Old Jun 08, 2010, 01:49 PM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
Anyone flown their birds recently?
FOX ONE! is offline Find More Posts by FOX ONE!
Old Jun 23, 2010, 08:53 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Check out this guy here:
http://www.xwing-crew.ch/index.php?o...86&video_id=34
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Jun 23, 2010, 09:11 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
LMAO, who needs a dolly when you can take off on the gear and jettison it after takeoff?
Sid3ways is offline Find More Posts by Sid3ways
Old Jun 23, 2010, 10:02 AM
Jammo is offline
Find More Posts by Jammo
London
Joined May 2010
What the hell happened there? Why did it dip so much after take-off?
Jammo is offline Find More Posts by Jammo
Old Jun 23, 2010, 10:26 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Probably overcontrolling... with all these control surfaces the Su-47 is incredibly agile.
Cheers,
Henrik
Old Jun 23, 2010, 10:56 AM
Jammo is offline
London
Joined May 2010
Makes sense.
Old Jun 23, 2010, 02:35 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Looked like it needed an insane amount of trim and the elevators/canards weren't at the right neutral angle to begin with. Either that or he put a cinder block under the canopy.
Old Jun 30, 2010, 03:48 AM
maxsky is offline
Find More Posts by maxsky
Joined Jan 2010
Awesome with the cow's bells in the back
It gives a godd idea of switzerland lol
maxsky is offline Find More Posts by maxsky
Old Jun 30, 2010, 06:59 AM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
Mtn_commando, how did your maiden with tuning gyro's go?
The guy in the video was trying to loose some weight off the plane so instead of doing all the hard word, he found a easy method. Just rip the landing gear and doors off.!!!:-)
f4addict is offline Find More Posts by f4addict
Old Jun 30, 2010, 08:17 AM
Mtn_Commando is offline
Find More Posts by Mtn_Commando
Mtn_Commando's Avatar
United States, CA, Dublin
Joined Sep 2008
No maiden yet, been unable to find time. Will post a report as soon as she takes to the air.
Mtn_Commando is offline Find More Posts by Mtn_Commando
Old Aug 01, 2010, 01:55 PM
Joined Sep 2008
Ok gentlemen, I finally maidened her yesterday. The delay was because I was looking for a paved runway. I finally joined a club that has one.
Actually, I had cold feet so I asked one of the field experts to maiden her. AUW was 2750 grams. All gyro gains were at 0%, and thrust vectoring was kept off.
First takeoff was aborted because she ran out of runway (around 100 feet). Ran into the grass and that caused the front retract to dislodge. With some 5 minute epoxy, she was ready to go again.
Second takeoff, we started right at the beginning of runway, allowed her to pick up good speed and lifted off like a rocket in around 150 feet. VERY tail heavy, said the pilot! Also very touchy on the controls. We knew immediately that we had to bring her back down, the pilot was struggling to keep her under control (and he's a GOOD pilot). Power was enough, but it was way tail heavy and that made it very hard to control. Easing back on the throttle caused her to nose up dramatically, almost looking like a cobra .
Anyway, he was finally able to get her down. Landing was a little rough, she came down almost vertical on her tail. Thrust vectoring nozzles dislodged and both of the rear retracts snapped right at the wheel. But the rest of it is unscathed.
So, looks like I overcompensated for the CoG. I had it at about 3.5-4 cm (so 1-1.5 cm behind factory setting), and that was definitely too much. On a positive note, the repairs are easy. Looking forward to getting her back in the air next weekend. I'll be extra careful to keep CoG exactly at 3cm.
She was definitely a head turner though
Old Aug 01, 2010, 02:09 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I'd have used the gyros.
That's the trick on Tail heavy planes!
Good to know it lives to fly another day, better luck next time!
SU-4ever is offline Find More Posts by SU-4ever
Old Aug 01, 2010, 02:37 PM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Hello there,
thanks for the field & damage report. Some comments below.
You can shorten the takeoff distance enormously by switching the TV nozzles on. With them, you can (or at least I could, and I have a Su-47 with a similar AUW as you have) rotate after 10-15 meters (30-50 feet).
Regarding the tail heavyness: This plane seems to be really tricky. You had it at "1-1.5 cm behind factory setting". When I tried it at 1.5cm behind factory setting, it was tail-heavy as yours - terrible. But when I had it at the factory setting, it seemed nose heavy to me - where is the sweet spot? Maybe some pre-trim of the control surfaces (canards 3 up, elevators 1 down) would help more than moving the CoG backwards?
Regarding the touchyness on the controls: Absolutely. It is easy to overcontrol it. I am considering to remove roll from the canards and elevators and have it only on ailerons and tv nozzles.
The head-turner effect is there, but that means there is even more pressure on the pilot!
Cheers,
Henrik
Old Aug 01, 2010, 02:40 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Leet's see what happens with the Gyros, I'm really interested in your results!
Old Aug 01, 2010, 03:10 PM
Joined Sep 2008
Hi Guys,
Thanks for the feedback. SU-4ever, did you mean you have used gyros on this plane? Or on some other plane? How were your results?
Henrik, since 2.5 cm is too forward, and 4 cm is too far back, I guess the logical thing to do is keep it at 3.25cm. Have you managed to work out a setting that somewhat works? I think i'm going to reduce throws by 50%, maybe increase expo from 35% to 50%
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1693 Apr 14, 2016 07:36 AM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 12:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
