Here's the video. I had fun with the wing bending of the plane.
http://www.rcgroups.com/forums/showt...2#post15164337 |
Well it was the first flight of our clubs twins comp. blassted out and threw it around for about 2 minutes before the high speed low level. leveled out from a dive, motor stopped and i had nothing, the thing ballooned up to 50 feet, stalled and blew its self apart 10 meters from me. motors and ecs's were the only thing ok, post mortom. The deans (plane side) was removed from the ECS leads very cleanly and was still plugged into the battery, no fracture,tear or anything. Therory? i think the wires got that hot during the flight they melted off the back of the deans plug. the solder was very dry and the tac spot was not the entire rear ot the connector. pissed me off. must have had 50 flights with it and to go in on a comp. how imbarrasing!!!!!
I loved that plane |
I hear ya, just got mine back in the air after modifications. removed allthe gear doors and painted the U/C mat black. rewired the ailerons for roll only, not an easy task as i got the ARF version. Sunk some 4mm square CF tube into the full lenth of the wing to eliminate the flex. Removed the TV nozzeles ( a discision made when i had my beautiful 34) and reduced the outled nozzels by 3mm. the thing flys beautifully and more importantly, no gear doors hanging down.
Man these @#$ gear doors. My hat is off to the Lanxiang workers who can make these facking things work.
One thing's for sure, my next edf (probably the LX Mig 29) will be purchased RTF. So much nicer to fly make minor mods and just go fly. This one's almost complete. Pics coming soon. Going to the Jones Beach air show tomorrow, so planning the maiden for Sunday or Monday. |
Have a good first flight. Cheers, Henrik |
Hello Gents,
No maiden yet, hopefully tomorrow. AUW is around 2715 grams. CoG is around 3.5cm behind factory line. I have added all three gyros. The gyros are rate, and stabilize TV servos only (no surfaces). Maiden will be done with 0% gain. The gyro sit under the cockpit, which is removable. This cockpit size is almost perfect scale for this model. Here are some pics: . . . |
What I meant was it's 3.5cm total, so 1 cm behind factory setting.
No maiden yet, it was windy and couldn't find time. Next weekend. I had initially planned on housing the gyros right above the receiver, but then it would have been sealed inside the fuselage and I wouldn't have been able to access it for modifying gain. Then I thought about housing them within the edf access hatch block, but that would have been too much vibrations. So the only place I could think of was the cockpit, even though it puts it away from the rotational axis. I'm thinking I can make it work by playing with the gain. I plan to maiden without any gain to see how she behaves and trim it out. Then i'll dial up the gyros and see if they make any difference. |
| Thread Tools | |
| New Product FreeWing 70mm F-35 w/ Thrust Vectoring | bhatch21 | Foamy EDFs | 1105 | Jun 11, 2013 03:36 PM |
| Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet | MikeysRC | Foamies (Scratchbuilt) | 2 | Aug 05, 2009 11:29 AM |
| Discussion SU-35 or any twin EDF with thrust vectoring | dash8pilot | Electric Ducted Fan Jet Talk | 11 | Jul 21, 2008 07:32 AM |
| Discussion Wicked thrust vectoring twin turbine mig-29 video | lavochkin | Foamy EDFs | 5 | Jun 12, 2008 12:07 PM |
| Build Log Mig-35 Twin EDF w/ Thrust Vectoring | tailslide5_0 | Foamy EDFs | 23 | Aug 27, 2007 09:20 PM |
