Old Feb 01, 2011, 06:49 AM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
a few pages back, i read someone is using a sapac mb1 and 5's lipo. so total of 10's in the canopy??? it should be way over 1:1 thrust right? also how did you the lipo's to fit in canopy?.
f4addict is offline Find More Posts by f4addict
Old Feb 01, 2011, 01:14 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Its a single 5000Mah 5s 30C battery. The motors and ESC are soldered together to make one wiring harness. Kind of like a 'Y' from the deans plug to each ESC and to the motors. The reciever wire gets a 'Y' also and a UBEC installed and any built in BEC's disabled.
This pic doesen't show it all. But you can see where I soldered ESC directly tomotor and the RED and BLACK wires join together and run up the center.
DaveBC is offline Find More Posts by DaveBC
Old Feb 02, 2011, 03:32 AM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
The esc's and wiring look top notch!
Dark Angel is offline Find More Posts by Dark Angel
Old Feb 02, 2011, 05:00 AM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
@davebc, the wiring looks clean as hell. thanks for the info.
Old Feb 03, 2011, 08:38 AM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
Ok guys, Im starting late on this bird, and I need to make an order on hobbyking for all the Servos I will need.
What are some HK servos you guys like?
Thanks Mike
mikes68charger is offline Find More Posts by mikes68charger
Old Feb 03, 2011, 10:43 AM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Thanks Mike
Hxt900 or the corona series (929mg etc.) I can recommend.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Feb 03, 2011, 11:16 AM
Joined Jul 2010
Cool, I really like the Hxt900 but I have not seen this bird in person, and I was not sure it was strong enof for such a big bird. I guess I could use my D-MG16 on the elvevator just to be safe,
Thanks Iron Mike
Old Feb 03, 2011, 11:24 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
On the raptor, the hxt900 needed a little foam to be cut to get them to fit. The coronas however drop right in, and come in analog and digital metal geared varieties.
Thanks Iron Mike
Old Feb 09, 2011, 08:04 PM
dirdredd is offline
Find More Posts by dirdredd
Dir_D_Redd
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
If this is a bad setupfor my SU-47 KIT. PLEASE,PLEASE,PLEASE. Let me know something.
I am looking at running a 5s power setup. If something is wrong with this setup. Please Tell me.....................
2-http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idproduct=7341
2-http://edfhobbies.com/index.php?route=product/product&path=66&product_id=150
8-http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idproduct=662
6-http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idproduct=6608
Thanks Guys
dirdredd is offline Find More Posts by dirdredd
Old Feb 10, 2011, 02:32 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Hello,
The most important thing is missing: The fans. Are you using the stock fans? From my experience (2x Su-47), they are really bad quality (see the photos I made and posted at the beginning of this thread). If you build the kit, the biggest single favour you can do yourself is using better fans, e.g. Wemotecs.
Apart of that:
The ESC looks good but oversize.
The motor should be bought in conjunction with your fans, preferably built-in and balanced.
HXT900s have been mentioned in this thread.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Feb 17, 2011, 09:07 PM
davidgp is offline
Find More Posts by davidgp
Joined May 2009
I finally bought a new airframe so I'm building a new SU-47. Should I buy the whole Wemotec Mini Fan Pro or just the rotors? I've got the stock motors already but could upgrade is necessary.
davidgp is offline Find More Posts by davidgp
Old Feb 18, 2011, 11:48 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Greetings,
Buy the whole! Really. The price is ok for the high quality you get. And the stock SU-47 fans are just too bad.
Whether the stock motors fit: I don't know. If it has similar specs like a HET2W25, which you would need to check out, why not?
Cheers,
Henrik
Old Feb 23, 2011, 06:32 PM
Sockrat is offline
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
need advise on battery
I have ordered this kit and would like to get some help on what battery to pick up.
So far I think about 2500kv cyclone motors:
http://rc-castle.com/shop/product_in...oducts_id=1616
and 6s 5000mah battery:
http://www.hobbyking.com/hobbyking/s...idProduct=8582
Motors will add 100g in the back (compared to stock) and battery will probably compensate for it being 750g.
Has anyone flown with 6s 5000mah battery by chance? Is it possible to match CG or take the battery out after you squeezed it in?
Sockrat is offline Find More Posts by Sockrat
Old Feb 23, 2011, 10:45 PM
Joined Jul 2010
You should not have any issue with the 5000mah lipo as I have seen others run a 5000mah lipo, but the lipo you chose has too low of a C rateing. 20c is not good for the lipo or the bird, go with at least a 35-40c lipo.
Old Feb 23, 2011, 10:53 PM
Joined Jul 2010
Thanks Guys
Im going to run the exsact same set up, Same ESC, You need to get a good EBC. Also for $10 more on the motor they sell the fan and all blanced. IT is really worth the money, the stock Sapac fan makes great thrust down low.
The only issue is the lipo, on 5s your looking around 68amps each motor, its going to take a real strong lipo to power both motors, or you will choke the motors down with to small a lipo.
Im going to use 2 http://hicountryhobbies.com/index.ph...roducts_id=133
From the testing I have read these are the best lipos for the money unless you want to spend $275 for TP Lipos. I was told these lipos are better than than XPS lipos.
At 136amps
Also 6800mah / 136000 * .8*60= 2.4 min at wot, so I figured I could get away 3 1/2-4min flight time.
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1693 Apr 14, 2016 07:36 AM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 12:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
