Old Aug 17, 2009, 05:48 PM
Clayton Wheaton is offline
Find More Posts by Clayton Wheaton
Team Performance Hobbies
Clayton Wheaton's Avatar
upstate New York
Joined Feb 2006
Build Log
Great Planes Sequence F3A build thread
Hey everyone,
Just received my sequence a couple days ago in perfect condition and decided to do a build/flying log on this cool little pattern ship. To start off the quality is great and the fit and finish of this ARF is amazing! I’m pleased to report all the hardware is of good quality and the amount of pre fab work is a big plus! for my set up ill be using a rimfire .32 out runner with a silver series 45amp esc, castle BEC, futaba s3150 servos and a r146dp receiver, I know its over kill but its just sitting here lol Here's how it all looks out of the box;
Clayton Wheaton is offline Find More Posts by Clayton Wheaton
Old Aug 17, 2009, 08:02 PM
upstate New York
Joined Feb 2006
Ok here it goes! the first thing I like to do when I build a plane is get it sitting up on the gear so its not rolling all over the work bench, all that was required to do this is slide the axel on the LG leg and screw down the 5mm lock nut, then a nice little spacer to keep the wheel from rubbing on the pants. After that are the wheel and wheel collar, and finally the pre drilled pants finish off the LG assembly. All of that is secured to the LG plate in the fuse. The tail wheel assembly is slick and very light! It all rides on nylon bushings to keep things smooth and lasting a long time.
Old Aug 18, 2009, 02:08 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Is it out in the shops yet?
Up&Away is offline Find More Posts by Up&Away
Old Aug 18, 2009, 07:11 AM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Tower said that they shipped their first ones out in March. But not sure if that was just for sponsored pilots? I just saw it for the first time in a Tower magazine they sent me.
STLAV8R is offline Find More Posts by STLAV8R
Old Aug 18, 2009, 07:12 AM
STLAV8R is offline
STLAV8R's Avatar
Joined Jan 2009
Are you going to use 1 elevator servo or 2?
Old Aug 18, 2009, 08:42 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Looking good!
BoneDoc is offline Find More Posts by BoneDoc
Old Aug 18, 2009, 09:20 AM
upstate New York
Joined Feb 2006
Thanks guys!
Yes the sequence is in shops now, it should have arrived mid last week if your LHS preordered it. I'm using one futaba s3150 on the ele mounted in the fuse with the rudder servo on pull-pull. If you use the recommended servos this is more than enough. I'll be building more today but now I need to run to the LHS and grab a couple things for the sequence and my Venus 2.
Clayton.
Old Aug 18, 2009, 09:40 AM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Is this even slightly a 3D airplane? Kind of figured the Sport section might make more sense for this thread. Mine just showed up for a FlyRC review. Looks nice!
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Aug 18, 2009, 12:21 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
It's not on their website yet.
Old Aug 18, 2009, 12:32 PM
upstate New York
Joined Feb 2006
Here is the link to towers site hope this helps!
http://www3.towerhobbies.com/cgi-bin...?&I=LXWWM1&P=7
Clayton.
Old Aug 18, 2009, 07:05 PM
upstate New York
Joined Feb 2006
So the next thing to do was to get the anti-rotation pins in the wing and get the elevator squared up and glued in using 30-min epoxy, the instructions do a great job of guiding you through this so im’ not going to go into great detail here. After the epoxy is cured you can go ahead and hinge the elevator half’s making sure that the elevator joiner is inserted fully into each half and is adjusted as needed to make sure that the half’s are level, my kit required no adjusting of the joiner. So far so good!!!
Clayton.
Old Aug 18, 2009, 07:17 PM
upstate New York
Joined Feb 2006
Now that already to this point I couldn’t resist putting the whole thing together and taking a few pictures with its big brother, I cant wait to fly this thing!
Clayton.
Old Aug 18, 2009, 07:25 PM
upstate New York
Joined Feb 2006
Here’s a shot of the canopy hold down system its really simple and effective, there are 2 pins in the front that slide into the slots as normal on many planes, but the rear is really cool. There are 2 hooks that slide down, forward and lock with 3 magnets in the back. There is no way that thing is coming off in flight!!!
Old Aug 18, 2009, 07:52 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
Looks good!!
heligrom is offline Find More Posts by heligrom
Old Aug 23, 2009, 11:17 AM
STLAV8R is offline
STLAV8R's Avatar
Joined Jan 2009
How is the build going?
Great Planes Yak 55 Build Thread p51flyer 3D Flying 90 Jul 10, 2010 07:12 AM
Build Log Another Great Planes Rapture 40 Build Log OrlandoP Fuel Plane Talk 68 Nov 22, 2007 07:15 PM
Discussion Great Planes P-51 Build in Progress!! =) Gravitus Fuel Warbirds 22 Dec 25, 2006 05:43 AM
Great Planes Spirit Elite build tips wanted cynjon Sailplane Talk 18 Jul 30, 2005 04:23 PM
Great Planes RV4 wing build question MAKODS Parkflyers 11 Apr 19, 2005 09:48 AM
