View Poll Results: Which quadrocopters and/or tricopters do you fly?
Aeroquad 219 6.53%
Alien Jump Jet 49 1.46%
Alien Saucer 35 1.04%
Draganflyer DF-IV 35 1.04%
Draganflyer DF-V TI 24 0.72%
Draganflyer Experimental Brushless (Spectrolutions) 39 1.16%
Draganflyer X6 32 0.95%
Quadpowered 282 8.41%
Microdrone 58 1.73%
Mikrokopter V1.0-ME 104 3.10%
Mikrokopter V1.0-ME with NAVI 195 5.82%
Mini-Mixer quadrocopter 50 1.49%
Mini-Mixer tricopter 30 0.89%
Self-build quadrocopter flight board/firmware 1,608 47.97%
Self-build tricopter flight board/firmware 786 23.45%
UAVP 76 2.27%
UAVP-NG 26 0.78%
UAVX 75 2.24%
Walkera UFO #4 35 1.04%
Walkera UFO #5 47 1.40%
Walkera UFO #8 40 1.19%
X-BL 33 0.98%
X-BL FunPilot 25 0.75%
X-BL Autopilot, ReasearchPilot, Hornet, Hummingbird, Falcon 14 0.42%
X-UFO 69 2.06%
Y-UFO LA Heli 25 0.75%
Y-UAVP 18 0.54%
Y-UAVX 30 0.89%
Multiple Choice Poll. Voters: 3352. You may not vote on this poll
This thread is privately moderated by jesolins, who may elect to delete unwanted replies.
Old Nov 09, 2012, 09:37 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Help please. I bought a KK compatible board from value hobby. Good price and looks fairly easy to use, I thought. It came with 2 wires. One is a regular wire with male to male ends. The other is a male plug on one end and the other end has 3 male plugs one on each wire. I know these are for the rx to board connection but how do I do it? Thank you for any help I can get.
Tom
carr52 is offline Find More Posts by carr52
Old Nov 10, 2012, 07:46 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Tom,
Please ask your question in one of the listed KK threads under the Index at the front of this thread under Project Quads/Hexas/Octos. Someone there will be better able to help you with specific setup info for your KK board.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Tom
jesolins is offline Find More Posts by jesolins
Old Nov 10, 2012, 08:07 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Will do. Thanks Jim.
Tom
Old Nov 21, 2012, 07:07 PM
MIDNCOCO is offline
Find More Posts by MIDNCOCO
United States, CT, Glastonbury
Joined Feb 2010
I am writing my masters thesis paper on the construction of a tricopter drone. One of the design requirements are speed. I did some testing on various motors and propeller combos for found that it is a trade off between lift and pitch speed(which factors into forward speed). So I notice for the size tri I am building most people are using a 9x4.7. With the motor I am using it gives you 1100grams of thrust and a pitch speed of 41 mph. I increased to a 10x8 and got the same thrust, but with a pitch speed of 46.7 mph. Of course there is a difference of 4 amps between the two. Does anyone have any other prop recommendations for speed on a tri. I placed the two props on my tri and also noticed the difference in speed. I have a 2.5 lbs tri and am trying to maintain to 2.5-3:1 thrust to weight ratio.
MIDNCOCO is offline Find More Posts by MIDNCOCO
Old Dec 06, 2012, 09:06 AM
eagle19 is offline
Find More Posts by eagle19
Joined Mar 2012
http://www.hobbyking.com/hobbyking/s...ame_625mm.html
About to order this Turnigy Talon Hexcopter
Not sure about landing gear and camera mount......please suggest............
eagle19 is offline Find More Posts by eagle19
Old Dec 06, 2012, 09:41 AM
jesolins is offline
Joined Feb 2007
Hi E,
I have never had one of the HK Talon frames, but others have liked them. The price sure has jumped from the $29 quad Talon frame...
SeismicCWave has some good information on camera mounts and vibration isolation. Here are some camera mount threads that will help you decide.
http://www.rcgroups.com/forums/showt...t#post20079729
and
http://www.rcgroups.com/forums/showt...t=camera+mount
Cheers,
Jim
Old Dec 06, 2012, 10:13 AM
eagle19 is offline
Joined Mar 2012
Originally Posted by jesolins View Post
Hi E,
and
Cheers,
Jim
Thanks for the reply....
i am new to this hobby...
