Old Aug 19, 2009, 05:02 AM
seedo is offline
Find More Posts by seedo
Plane crasher
seedo's Avatar
Joined Jun 2007
Build Log
The old EDF Mirage 2000 with new build
Hi Guys
Before 2 years i got from Hobby-lobby.com the EDF Mirage 2000 RTF,,,,,,
its sucks
once i fly the thing it fall and crash there was a little breeze though
so i got another one but just a kit with the new "gold color motor" the old one was blue, i changed the ESC but i run it with full throttle it started to generate red smoke from the speed control i gave up.
so that was before 2 years now i decided to run it again but with new electronic build, so he so far what i have now:
- transmitter & receiver radio control futabu programmable
- the body of the plane very new didn't fly yet
- the old blue motor and the gold one ( with squealing noise )
- servos ready
- landing gear
- charger
- 2 lipo batter 1300 mAH 11 V
- 64 mm duct fan unit
- balancer
now we need 2 things that will determine how good the Jet will fly
Motor
ESC
now the old motor "the gold one" use to drain 175 watt and it a 4200 KV
and the ESC 18 amp
so i want to go with something better and i need to share me your ideas
here what i have in mind i will post the links for the motor:
Elite 400 4200 KV
or should i get this
Elite 400 3700 KV
and for the ESC
25 A i think is good right?
so please can u think with me and tell me idea or useful links to purchase motors & ESC
i will provide pictures later of the Jet
Thank you
seedo is offline Find More Posts by seedo
Old Aug 19, 2009, 11:36 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
no one want to share?
Old Aug 19, 2009, 11:37 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
Old Aug 19, 2009, 11:38 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
Old Aug 19, 2009, 03:14 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
here is some pix for the mirage that am talking about
don't know but suddenly all the exceed motors that i was thinking of buying are out of stoke so i made more search and yes i found goooood motors for the mirage and ESC as well
check them out
HXT 3790 KV
XHT 4850 KV
XHT 4400 KV
for ESC
turnigy 25 Amp
tower pro 25 Amp
Hobby king 25 Amp
am also thinking of getting a ESC program card
so guys what you think now, which ones will fit more?
i will provide more info more
Old Aug 19, 2009, 03:58 PM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
Get a motor in the 4500kv range that can run on 3s lipo and get a higher C rated lipo, should pull about 25amps. Would fly fine.
cray2602 is offline Find More Posts by cray2602
Old Aug 19, 2009, 04:04 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
thank you for your respond
i have 3cell lipo 1300 mAH 11.1 V is this ok you think?
Old Aug 19, 2009, 04:27 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
ok for a battery is this good?
Zippy 5000mAh 3 cell 11.1V
Old Aug 19, 2009, 05:30 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
5000 mah is likely too heavy.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Aug 19, 2009, 05:50 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
Id stick with the 3s 1300mah but get one rated for 25C, most stock batterys are 15C maybe 20C. The higher the mah capacity the heavier the battery, best to stick with the size it was intended to use.
I have some of these batterys and they have excellent performance-
http://www.hobbyking.com/hobbycity/s..._25C_Lipo_Pack .
Old Aug 19, 2009, 05:54 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
i think you are right
Old Aug 19, 2009, 05:55 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
thank you man very usefull
Old Aug 19, 2009, 06:04 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
ok i think we are done with the battery
now the motor, think with me please do you think what i want is right?
i think i will need the 4850 KV one i posted up
what you think?
also guys i will really appreciate any more ideas like program card for the ESC or something else anything i want it to be maximum fun
i will video it
also am thinking of spraying the mirage with shiny thing for foam to give it a reflective look cool right!
if things go good i will add retracted landing gear and some leds (lights)
i feel this thread will be useful for other people maybe, i hope so
Old Aug 19, 2009, 06:19 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
i have a question cant i get just edf unit with no motor?
i need advices please
Old Aug 20, 2009, 12:52 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
no advice!!!
Discussion New Ultrafly Mirage 2000 with a FRP fuselage youngseokshin Electric Ducted Fan Jet Talk 12 May 17, 2008 12:34 AM
Balance trouble with new build bigbear3721 Fuel Plane Talk 24 Feb 23, 2004 10:40 PM
WTB Wattage Mirage 2000-5 new or used mlehman Aircraft - Electric - Airplanes (FS/W) 6 Dec 13, 2003 09:12 PM
Need help with new build spaced Electric Ducted Fan Jet Talk 1 Oct 23, 2003 05:28 AM
Mirage 2000 with landing gear? webnetxpress Foamies (Kits) 8 Jan 27, 2003 10:16 AM
