Old Dec 22, 2011, 06:39 PM
anthodenn is offline
Find More Posts by anthodenn
anthodenn's Avatar
Virginia Beach, VA
Joined Nov 2006
Actually I made mine into a pusher BUT haven't flown it yet or have the rudders on yet for that matter. And I still need to more secure the stick mount stick from torque twisting a little. I've ram the stick up its behind but on top a little. I also glassed the whole jet too like some have in the thread.
The set up I'm using is a Scorpion SII-3020-1500 Custom from Lucien Miller from Innov8tive Designs, Inc.(great guy) with a Mystery Pentium 60amp w/no Bec. I'm using a 5amp UBEC. Btw, I'm using a 3300mah 4s. After running it up holding it, it is well over 1to1.! I It will clime out!
Look, everyone, I'm a little scared to fly it after reading the thread this past year so don't rush me. I trying to take my time right now. I just want the c of g at factory which to my understanding is give and take nose heavy/ perfect/ just right for flying this particular forward swept beauty.
I have the landing gear installed. Not sure if I will use them if any cause don't have access to pave runways/parking lots. I fly in grass fields so more than likely it will be a belly lander. Who knows, I might just rip them out later, just don't know yet. I would put up some pics of my plane but right now I have to go somewhere. Will talk later.
Anthony
anthodenn is offline Find More Posts by anthodenn
Old Dec 22, 2011, 10:41 PM
Sockrat is offline
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
Originally Posted by benjo View Post
Theres no problem with having a big pusher!
Well, it might be. The point where throttle force is applied moves back 1ft. It's certainly not a problem when it moves forward but here I believe it will make plane way more sensitive and agile. Although there are videos of profile su-47 with 1-2 props in the back. I guess as long as you don't give it full throttle at launch it should be manageable.
Sockrat is offline Find More Posts by Sockrat
Old Dec 25, 2011, 01:37 PM
davidgp is offline
Find More Posts by davidgp
Joined May 2009
can anyone confirm that T-Pro MG90 servos (hobbypartz) fit the servo openings correctly? I have a lot of types of 9G servos and most do not fit correctly. The distance above the mounting tabs needs to be 10-11mm
davidgp is offline Find More Posts by davidgp
Old Jan 13, 2012, 01:41 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
Originally Posted by dirdredd View Post
Seems under powered once you got air born. Just didn't look like the fans were pushing hard enough and she looked nose heavy. did you check your CG before flying?
true, i swped out teh EDF's for the ones in the Mig-29, seams like 2x the power.
Wargassm is offline Find More Posts by Wargassm
Old Jan 13, 2012, 02:14 PM
Wargassm is offline
Wargassm's Avatar
Joined Nov 2010
Originally Posted by DaveBC View Post
Yeah mine goes thru a 5000mAh pak in five minutes
odd, i find that i had to add around 100g of weight to tail so i coudl use some thunderpwoer 2x3s 4400ma 45c and 65c.
fortuntely i found some Genace 4000ma lipos the same weight as the stock 6s 3600ma. Flies a little faster and seams more responsive with less weight.
My only thing onthe plane is its difficult to do a loop with no TV. almost stalls at the top. All surfaces are @ recomended settings.
hopefully will find out soon enough.
Old Jan 23, 2012, 04:13 PM
Sockrat is offline
Canada, AB, Calgary
Joined Oct 2010
Aren't stock fans identical in these?
Regarding batteries my stock MIG is 75Amp, SU with 2500kv Cyclone motors 105 Amp. This tells me 4000 30C battery is more than enough. Ordered 4500 25C nano-techs for Mig for lower voltage sag.
Old Jan 23, 2012, 07:42 PM
MiG-3 Reno Rocket is offline
Find More Posts by MiG-3 Reno Rocket
Haul ass! Turn left sometimes
MiG-3 Reno Rocket's Avatar
United States, ID, Idaho Falls
Joined May 2011
Both of these happen to be 10mm from mounting tab up.
I used these Corona 939MG http://www.hobbyking.com/hobbyking/s...oduct=14459for all servo locations except the canards.
I used these Corona 928BB for the canards http://www.hobbyking.com/hobbyking/s...dProduct=10344
Hope that info helps!
H-V-A
MiG-3 Reno Rocket is offline Find More Posts by MiG-3 Reno Rocket
Old Feb 05, 2012, 10:30 AM
ConcreteTurtle is offline
Find More Posts by ConcreteTurtle
Eternal Sub, Heli/Plane Newb
ConcreteTurtle's Avatar
Sydney, Australia
Joined Jan 2009
Hi guys,
I've recently bought one of these bad boys, already built by it's previous owner. As our club flies off grass, I'm wondering what replacement retracts would suit?
I did try the search function but to no avail.
Thanks all, great thread
ConcreteTurtle is offline Find More Posts by ConcreteTurtle
Old Feb 05, 2012, 01:05 PM
Joined May 2011
Originally Posted by ConcreteTurtle View Post
Hi guys,
I have wondered this myself. Also thought about bungee launching it, but man that defeats the scale feel and look of this beautiful machine taking off and landing.. Also the experience of landing on the wheels safely after a nice flight is a great feeling!
Old Apr 27, 2012, 06:58 PM
dirdredd is offline
Find More Posts by dirdredd
Dir_D_Redd
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
looking for a nose retract. pm me if you are willing to sell
dirdredd is offline Find More Posts by dirdredd
Old Apr 29, 2012, 01:45 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
subscribed
Bravo47 is offline Find More Posts by Bravo47
Old May 14, 2012, 11:18 AM
comelit79 is offline
Find More Posts by comelit79
comelit79's Avatar
Italy, Lombardia, Bergamo
Joined Mar 2012
hi,
I need help with the links of a Sukhoi Su-47 ..
The question may seem stupid but I can not be solved around ...
Then the wires coming into the receiver and connected them as follows:
Spektrum receiver Ar8000:
Ch1-Thro - Throttle
Ch2 Aile - Aileron
Ch3 Elev - Elevator
Ch4 Rudd - Direction
Ch5 Gear - retracts
Ch6 Aux1 - Bomb Door
Ch7 Aux2 - Empty
Ch8 Aux 3 - Empty
so far is correct right?
hours arrival to the problem ...
the model also has this cable should be the UBEC is correct?? where do I connect it to the receiver?? :
By comelit79 at 2012-05-14
also this mysterious cable .. I do not know what it is .. seems to come from the front door of the reach truck ... but it is not the wire of the cart ... What is it? where do I connect it?
I hope you can help ...
thanks,
Fabio
comelit79 is offline Find More Posts by comelit79
Old May 14, 2012, 02:47 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Lit79, mines half built. I cant help,(amnesia). I wont do any further work till I get more ram space in my brain. Lee
capt soap is offline Find More Posts by capt soap
Old May 14, 2012, 04:58 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
That seems to be correct. You can connect it to the battery input of your receiver, if it has one, or to any free channel output, if any are left free. If all channel outputs are used by servos, you can connect a y-cable to it and the servo and connect the single end of the y-cable to the receiver. In each case, you will have supplied power to the receiver.
That cable connects to a landing light which is mounted on the front retract. You can connect it to a free output on the receiver, or also via a y-cable. Or you can simply leave it unconnected, of course.
Hope this helps,
Henrik
hklagges is offline Find More Posts by hklagges
Old May 15, 2012, 05:43 AM
comelit79's Avatar
Joined Mar 2012
Hope this helps,
Henrik
thank you so much...
you solved my doubts,
Fabio
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1568 Dec 14, 2015 01:20 PM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 12:29 PM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 08:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 01:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 10:20 PM
