Old May 21, 2010, 04:08 PM
Mtn_Commando is offline
Find More Posts by Mtn_Commando
Mtn_Commando's Avatar
United States, CA, Dublin
Joined Sep 2008
Originally Posted by hklagges View Post
Hello F4Meister,
Well, you built it that way and have the flying experience with the bad nozzles, then I believe your advice in this case :-) and withdraw mine.
By the way, in this link posted by a Lanxiang representative in the Mig-29 thread, you can see very impressive photos of the new Mig-29 and the new nozzles that Lanxiang is using:
http://www.lxhm.us/en/products_show....&id=169&flag=0
The new ball nozzles look like Freewing nozzles, and the way the pushrods are connected, looks like the Freewing Su-34, too. Much better.
Cheers,
Henrik
PS: It seems that our beloved Su-47 is already old !
Damnit Henrik, why did you have to show us that
Ball linked nozzles, flaps, leading edge slats, lights, ejector seat, integrated electric retracts, missiles, 17 servos, drogue chute wowow!!!
Well, not until I've flown the crap out of the Berkut, probably next year...but wow!!!
Mtn_Commando is offline Find More Posts by Mtn_Commando
Old May 22, 2010, 06:19 AM
Detlef is offline
Find More Posts by Detlef
Detlef's Avatar
Germany, Ladbergen
Joined Dec 2006
Grrrrr.....Mig 29....another real russian beauty....decisions, decisions...
Detlef
Detlef is offline Find More Posts by Detlef
Old May 22, 2010, 11:34 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
OMGOMGOMGOMGOMG!!!
Thatt was fu***n awesome!!
Videos, I want to see videos!!!
SU-4ever is offline Find More Posts by SU-4ever
Old May 22, 2010, 01:50 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Hello there,
Here is a link with 48 seconds. The plane is not in the air, but you can still see some movement of the control surfaces:
Giant Mig-29 Lanxiang www.ready2fly.eu (0 min 48 sec)
Pro: Everything moves! I particularly like the slats and flaps. I wonder how much they allow to slow down the plane for approach and slow flight? If it really can fly slow, that is a BIG plus for the bad grass fields we have.
Contra: Ailerons and Elevators are linked for the elevator function, again . But that can probably be fixed.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old May 22, 2010, 01:56 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Well, good try, I've already seen it but thanks anyway!
Come on Lanxiang! Let us see how this bird flies!
Old May 22, 2010, 08:09 PM
lovetofly25 is offline
Find More Posts by lovetofly25
lovetofly25's Avatar
Melbourne, Aust
Joined Nov 2009
PERFECT TIMING, The demise of my 34 leaves space in the hanger. Looks like the 29 will fill its absence nicley. well done LX
lovetofly25 is offline Find More Posts by lovetofly25
Old May 23, 2010, 02:47 AM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
What happened to your 34
Dark Angel is offline Find More Posts by Dark Angel
Old May 23, 2010, 01:22 PM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Hello,
I don't know what happened to HIS 34, but I attach a picture of what happened to my new 34 yesterday .
Cheers,
Henrik
Old May 23, 2010, 06:27 PM
skunkworks
Dark Angel's Avatar
Joined Apr 2008
Ok what happened to that one? My condolences by the way.
Old May 23, 2010, 06:57 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I'm Sorry Henrik, that must have been terrible!
How did it happen?
Old May 24, 2010, 02:53 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Pilot error. Start was okay, 90 right turn, ok, next 90 turn, not enough speed in the right turn, too much bank angle in the turn, slip of the plane, nose down, not enough pull up, impact.
Added bonus: Trying whether the impellers still work after the crash. Both worked for a second, but one sucked in a little stone and you bet it stopped working after that.
A learning experience! Next time: More speed, more altitude.
Cheers,
Henrik
Old May 24, 2010, 08:51 AM
Joined Sep 2008
Did anyone else have trouble getting the gear doors to work? It's tricky getting the string to be just the right length.
Old May 24, 2010, 09:35 AM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
i did have some trouble, but i manually removed the servo arm and centered all 3 servo's, after that i adjusted the travel adjust on close, and also adjusted the length of the string. all that for just one flight. oh well......
f4addict is offline Find More Posts by f4addict
Old May 24, 2010, 12:54 PM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Hehe, the pain, the horror :-). If I think how much extra work I put in to get ball nozzles etc to the Su-47, grmbl. But anyway, I just pre-ordered a Mig and am curious. But it will probably take 2-3 weeks or so before it is really here.
Cheers,
Henrik
Old May 24, 2010, 02:05 PM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Concrete trim angles
Hello,
Michael from xpowershop just posted his Su-47 trim angles in a German forum. A his numbers are the first to be posted anywhere (that I am aware of), I repeat them here. Thanks Michael.
  • His longitudinal dihedral ("Einstellwinkeldifferenz") between main wing and elevator is 1. That means that, as the main wing has an angle of 0 degrees to the longitudinal axis (it is parallel to it), his elevator is down (leading edge down) by 1.
  • His canards are fixed at 3 leading edge up.
  • He removed the TV nozzles, so the airstream goes out at 0.
Cheers,
Henrik
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1702 May 23, 2016 08:24 AM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 12:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
