Old Jan 21, 2010, 12:25 PM
squirrlybird is offline
Find More Posts by squirrlybird
squirrlybird's Avatar
Greenville, SC
Joined Feb 2007
The F-35 STOVL is the only aircraft to have taken off vertically, accelerated to supersonic, then landed vertically.
The F-35 STOVL is the coming replacement for the USMC's harrier. The Navy will be getting the CTOL version, which is not capable of hovering but has beefier landing gear for carrier ops. The Air Force will get the standard F-35 which will be capable of holding more weapons than the STOVL and CTOL.
I also fly the helis, but when discussing planks, "hover" is generally verticle with horizontal VTOL such as the harrier and F-35 being something totally different. I have only seen talk of horizontal hovering using edf/turbine with never any real results.
squirrlybird is offline Find More Posts by squirrlybird
Old Jan 21, 2010, 01:32 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
If you want info on how to hover "vtol" like the Harrier then this is the place to look.
http://www.rcgroups.com/vtols-360/
There are some very interesting projects going on there, like this one:
swivel duct (0 min 14 sec)
kuczy is offline Find More Posts by kuczy
Old Jan 23, 2010, 03:05 PM
Bigdaddi is offline
Find More Posts by Bigdaddi
Bigdaddi's Avatar
north east pa
Joined Nov 2009
Wow! that is a great video. I can see a production vertical lift EDF jet comming soon.
But seriuosly, when we are talking about hovering RC jets we are not talking about vertical lift.
From looking at this su-47, it seem like it's going to take to get this thing to hover. It is going to need more than a 1.1 ratio. The size of this thing will work ot it's advantage, but it needs to step up the power a bit.
Bigdaddi is offline Find More Posts by Bigdaddi
Old Jan 23, 2010, 07:36 PM
Redemptioner is offline
Find More Posts by Redemptioner
Professional UAV Services
Redemptioner's Avatar
Australia
Joined Dec 2009
yup, 2x2kg+ fans are needed to sit there and have enough power to get out of it. At the same time the better motors will draw less juice when you are flying it arround at lower speeds. It won't fly for long drawing the full 2000w though.
When mark gets the ARC's in this week I will be putting a set of these in
http://www.extremerc.com.au/estore/i...roducts_id=704
http://www.extremerc.com.au/estore/i...roducts_id=683
Redemptioner is offline Find More Posts by Redemptioner
Old Jan 23, 2010, 08:29 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
ARC are already in! Better jump on the site and order the motors at least as after the back orders were filled there are only 7 left I think.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 25, 2010, 03:37 AM
Baca is offline
Find More Posts by Baca
Baca's Avatar
Melbourne , Australia
Joined Jun 2006
Hi, I had 2 flights today , first time after some mods .First was a bungee launch and landing wheels down on the grass ,second ,take of and landing on the grass , no problems .In first flight one of the canards unhooked from the servo and get stuck in about 45deg .I didn't notice till after landing , there was not much difference in flight , try to roll a bit .Looks like canards are not very efficient .
SU-47 (1 min 37 sec)
Baca is offline Find More Posts by Baca
Old Jan 25, 2010, 05:43 AM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
Andrew, what were the mods you made for that flight yesterday?
Were the carbon spars fitted?
And did you move the cg?
Dzieki !
FOX ONE! is offline Find More Posts by FOX ONE!
Old Jan 25, 2010, 12:51 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Hello Andrew,
nice slow landing! Did you move the CoG backwards a bit? Or change another part of the trim? Also, the wings don't bend as much as they used to in your previous video, did you put the carbon spars in? How many mAh did you use? Questions over questions !
I think the plane looks very beautiful in the air, especially if you do a banked turn where the canards and the forward-swept wings become visible.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Jan 25, 2010, 01:36 PM
Baca is offline
Baca's Avatar
Joined Jun 2006
Hi ,CG in the moment 30 mm but I think can be move back a bit more .I already have 100 g of lead in the tail .You don't need cheater hols .No more wing bending .I made a slot with 3 mm router bit, 6 mm deep and insert spar made of 2 ,3X3 mm carbon square tubs glued together (post394) .Looks very neat.After 4 min of flight with throttle management used abour 2500 mAh , 3/4 capacity .
Andrew
Czesc!
Old Jan 25, 2010, 05:46 PM
lovetofly25 is offline
Find More Posts by lovetofly25
lovetofly25's Avatar
Melbourne, Aust
Joined Nov 2009
Great Flight Video
Baca, well done on the video's. yours floats in like mine. As mentioned I'm running the c/g at 30mm and happier with it. Lucky with the cannard, i'm gald i fuel tubed all my clevices during assembely.
I'm yet to cover in the cheater holes, did you find it made much diffrence?.
My next Modification is same as yours on the U/C and to seperate the Ailerons.
Happy Australia Day. To All
lovetofly25 is offline Find More Posts by lovetofly25
Old Jan 25, 2010, 06:35 PM
FOX ONE! is offline
FOX ONE!'s Avatar
Joined Aug 2008
Dziękują !
Old Jan 25, 2010, 06:55 PM
Melbourne, Aust
Joined Nov 2009
Originally Posted by abagnalejr123 View Post
Dziękują !
G'day Mate, very well done, a big thankyou back at you.
Old Jan 25, 2010, 07:45 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Defintely want this one.
kahloq is offline Find More Posts by kahloq
Old Jan 25, 2010, 10:21 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Actually those are not canards. Just like on the su-37. They are to help direct air over the wings surface. The canards on these and the 37's and other SU's are way too small in real life to be an effective control surface. They are functional but not for what many think. The eurofighter uses true canards. While they are still called canards they have more to do with directing and keeping air going over the wings at different angles than providing direct pitch control movement.
lavochkin is offline Find More Posts by lavochkin
Old Jan 26, 2010, 02:14 AM
Turbo442 is offline
Find More Posts by Turbo442
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
Looks like BH is about to ship out some Berkuts! My friend and I both recieved shipping notices.
Turbo442 is offline Find More Posts by Turbo442
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1693 Apr 14, 2016 07:36 AM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Discussion Wicked thrust vectoring twin turbine mig-29 video lavochkin Foamy EDFs 5 Jun 12, 2008 12:07 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
