Old Oct 12, 2011, 02:11 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Very interesting data points - and surprising! How heavy is your aircraft? You must have saved a little weight by not using the TV units (3 servos plus a bit), but that should not make the difference. How heavy is your battery, please?
And btw I had the ailerons and elevators on individual unmixed channels, too.
Will you rebuild the gears or hand-launch?
Cheers and happy flying,
Henrik
hklagges is offline Find More Posts by hklagges
Old Oct 12, 2011, 05:33 PM
Sockrat is offline
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
Henrik
Almost 2.5kg with 690g battery (http://www.hobbyking.com/hobbyking/s..._6S1P_40C.html).
Static thrust 2.4kg.
It was slightly nose heavy within 5-10 clicks but that's without nozzles and chute.
I think what added to roll stability is that I halfed ailerons. Forward-swept wing has higher lift near the root than regular ones so playing with lift during turns is dangerous. Full-length aileron kills all the lift in one wing and causes stall on the other at some point. What happens next is tip-stall even at decent speed. And useless canards which are too close to CG on the model to do any elevator work but are really good at breaking airflow at wing roots add to this. You add some elevator during turn and plane suddenly stalls...
I connected canards to have around +-10 degrees at maximum.
I experienced that plane was self-leveling from the turns with stick in neutral and required barely any elevator for quite sharp turns. Didn't try any 3d. I flown it in loops at 60-70% throttle for about 3 minutes and the feeling was like a big fast solid plane with 2m wingspan. There was ~20km/h wind and su-34 I flew right before was quite searching up/down when against the wind. This one was going rock solid as if it's calm. I guess an extra kilo and more rocket-shape play the role.
I'll rebuild the wheels. Already ordered servoless retracts and metal legs from HK. Don't want to handlaunch it mostly for safety. One of my stock fans exploded before during bench test at full throttle and a couple of pieces penetrated through the foam, rest made small dents on the wall 3m away. The launcher person must have gloves and goggles at least.
Sockrat is offline Find More Posts by Sockrat
Old Oct 13, 2011, 11:51 AM
Mtn_Commando is offline
Find More Posts by Mtn_Commando
Mtn_Commando's Avatar
United States, CA, Dublin
Joined Sep 2008
Hello all,
My SU-47 is no more. I'm selling the SAPAC MB1 motors and fans, and the Castle 100A esc's. PM me if anyone is interested. Good luck with this beast, it's quite a handful!
Mtn_Commando is offline Find More Posts by Mtn_Commando
Old Oct 13, 2011, 12:09 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Commando, Is it repairable? what survived the crash?? Lee
capt soap is online now Find More Posts by capt soap
Old Oct 13, 2011, 03:42 PM
Joined Sep 2008
no crash. I "decommissioned" it (took it apart since I was moving out of state, it was too big to take with me). what's left is motors, edfs, esc's, rx, servo extensions, and nose retract.
Old Oct 13, 2011, 04:05 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Thrust vector noozels, and vector hardware??
Old Oct 13, 2011, 04:24 PM
Joined Sep 2008
nope.
Old Oct 14, 2011, 02:39 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Ouch Aua Aua !
Mtn_Su-Killa !
Old Oct 14, 2011, 12:52 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Wow, some crash if the tail componets are damaged. PHOTOS?
Old Nov 18, 2011, 09:10 PM
MiG-3 Reno Rocket is offline
Find More Posts by MiG-3 Reno Rocket
Haul ass! Turn left sometimes
MiG-3 Reno Rocket's Avatar
United States, ID, Idaho Falls
Joined May 2011
Originally Posted by Oger Lionel View Post
Those pics, ARE FRICKIN AWESOME! LOL GREAT JOB! THEY LOOK COOL!
MiG-3 Reno Rocket is offline Find More Posts by MiG-3 Reno Rocket
Old Dec 21, 2011, 05:32 PM
Sockrat is offline
Canada, AB, Calgary
Joined Oct 2010
I have compared thrust on my RTF MIG and SU-47 I've build from kit with CS480-2500kv Cyclone power motors and was quite surprised. At full throttle:
MIG: 2.2kg thrust, 75amp
SU: 2.2kg, 105amp
(my elevation is 1.2km above sea level)
Both use stock fans and no TV nozzles or thrust tubes. The only explanation I see is that SU has an expansion area after edf where esc are located. After all, thrust is the difference of speed between air coming in and out of the plane times mass. So, looks like expansion and contraction in that area behind the edf causes 25% power loss. I'll add a 55mm coffee cup mod to nozzles and see how thrust changes.
I hope it's not due to Cyclone motors being less efficient than LX stock...
Old Dec 21, 2011, 05:49 PM
Joined May 2011
SU: 2.2kg, 105amp
YES! Please do post the results! I would love to see them and see what might be able to be done to mine as well. Thanks Sockrat!
Old Dec 22, 2011, 03:52 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
This would work wicked as a pusher, one motor, one esc, no retracts, the thrust of a prop, imagine what it would fly like.
benjo is offline Find More Posts by benjo
Old Dec 22, 2011, 02:47 PM
dirdredd is offline
Find More Posts by dirdredd
Dir_D_Redd
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
That would be a big pusher. This guy holding that SU-47 has to be well over 6'1"
dirdredd is offline Find More Posts by dirdredd
Old Dec 22, 2011, 04:52 PM
benjo is offline
benjo's Avatar
Joined Aug 2009
Theres no problem with having a big pusher!
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1716 Jun 06, 2016 11:21 AM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 12:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
