Hi guys!
I'm Brazilian and I've just set up an SU-47 Berkut by Banana Hobby. I am accompanied this post to make adjustments before the first flight. I also had great difficulty in adjusting to cover the landing gear, especially the nose gear, but I guess I did ... Here are some pictures: ![]() ![]() This is my first EDF airplane!!! Here the video of the endurance test of the landing gear. Our track is bad, just dirt!
And here I found the solution to the port of landing the nose gear...
Canada, AB, Calgary
Joined Oct 2010
- Thanks Lord that by half, thanks Lord that by half... - Excuse me, what do you mean by "by half"? - mv^2 by half. I remember this each time I crash my foamie and think how it looked like if plane was 4kg instead of 2.
my plan for strenthing the retract pad was to eather fiberglass, or use carbonfiber rope, and make a good strong base. I was then thinking of adding a peace of very thin ply to the other side and running 2 or 3 screws throw the plastic retrac base throw the fiberglass/foam to the wood. do you think this is to much?
I'm pasting a wooden lite ply base on it will stick the landing gear which will then be secured with four screws. I'm shooting and then post the pictures here ... |
That sounds good, that way there is a wider foot print for the retract. I have not flown this bird yet so any real world results are greatly appreceated. Iron Mike |
A lot of force can be transmitted over the gear surface as it is. If you strenghten that so that it won't break, it will break next to the rim of your strengthening pad. Just my opinion, ofc :-). Cheers, Henrik |
I respectfully disagree with Henrik on this issue. This and almost all of the LX models require extensive gear housing rework. Even the stock AC is easily able to handle an additional 60 grams of weight distributed over the three gear bases. I see no value in flying fast if when you touch down you rip the gear out of the housing.
Two hour of work during the initial build saves many hours of tedious repair when the eventual failure happens, and it absolutely will happen, if not today, all too soon. Save the weight where and when you can on non-essential systems but NEVER skimp on the important stuff. Cheers and happy flying. Joe |
Canada, AB, Calgary
Joined Oct 2010
My view on the LX landing gear is it can handle very strong vertical impacts, strong front impacts and barely any side hits. This is especially bad for dual-wheel front gear which can hit a stone with just 1 wheel. If you steer sharp at high speed or land at crosswinds there's a good chance to strip gear off like on the video above. How epoxy binds to flexible plastic surfaces we all know... Therefore adding some side support rods or plywood on the back side might be essential.
I badly crashed my 1m AMX jet twice due to landing gear detaching seconds before takeoff - it's unrecoverable when your plane takes off and spins. |
Berkut = 12 sec flying!!!
Good morning fellow model airplane! (06:04 AM)
![]() I need your help. I was flying my Berkut this weekend but the result was not very good. I'm putting the video for you to analyze and to tell me what is wrong. The CG is at 30mm.
I'm working to recover the aircraft. Disney |
Hello Disney,
So the biggest news is: Power the beast UP. Don't fly it at 50% throttle. Fly it at 75%, or maybe a bit less when it is already fast and flying level. And the next news is: This plane is easily overcontrolled. So dial in expo or change the mechanical links to the elevators and canards to a position where the control surfaces deflect less for a given servo input. Cheers, Henrik PS: I don't think the CG was particularly bad. With power, it should have flown, with the occasional time spent in drop-my-tail-mode. |
CG looks ok. Damage doesn't look bad. Good luck with the next flight. |
| Thread Tools | |
| New Product FreeWing 70mm F-35 w/ Thrust Vectoring | bhatch21 | Foamy EDFs | 1104 | Apr 19, 2013 09:32 PM |
| Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet | MikeysRC | Foamies (Scratchbuilt) | 2 | Aug 05, 2009 11:29 AM |
| Discussion SU-35 or any twin EDF with thrust vectoring | dash8pilot | Electric Ducted Fan Jet Talk | 11 | Jul 21, 2008 07:32 AM |
| Discussion Wicked thrust vectoring twin turbine mig-29 video | lavochkin | Foamy EDFs | 5 | Jun 12, 2008 12:07 PM |
| Build Log Mig-35 Twin EDF w/ Thrust Vectoring | tailslide5_0 | Foamy EDFs | 23 | Aug 27, 2007 09:20 PM |
