Old Aug 18, 2009, 07:20 PM
hlaija51 is offline
Find More Posts by hlaija51
Joined Jan 2009
Question
Turnigy 28-26-CQ 1300Kv Brushless Outrunner motor trouble
Hello,
I have rescentailly purchased a Turnigy 28-26-CQ 1300Kv Brushless Outrunner from hobby city (http://www.hobbycity.com/hobbycity/s...ess_Outrunner). And I can't find anyway of putting a propeller on it because the shaft is to thick and short to mount a direct drive propeller or adapter yet too thin to put a prop saver adapter on, what should I do? (I am on a tight budget.)
Jason
hlaija51 is offline Find More Posts by hlaija51
Old Aug 18, 2009, 07:43 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
It looks like the picture?
If so, it appears you need to replace the set screws with longer bolts (3mm?) to use an o-ring or rubber band for a prop saver...
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 19, 2009, 08:34 AM
hlaija51 is offline
Joined Jan 2009
yes the motor looks identical to the picture.
what bolts are you talking about (could you point to it on a picture please)?
Are they on the side of the shaft, and if so can I get these parts from my local hobby shop?
Old Aug 19, 2009, 11:11 AM
hlaija51 is offline
Joined Jan 2009
about how much will that cost me?
Old Aug 19, 2009, 11:31 AM
Ierwin is offline
Find More Posts by Ierwin
Germany
Joined Jun 2009
I think Gene is referring to the screw(s) marked in this picture.
If there os one of these screws on oposite sides you can just replace them with regular screws and have your built in prop saver.
Should be M2 or something so I guess you should get those at the LHS for a few cents.
Ierwin is offline Find More Posts by Ierwin
Sold AXI 2212-26 GOLD brushless outrunner motor super cheap! shschon Aircraft - Electric - Power Systems (FS/W) 1 Nov 30, 2008 04:21 PM
Sold AXI 2212-26 GOLD brushless outrunner motor cheap! shschon Aircraft - Electric - Power Systems (FS/W) 3 Oct 21, 2008 10:30 PM
Question Help find manufacturer for HXT 28-26-B 1350Kv Brushless Outrunner beca Power Systems 5 Jan 11, 2008 08:06 AM
Sold Axi 2212/26 Brushless outrunner motor New in box Lammergier Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 01:35 PM
FS: Axi 2212/26 Brushless Outrunner Motor PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 3 Nov 25, 2004 12:40 PM
