral with the servo centered.
Do you have the battery as far forward as you can get it? I got rid of most of the porpoising on mine just by moving the battery forward.
dacaur is offline Find More Posts by dacaur
Old Oct 27, 2009, 07:17 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Mine is 32.2 grams RTF with the landing gears (and main gear mounting plates removed.
Old Oct 27, 2009, 07:45 PM
Jaded Flyer
mcharles13's Avatar
Joined Aug 2004
Originally Posted by tulz43
...On another note... what exp are you all running, if any?
Currently no D/R no Expo. Next flight i'll work in some D/R not sure if i'll need expo yet.
Old Oct 27, 2009, 07:54 PM
MicroTex is offline
Find More Posts by MicroTex
I need a BIGGER lvng rm!
Conroe, Tx
Joined Oct 2006
clear canopy
A couple pics of my clear canopy. Makes it look a lot less "toy" like IMO.
MicroTex is offline Find More Posts by MicroTex
Old Oct 27, 2009, 08:05 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
nice..how did you do that?
modfly is offline Find More Posts by modfly
Old Oct 27, 2009, 08:31 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
...and are you going to be marketing those?
Dora Nine is offline Find More Posts by Dora Nine
Discussion 15" Parkzone Micro Cessna 210 flyingace451 Micro Ready-to-Fly 16 Aug 09, 2007 04:11 PM
Discussion parkzone Micro Cessna 210 RTF mecevans Micro Ready-to-Fly 7 Apr 30, 2007 01:14 AM
Alert Parkzone Micro Cessna Hugequark Scratchbuilt Indoor and Micro Models 28 Apr 18, 2007 01:38 PM
New Product parkzone micro cessna gunracer Parkflyers 18 Apr 16, 2007 05:01 PM