Can You please configure an entry level quad ....
AP with my samsung camcorder is my goal......
Old Dec 06, 2012, 10:42 AM
jesolins is offline
Joined Feb 2007
E,
Since you are new, it is more important that you learn safe procedures and then to fly and maintain and trouble-shoot multicopters. There are many options in diameter size and lifting capability and price ranges that must match your requirements. Perhaps you should start out by learning on one of the many mini or micro quads first and use them as training before you start flying with a camera that can be easily damaged in "hard-landings". That way you will have only spent about $50 and will learn quite a bit and gain some flying and rebuilding skills and trouble-shooting knowledge.
Cheers,
Jim
Old Dec 06, 2012, 11:21 AM
eagle19 is offline
Joined Mar 2012
E,
Cheers,
Jim
Yes but
The problem is I am from INDIA.....
and its not so easy to import so frequently because of several kinds of taxes and postage charges....
and also you cant import any electronic items even simple motors and lipos need permission from govt to get custom clearance...
thats the reason i want to import a frame first ,then i would use local made electronics
Old Dec 06, 2012, 08:22 PM
Cobra68 is offline
Find More Posts by Cobra68
Cobra68's Avatar
United States, WA, Ravensdale
Joined Jan 2011
I can't speak for the Hex frame... but I have the quad frame and can tell you that the quality is excellent! The frame is strong and sturdy, and when set up correctly, it flies GREAT! I put a NAZA +GPS on mine, and it's rock-solid!
Cobra68 is offline Find More Posts by Cobra68
Old Dec 07, 2012, 07:57 AM
eagle19 is offline
Joined Mar 2012
even i was trying for the quad......its out of stock.....
Old Dec 07, 2012, 07:58 AM
eagle19 is offline
Joined Mar 2012
http://www.goodluckbuy.com/360-degre...00-model-.html
any reviews and thoughts about this
Old Jan 21, 2013, 02:21 AM
figgoat is offline
Find More Posts by figgoat
CunningStuntsFPV
figgoat's Avatar
Greenland
Joined Dec 2012
An archive of mammoth proportions, of both man and machines. Have read from whoa to go, and all i can say is, thanks Jim. I fly a MWC Stealth Reconn http://www.multiwiicopter.com/produc...uad-fpv-reconn
Thanks for the time you have put into this reference/wiki. I am 12 months into the multirotor side of rc flying, having flown helis for about 3 years, and i have found this thread so informative....this thread has answered where i have not asked....Thank You.
Cheers Glenn. Gold Coast, QLD, Australia.
figgoat is offline Find More Posts by figgoat
Old Feb 12, 2013, 12:58 PM
mnemennth is offline
Find More Posts by mnemennth
AMA 1033652
mnemennth's Avatar
United States, TX, Houston
Joined Jul 2012
Jim -
Thanks for scoping out my "Toy-Quad Hackery" ("Toy-Quackery") project; I figured I should stop by and check out... *FAINT*
*Slaps self awake* ... your archive of Quad-Related stuffs & notes. Dude... this this is MONSTROUS!
* Sets a tick in his mental appointment book for this weekend to come back and learn sumthin' *
mnem
Toys: Big, little, short or tall... I tell you, I love 'em all...
mnemennth is offline Find More Posts by mnemennth
Old Feb 27, 2013, 04:42 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
You forgot OpenPilot in the pole
gitit20 is offline Find More Posts by gitit20
Data Quadrocopter and Tricopter Info Mega Link Index!! jesolins Multirotor Talk 625 Yesterday 07:27 PM
Discussion Quadrocopter/tricopter NAV Lighting Ideas tend2it Multirotor Talk 10 May 19, 2015 03:54 PM
Poll Quadrocopter and Tricopter Info Mega Link Index!! Poll additions. jesolins Multirotor Talk 8 Jan 08, 2015 08:17 AM
Poll Quadrocopter and Tricopter Info Mega Link Index! jesolins Coaxial Helicopters 0 Aug 13, 2009 12:38 PM
