I just used this technique on my old Turbo I'm also restoring. The results were poor. It did not fill the area I was after, and the foam that did expand into an area I wanted to fill fell off as it had no adhesion to the wood, and below that were large air voids. I'll be smearing the area with some microballons. My buddy showed me his cleaned up repair and it looks pretty good. I forgot to take a picture though.. |
Latest blog entry: FrSky at the Toledo R/C Model Expo -...
Interesting..
Hobie Q's
Exciter and all;
Nice thread, thank you. I just picked up a hawk and will prepare it to fly. My question(s) is; it came with a large aluminum wing rod. Is this acceptable to use, or should I find something else.. carbon, etc.?? Also, should the dorsal part be reinforced in any way, or is stock ok? Thanks in advance for your time. John |
the aluminum rod is just fine- you can substitute it for something else if it's bent, but the general concensus is they it allows the wings to flex rather than break. The stock tail is fragile to a point, but plenty strong if it is still intact and not cracked or poorly repaired. Remember, it's pretty much an antique! Lol good luck, and thanks for the post! |
San Bernardino, California, United States
While the aluminum may help prevent wing damage, they are a P.I.A. to remove from the fuse once they are bent. I used to replace them with steel ones, but I can't remember if that caused more cases of wing damage or not.
What would be nice is one that could flex some under crash loads then spring back. Carbon or glass? When I bent one so bad I couldn't remove it I had to hacksaw it off and get a new one. But if you're patient and creative you can straighten it while it's still in the fuse. |
I'll be honest, and tell you that there is a 5/16" stainless rod in mine, but I know that I'm not gonna flog the hell out of it- just be careful of winch launching it, and pouring on the g's from diving/looping and the stronger ones are cool-
my "default" is to recommend what's "supposed" to be, or better. |
I think a popular replacement is something like 7075 alloy. It can bend under load, but is very hard to actually bend and keep bent.
I need to do a little research and see if that is the right alloy.. |
Well, I broke down and finally nabbed a great looking Hobie this week. No restoration required on this baby (yet). I'm really stoked!
All I did was replace the old 72mhz radio with a 2.4Ghz rx, and replaced the old slider power switch with a blackjack plug for external charging and power-switching, Tonite, check the CG and washout, and she's basically ready to go. Even my wife likes it. She says it looks like a piece of art in our living room. (I agree!)
mdine1us - I hate you too.
Great looking plane, and you wife is right, it looks great on your coffee table. Just sent a lot of cash off for a tail assembly so I can get back to work on mine. Lets just say the price of these parts has gone way up! Ran into a great example at Long Beach on Sunday. Was flying with an equally nice looking Aquilla (sp?). Didn't bring my camera though.. Be warned - the Hobie at Long Beach had been recovered recently. Even though the plane had no damage history the wing now has flat spots - Why you ask? Well, he used the new Monokote, and it required a lot more heat to pull the wrinkles. The heat melted the foam. You have been warned. We plan to use Ultracoat on ours. -Wayne |
Lomcevak
I think I spelled it right... Anyway I remember a day flying a Hobie in an east wind on Table Rock Dam near Branson, Missouri. It was a great day with 10-15 mph wind and thermals.
In those days (early/mid '80's) I was young and very go-4-it. I flew my Hobies with the CG at the aft limit (19"?) and plenty of throw on the surfaces. No computer radio, in "normal" flying the top of the stick never moved more than 1/8"-3/16". And my snap rolls were wild... I was flying in a "spirited" manner. Some guy showed up with a Sig Ninja, fresh on the market at that time. He marveled that I had a faster roll rate than he did... My flying buddy says "Hey Steve, show this guy your lomcevak." So I found a thermal and got her way up there, I'm sure no less than 300' over. Vertical dive, when she got level with us she was really moving. I eased the stick back to bring her to a vertical climb with minimal speed loss... Then I pulled full left and full up. Hobie was a blur, spinning wildly. The climb stopped immediately but all that energy was now in a rapid positive G spin, with Hobie on her back. As she fell she wanted to nose down, but the gyroscopic forces interfered, and the result was a combination of spin and tumble, really wild. Recovery must have used 100' at least. It looked very much like the famous maneuver seen at airshows. Ninja guy just shook his head in disbelief. Yep, them Hobie Hawks were really something. |
| Thread Tools | |
| Question Hobie Hawk - what's it worth? | Thermalin | Sailplane Talk | 2 | Jun 03, 2008 09:17 AM |
| Discussion Hobie Hawk, what's it worth | bigjohn | Sailplane Talk | 0 | Feb 16, 2006 07:48 PM |
| FS: Hobie Hawk(s) and 10 foot wing set | CactusJackSlade | Aircraft - Sailplanes (FS/W) | 1 | Nov 04, 2004 09:15 PM |
| Veteran Hobie Hawk Get's New Pilot/Intro | webguyjv | Thermal | 11 | Jul 12, 2004 02:07 AM |
