Old Apr 13, 2003, 08:41 AM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
Throttle Tx end point adjustment and ESC
Hi
What I wanted to do:
Without changing the prop, I wanted to draw less amps from my motor.
For that, on my T9CAP, I moved back the end point of the throttle to 50%. It worked as I was doing it, but I have the impression each time I turn on and off the Tx that the controller finds the new endpoint and gives me the 10% power, even with a reduced throttle end point.
Is it true?
Can I do something else on my Tx to correct it?
Thx
luc is offline Find More Posts by luc
Old Apr 13, 2003, 11:56 AM
seanm is offline
Find More Posts by seanm
Joined Sep 2002
Idea....
I JUST got a 9C and don't know exactly what to do, BUT I think if you somehow make the throttle full throw when you arm the ESC and then throw a switch (like dual rates) then the ESC would see it as a lower setting.
Not sure how to do this on a 9C yet, but I will learn as it sound like an interesting way to get some extra flight time for those of us with heavy left thumbs.
Sean
seanm is offline Find More Posts by seanm
Old Apr 13, 2003, 12:33 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
No matter where you set your EPA the ESC senses the total movement and sets itself for full throttle based on that! All you are doing is decreasing the amount of stick movement to go from off to full! Not a good move! The throttle stick slides! Just decrease your throttle to a setting you like... that's why it slides!
boomer
boomerace is offline Find More Posts by boomerace
Old Apr 13, 2003, 12:48 PM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
Boomer, Thnat's what I thought, unfortunately
Sean, that's a very good idea and I will test it. I think it might work, because once the esc has found the total curve, then I can decrease the throttle movement thru a switch.
Old Apr 13, 2003, 02:04 PM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
Unfortunately, on the 9CAP, the throttle does not accept dual rates, and I don't know how to program something which can do it.
If anybody has an idea....
Old Apr 13, 2003, 02:10 PM
seanm is offline
Joined Sep 2002
Idea....
(duplicate..sorry... Must have left a window open or something)
Sean
Old Apr 13, 2003, 02:12 PM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
I found it: on p.60 of instructions, in the mixing setups, there is something called "dialled as master" which allows to assign a switch linked to another channel.
It works!
Thx for the idea
Old Apr 13, 2003, 10:26 PM
seanm is offline
Joined Sep 2002
(Big grin)
I have not scratched the surface of my 9C....Looks like it is pretty deep.
Glad to hear it worked.
Sean
Old Apr 13, 2003, 10:33 PM
Peter Khor is offline
Find More Posts by Peter Khor
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
Do a Throttle-to-Throttle mix, when you throw the switch, the new end point is programmed to be lower than initial setup, no offset (a multipoint mix with graphic display helps). Also great for those ESC (eg, Cermark, FMA, Zagi) that go WOT at 1/2 stick.
Only thing you need to remember is to power on the plane (when the ESC inits.) with mixer switch off.
Peter Khor is offline Find More Posts by Peter Khor
Old Apr 14, 2003, 02:35 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Two things:
First - limiting current draw by never going to full throttle is NOT good for the ESC. Heating in the ESC is the worst around 70-80% power. Change the prop!
Second - some ESCs rescale their throw to whatever they get from the transmitter, some don't. Most have some minimum throttle "throw" they must have in order to get to full throttle (it is usually pretty small). So whether or not you can do what you want (even though it's hard on the ESC) or not depends on whether you have a fixed-endpoint or self-adjusting type.
BEC is offline Find More Posts by BEC
Old Apr 14, 2003, 03:58 PM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
BEC, I think you are right.
I tested the throttle to throttle mixing. Works great on jeti 18A and mega, but not really on the astro020 and his castle esc. On this one, I have first to go full throttle and then to use the switch; If I don't go full throttle, the switch does not work...strange.
Well , I have ordered smaller props, but in these diameters, they are not ez to find (4.7*4.1 or 4.2), as I already draw close to 20A with a 4.7*4.7 cam prop.
Thx
End point adjustment circuit ATV for simple 2 channel TX polar bear DIY Electronics 23 Dec 11, 2006 02:45 AM
Question T6XAS - Throttle End Point Adjustment? Helicool Radios 2 Apr 01, 2005 02:46 AM
End point adjustment problem mountain flyer Parkflyers 3 Jun 20, 2003 07:01 PM
Dual rates and/or end point adjustment? Peter Young Fuel Plane Talk 4 Aug 18, 2002 04:08 PM
Can Hitec S81 servos take 125% end point adjustment? Balin Electric Plane Talk 7 May 31, 2001 04:23 PM
